Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 02-18-2009, 02:05 PM   #1
TomB1269
TomB1269's Avatar
Vehicle Year: 2002, 2005, & 2
Vehicle Make: All Fords
Vehicle Model: Ranger Edge '02, Freestar '06 & The newest '05 F150 FX4 SCrew
I use this vehicle for: Original Daily Driver/New DD
TomB1269 is on a distinguished road
Question New 4.2L FWD motor to 3L auto Ranger?
The 4.2L in my Freestar looks to be the same block as the 3.8L in my old Windstar. If ever the opporunity arises would the 4.2L FWD fit as does the old 3.8L FWD? If you have driven the new F-stars, the HP is only around 200 but the torque is nice at 268 and the curve is 3600 to 4200 rpm. Which makes it a very nice driving engine for the weight van is slightly heaver than 2002 Edge extra cab 2 door.
TomB1269 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-18-2009, 08:31 PM   #2
rurouni20xx
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Everything
rurouni20xx is on a distinguished road
Send a message via Yahoo to rurouni20xx
Default
since a 4.2 is simply a stroked 3.8 i think it would be nice, the question is are the bolt patterns the same. til somebody takes one out and confirms its a 3.0 pattern not a 5.0 pattern i dont think anybody will attempt it.
rurouni20xx is offline   Reply With Quote
Old 02-22-2009, 05:21 PM   #3
Piper106
Piper106 is on a distinguished road
Default
According to one of the websites that talks about Ford trans bolt patterns, the FWD 3.8 / 4.2 L V6 motors have the same trans bolt pattern as the Ranger 3.0 V6.
That is what I have read, I have not seen the parts in question, so proceed with caution.
Piper106
Piper106 is offline   Reply With Quote
Old 03-16-2009, 03:46 PM   #4
Moto Mel
Junior Member
Vehicle Year: 1992 1994 19
Vehicle Make: Ford Ranger Li
Vehicle Model: STX 4X4 Mark VIII XLT Expedition 4X4 Navigator 4X4
I use this vehicle for: All of them for everything
Moto Mel is on a distinguished road
Default
Piper106
The bolt pattern is also the same between the 3.8 V6 and the 4.6 V8 which gives a multitude of engine swap choices.
Moto Mel is offline   Reply With Quote
Old 03-16-2009, 06:00 PM   #5
Gotta_gofast
Gotta_gofast's Avatar
Vehicle Year: 2006
Vehicle Make: Ford
Vehicle Model: F250 FX4
I use this vehicle for: Droppin panties
Gotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to allGotta_gofast is a name known to all
Default
Quote:
The 3.8L V6 in a Rear Wheel drive application will share the same bellhousing bolt pattern as the modular mustang V8s. The 3.8L V6 found in front wheel drive (trans-axle) applications will share the same bellhousing bolt pattern as the vulcan 3.0L V6. In order to bolt a 3.8L/4.2L V6 to the 3.0L vulcan's transmission, you would need to find one out of a FWD vehicle.
__________________
2006 F250 Super Duty Fx4. 6.0L powerstroke ARP studs, EGR delete, 4" turbo-back, bullydog intake, SCT livewire TS with looney tunes...
(sold) SUPERCHARGED 2005 Ford Ranger
Gotta_gofast is offline   Reply With Quote
Old 03-25-2009, 03:00 PM   #6
Dave
Junior Member
Vehicle Year: 1992
Vehicle Make: Ford
I use this vehicle for: getting from point A to point B
Dave is on a distinguished road
Default
Quote:
Doesn't a RWD 3.8L have a SBF bellhousing? Or did Ford make the RWD 3.8L in both SBF and Modular bellhousings.
Dave is offline   Reply With Quote
Old 04-28-2009, 10:21 AM   #7
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
Not all the 3.8's have a Winsor bellhousing.
I can tell you for certain that the manual trans I have out of a Thunderbird Supercoop is most definatly NOT a windsor bellhousing.
I got the trans in the hope of using it to make a 2wd 5.0 Ranger
without using a cable clutch or an "R2" F-series transmission.
That hope died as soon as I had the trans next to the 5.0 engine
I had at the time.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 04-28-2009, 12:06 PM   #8
Faster7
Vehicle Year: 1986
Vehicle Model: Ranger 2.3T
Faster7 is on a distinguished road
Send a message via AIM to Faster7
Default
I had at the time.
AD
Can you send pictures of that transmission? I've been around supercoupes and other IRS thunderbirds for years, and every 3.8 car has has had the windsor bellhousing. Same thing with my '82 grenada 3.8 V6 and the early fox 3.8's I've worked on.
Faster7 is offline   Reply With Quote
Old 06-11-2009, 05:16 PM   #9
DCinDC
Junior Member
DCinDC is on a distinguished road
Default
The 4.2 fwd will be my upgrade path when my 3.0 dies, which is unlikely cuz I have a dizzy.
Hey Allan! :wave:
DCinDC is offline   Reply With Quote
Old 06-11-2009, 06:12 PM   #10
odie1969
odie1969's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: 87 stx
odie1969 is on a distinguished road
Default
OK let me get this I can take the 4.6 out of the wifes Muff-stang and drop it in the ranger with out swapping the trans. Ya that will last a week before the trans is in peices. But I wish someone would do the a 4.2 swap. that might be a cool swap with good info.
__________________
Plz no grammer NAZIS I know my spelling and grammer sucks. thanks.
2001 ranger 3.0l 2wd posed out with prerunner fronts. Sold
1987 ranger 2.9l 4wd stx (swaping in 4.0l sohc trans and 8.8) For sale
1969 mercury cougar conv. 351w virgin as mary
1964 MG Midget 1275cc motor
1996 mustang Gt conv. 4.6l steeda susp. parts Sold
2004 f350 king ranch
2007 Expedition El Limted
odie1969 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
