Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-30-2009, 05:30 PM   #1
KevinV6
KevinV6's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Mustang
I use this vehicle for: DD
KevinV6 is on a distinguished road
Default Belt tensioner on 99 Ranger?
Hey guys, I don't own a Ranger but I'm helping my friend replace the alternator in his 99 3.0 Ranger. I've run into a snag as, unlike in the Haynes manual, or any other Ranger I've seen on the internet, the belt tensioner in his engine bay (what looks like the tensioner anyway) does not have a square hole where a 3/8" socket would go. It has a T-47 reverse torx bolt which just loosens the entire tensioner assembly, and I've found no way to adjust it so that I can mount the serpentine belt around the alternator pulley.
I don't have the truck near me to go take a photo or check, but is there a way to pivot the idler pulley next to the Alternator to loosen the belt tension? That's what I was thinking about trying next, but I won't get a chance to work on it till tomorrow.
Thanks.
KevinV6 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-30-2009, 09:06 PM   #2
fleck
fleck's Avatar
Vehicle Year: 1994
Vehicle Make: Mazda
Vehicle Model: B3000
I use this vehicle for: Work
fleck is on a distinguished road
Default
You move the tensioner pulley down by 'tightening' the tensioner pulley bolt, this moves the tensioner pulley down and voila, belt slips on. We put the belt in the dryer for 5 minutes to get it floppy.
__________________
Workhorse? More like 'work, whore'! Owned 5 months and:
Silverstar headlight bulbs; New clutch & clutch line, slave & master cylinders; Serpentine belt & belt tensioner; Radiator and a hose, thermostat removed; Spark plugs, battery, & battery terminals; PCV valve and fuel pressure regulator; Fuel filter and fuel pump relay replaced; Air flow sensor and throttle body cleaned
Two new tires mounted & balanced; New rear window installed; Several intake cleaning treatments...
fleck is offline   Reply With Quote
Old 01-31-2009, 12:12 PM   #3
Bob Ayers
Vehicle Year: 1999
Vehicle Make: Ranger
Vehicle Model: St. Cab
Bob Ayers has a spectacular aura aboutBob Ayers has a spectacular aura aboutBob Ayers has a spectacular aura about
Default
Fleck is correct, you need to rotate the tensioner pulley bolt, to remove the tension on the serpentine belt. Here are a few photos to help you:
Using a 15mm boxed-end wrench, turn the tensioner pully bolt clockwise (tightening) to loosen the tension
on the serpentine belt:
__________________
"you can rant, rave, scream, shout invective, claim infinite experience,
and ultimatly deny that you are wrong until hell freezes, but you are WRONG." Alland
Bob Ayers is offline   Reply With Quote
Old 02-01-2009, 08:02 AM   #4
Bob Ayers
Vehicle Year: 1999
Default
I realized that I had an old tensioner, that I changed several years ago.
These photos should show you how the tensioner is made, and how it works:
Notice without a belt in place, the outer part of the tensioner (part the pulley is mounted to)
is in the full counter-clockwise position.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
