Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-14-2009, 09:53 AM   #1
eric
eric is on a distinguished road
Default can ect sensor or bad t-stat cause engine to run rough?
2001 ford ranger 2.3 liter 5 speed
Hello,
My thermostat is bad (gauge does not work and no heat) and check engine light came so I had it scanned at autozone. Guy said bad ect sensor and that is causing my truck to run a bit rough (tough to accelerate ).
I also get poor gas mileage and I was told this is because of bad ect sensor. Can I get your opinion? Do you think ect going bad will cause engine to run rough?
Lastly, can you please walk me through the changing of thermostat and ect sensor? Do I have to drain antifreeze? I think t-stat is at bottom of engine block. Can I simply pull hose off , unscrew / bolt t-stat and put on new one while pointing hose up to avoid spilling? How do I locate ect sensor ? I cannot find it.
Someone told me my coil pack was bad ( plug #3 was not firing) I do not know what kind of diagnostic he did. I was changing my plugs a while back and ripped wire out of plug#3 rubber cap that goes over plug. I put wire back in rubber cap and it started fine. When I finally changed my wires , I noticed that plug #3 wire was frayed. I told mechanic guy wire may be bad but he may not have been listening. I spoke to a dealer service dept and he said coil packs usually do not go bad Your thoughts please
Engine has been running rough for a while and when changed plugs they were pretty well worn out.
thanks in advance
eric is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-14-2009, 09:59 AM   #2
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
"The ECT is third in command in the hierarchy of EFI sensors, this means this sensor is very important when calculating fuel ratios and timing curves."
from http://www.fordfuelinjection.com/?p=28
I believe you'll need to drain your coolant down below the level of the T-stat you plan to replace. I don't know about your ECT - it may not even be bad, but is simply reporting to the computer that the coolant isn't ever getting up to temp (from the bad t-stat). I've heard something about the new t-stats having a temp sensor built in and costing $140. Don't know if that's what you've got or not.
Welcome to TRS (an expert will be along shortly to help you with the other questions).
Earl43P is offline   Reply With Quote
Old 01-14-2009, 02:25 PM   #3
Wicked_Sludge
Wicked_Sludge's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger, Flareside
I use this vehicle for: Attracting the ladies
Wicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the rough
Send a message via MSN to Wicked_Sludge
Default
the ECT sensor is likely fine. the cumputer never tells you you have a bad sensor, it simply reports what the sensor is reporting. in this case, its low coolant temps due to a stuck-t-stat. i would replace the t-stat and reset the code and wait to see if it comes back on.
a stuck t-stat will cause all the symptoms you describe.
you can easily and controllably drain the coolant from the system using the petcock located on the lower corner of the radiator.
a bad coil pack would likely cause a miss in 2 cylinders (one coil fires two cylinders), and is usually enough to set off a misfire code with the computer.
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 01-14-2009, 03:11 PM   #4
dorman68
Vehicle Year: 1993
Vehicle Make: Ford
dorman68 is on a distinguished road
Default
I think that it is for the ECT sensor to cause a rough running engine. One thing that I have seen on some of the 2.3L Rangers is that the IMRC(Intake manifold runner control) or the intake manifold swirl control valve vacuum solenoid is prone to sticking or the vacuum hose connecting to it deteriorates or falls off.
__________________
1993 Ranger 2.3L,5-spd-2wd - 149,000 mi.(slow as dog-dirt)
1994 Ranger 2.3L,Auto-2wd - 155,000 mi.(Sold)
2005 Corolla LE - AT Trans
dorman68 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
