Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-27-2009, 08:28 PM   #1
Rangerman87
Rangerman87's Avatar
Vehicle Year: '88,'11
Vehicle Make: ford,mitsubishi
Vehicle Model: ranger sc,Ralliart
I use this vehicle for: Ralliart is my dd/winter vehicle and ranger when I need it.
Rangerman87 is on a distinguished road
Angry Truck loses power while driving
What would cause the engine to lose power when I'm driving.When I punch it,there is a slight hesitation and then it picks up and does it all over again.I've replaced the IAC,plugs,intank fuel pump and filter.Would the fuel pressure regulator cause it and if so wheres it at,I'm also thinking maybe the framerail mounted pump and also what is the assembly next to it,it's round and sits horizontily.This shit is getting annoying,would the egr have anything to do with it?Any help would be greatly appreciated!
Rangerman87 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-28-2009, 02:39 PM   #2
eb89
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger xlt
I use this vehicle for: DD
eb89 is on a distinguished road
Default
Have you checked out your ignition module? I had some problems with my truck dying while driving and then not always restarting right away and a new module fixed that. you might want to check into that. Also you might try gettin a computer diagnostic and see if any codes pop up.
eb89 is offline   Reply With Quote
Old 01-28-2009, 03:00 PM   #3
CraigK
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Bronco II
CraigK is an unknown quantity at this point
Default
disconnecttheO2sensor
CraigK is offline   Reply With Quote
Old 01-28-2009, 04:34 PM   #4
The Fox
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Picking Up Vixens
The Fox is on a distinguished road
Default
Check codes and fuel pressure.
A plugged cat could also cause the lack of power and it would happen all of a sudden. Just run the motor at idle until warm and look at the car, they will usually glow orange or red hot if they are blocked.
Nick
__________________
1988 Ranger XLT- 2.9L, FM-146 5 Speed, 4x4 w/ Mechanical Transfer, Ford 7.5" Limited Slip, 3.73 Gears, Cobra 148 GTL w/ Wilson 5000 Mag Mount. Bone Stock Otherwise.
The Fox is offline   Reply With Quote
Old 01-28-2009, 06:33 PM   #5
IMenriched
IMenriched's Avatar
Vehicle Year: 1986 02'
Vehicle Make: ford
Vehicle Model: ranger f150 fx4
I use this vehicle for: exercise and DD & hauling college kids stuff
IMenriched is on a distinguished road
Default
All good suggestions.
when was the last time you had it tuned up? air filter???
you MIGHT have 2 fuel filters....1in a plastic canister just ahead of the fuel tank & 1 inline metal filter just after the frame rail FP...also on the frame rail. Usually in 87 they only had 1....but a few say they had 2 yet.
Have taken any fuel pressure readings??
pull the little vacuum line off the FPR (Fuel Pressure Regulator)....if you have a dribble of fuel out of it... then yes.... it is shot.
check the all vacuum ports on the upper intake...to make sure they are not crusted over with carbon.
__________________
IMenRiched
By the power of Lord Jesus
2 are willing to die for you.
one is a soldier, but the 1st was Jesus Christ
~few appreciate either~
IMenriched is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
