Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-07-2009, 08:44 PM   #1
amanda11270
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger 3.0 4x4
I use this vehicle for: Pleasure
amanda11270 is on a distinguished road
Default My truck starts, sputters, then dies 3.0L 1999
Hey guys, over the past few days, my truck has needed to be cranked longer than the norm to start, but it would run okay, and today, me and my family went on a hiking trip 30 miles away and upon arrival my truck suddenly sputtered out and died, no engine codes at all. I keep my OBD2 tool in the glovebox. It would immediately restart, but then die immediately after. I got it towed home and It would restart, then sputter and die again quickly, but not as quickly as when it first stopped. The longer it sits, the better it starts and revs, but regardless it will sputter and die in 30 - 60 seconds usually now. It will even rev normally a few times before dying if it sits long enuf. I replaced the fuel filter about 2000 miles ago, and did a complete tune up at that time also, every thing but the ignition coil. But since my truck is throwing no codes at all, im thinking the fuel pump is out. That is a big job though, before I start Anyone have an idea of if this sounds like the fuel pump? Thanks
amanda11270 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-07-2009, 09:07 PM   #2
rustybolt
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger XLT
rustybolt is on a distinguished road
Default
Check to make sure the fuel filter was not installed backwards. There's an arrow printed on the filter, make sure it's pointing toward the engine. I would also inspect the fuel lines for any sign of damage (compressed or crushed).
rustybolt is offline   Reply With Quote
Old 03-07-2009, 09:13 PM   #3
fleck
fleck's Avatar
Vehicle Year: 1994
Vehicle Make: Mazda
Vehicle Model: B3000
I use this vehicle for: Work
fleck is on a distinguished road
Default
Or the $11 fuel pump relay.
__________________
Workhorse? More like 'work, whore'! Owned 5 months and:
Silverstar headlight bulbs; New clutch & clutch line, slave & master cylinders; Serpentine belt & belt tensioner; Radiator and a hose, thermostat removed; Spark plugs, battery, & battery terminals; PCV valve and fuel pressure regulator; Fuel filter and fuel pump relay replaced; Air flow sensor and throttle body cleaned
Two new tires mounted & balanced; New rear window installed; Several intake cleaning treatments...
fleck is offline   Reply With Quote
Old 03-07-2009, 09:26 PM   #4
RumpRanger98
Vehicle Year: 1999
Vehicle Make: Ford
I use this vehicle for: Doing work
RumpRanger98 is on a distinguished road
Default
check the fuel pressure...
__________________
New Toy- 1999 Ford Ranger XLT 4x4 v6 3.0L 5speed
DD- 1992 Nissan Maxima SE, 3.0L DOHC V6 auto, ASP UDP, CAI, Full 2.5" exhaust, 2"drop, Stillen kit, E36 BMW halo conversion. CarDomain
RumpRanger98 is offline   Reply With Quote
Old 03-09-2009, 06:57 PM   #5
amanda11270
Vehicle Year: 1999
Vehicle Make: Ford
Default
Okay, I have never actually tested a fuel pump before, but today I went out and bought this kit that attaches to the fuel rail port, and it says my truck has 55 psi at the rail, when you shut the truck off it slowly drops almost to zero but not quite, then when you turn the key or restart it it goes back up to 55 again. And also since the truck sat overnite it now runs fine. Yesterday after driving it, it would only sit and sputter, then eventually die. And it wasnt overheated. I think the pump maybe getting flaky and if I actually drive it anywhere it will fail on me and leave me sitting. Anyone else have this problem. The truck still has no trouble codes at all in the OBD2.
Old 03-09-2009, 07:02 PM   #6
Beef52751
Snake Champion
Beef52751's Avatar
Vehicle Year: 86
Vehicle Make: Ford
I use this vehicle for: Beater/Toy
Beef52751 has a spectacular aura aboutBeef52751 has a spectacular aura about
Default
if youve got pressure i doubt if its the pump. in my experiences fuel pumps dont come and go, they are there or theyre not.
Id try testing the coilpack, my truck had similiar symptoms when mine went out.
Beef
__________________
86 Ranger 2.9 4X4 D35 8.8 FM145 BW1350M 33s (Build Thread)
83 Ranger RCSB 2.0 5-speed
06 CCSB KR F250 6.0 4X4
Beef52751 is offline   Reply With Quote
Old 03-09-2009, 07:05 PM   #7
fleck
fleck's Avatar
Vehicle Year: 1994
Vehicle Make: Mazda
Default
Fuel pump relay ma'am, it could cause symptoms like these, and it's only $11.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
