TheRangerStation.com  SM
Serving Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Resources Tech Library Magazine Video Gallery Truck Gallery Shirts & Decals Parts
Go Back   The Ranger Station Forums > Truck Discussions > Towing
Towing For questions about towing or to show off your tow rig.
Post New Thread Reply
Thread Tools Display Modes
Old 04-21-2009, 04:40 PM   #1
MrShanks2U
Junior Member
MrShanks2U's Avatar
Year: 2000
Make: Mazda
Model: B3000
MrShanks2U is on a distinguished road
Send a message via AIM to MrShanks2U
Default Can someone identify this trailer hitch?
Bought this trailer hitch the other day. I don't know if this is possible, but could someone tell me who the manufacturer might be and what the weight capacities may be for it? Thanks in advance!
__________________
2000 Mazda B3000
2wd
5spd
K&N filter
MrShanks2U is offline   Reply With Quote
Old 04-21-2009, 05:39 PM   #2
mjonesjr
Plannin For Tomorrow...
mjonesjr's Avatar
mjonesjr is on a distinguished road
Send a message via AIM to mjonesjr
Default
It looks like it is for an Explorer or Bronco II...
__________________
"The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
- Thomas Jefferson -
Support Our Troops!
mjonesjr is offline   Reply With Quote
Old 04-21-2009, 06:17 PM   #3
Chris.S.
Chris.S.'s Avatar
Year: 2010
Make: Ford
Model: Ranger FX4
Engine: 4.0
Class: 4x4
Used For: A bit of everything...
Chris.S. is on a distinguished road
Default
Looks like a class III which has a rating of 6000trailer 600tongue.
Quote:
Class I Hidden Hitch
Class I hitches are weight carrying (WC) hitches rated up to 2000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 200 lbs. The use of a drawbar and hitch ball of the same rating or higher is required. Some hitches in this class may attach to the vehicle bumper or trunk pan. Most other Class I hitches attach to the vehicle frame. Always consult your owner's manual for vehicle rating.
Class II Hidden Hitch
Class II hitches are weight carrying (WC) hitches rated up to 3500 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 300 lbs. The use of a drawbar and hitch ball of the same rating or higher is required. Class II hitches normally attach to the vehicle frame and or bumper. Always consult your owner's manual for vehicle rating.
Class III Hidden Hitch
Class III hitches are weight carrying (WC) and also are weight distributing (WD) hitches depending on the vehicle and hitch specifications. Not all Class III hitches are rated to be both. The hitch specifications will alert you to a hitch that is not weight distributing. Class III hitches used as weight carrying is rated up to 6000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 600 lbs. Hitches that are used for weight distributing are rated up to 10,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1000 lbs. The use of a ball mount and hitch ball of the same rating or higher is required. To use the weight distribution side of the hitch a weight distribution system is required. Class III hitches attach to the vehicle frame only. Always consult your owner's manual for vehicle rating.
Class IV Hidden Hitch
Class IV hitches is very similar to Class III hitches except for the weight ratings. Class IV hitches are weight carrying (WC) and weight distributing (WD) hitches depending on the vehicle and hitch specifications. Not all Class IV hitches are rated to be both. The hitch specifications will alert you to a hitch that is not weight distributing. Class IV hitches used as weight carrying is rated up to 10,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1000 lbs. Hitches that are used for weight distributing are rated up to 14,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1400 lbs. The use of a ball mount and hitch ball of the same rating or higher is required for weight carrying. To use the weight distribution side of the hitch a weight distribution system is required. Class IV hitches attach to the vehicle frame only. Always consult your owner's manual for vehicle rating.
Class V Hidden Hitch
Class V hitches is very similar to Class III & IV hitches except for the weight ratings and that the hitch uses a 2-1/2" receiver. Class V hitches are weight carrying (WC) and weight distributing (WD) hitches. Class V hitches used as weight carrying is rated up to 12,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1200 lbs. Hitches that are used for weight distributing are rated up to 17,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1700 lbs. The use of a ball mount and hitch ball of the same rating or higher is required. To use the weight distribution side of the hitch a weight distribution system is required. Class V hitches attach to the vehicle frame only. Always consult your owner's manual for vehicle rating.
__________________
2010 FX4 4X4, 4.0 SOHC, Auto, Magellan nav, 265/75 16 Toyo Open Country M/T's, 2" TT , 2" Shackles
Chris.S. is offline   Reply With Quote
Old 04-21-2009, 07:00 PM   #4
MrShanks2U
Junior Member
MrShanks2U's Avatar
Year: 2000
Make: Mazda
Model: B3000
Default
The only thing I know about this hitch is that it will fit '98 and later rangers and '99 and later B-Series. I tried looking around online but could not find any hitch made by the major manufacturers that looked like this one. A guy that I work with has a '03 Ranger that has this exact same hitch on it. But he said that it came on the truck when he bought it 2 years ago. I'm starting to think that maybe this is a factory Ranger hitch. Do y'all think that this could be the case? What are the weight capacities on the factory Ranger hitches?
EDIT: Also, I'm thinking about laying some fresh paint on it. It looks like it has some overspray on it and there are also a few spots where it looks like it is starting to rust. I'm just going to clean it up with a scotch pad or light sandpaper and paint over it. What kind of paint do you think would work best? I was looking at rustoleum at AutoZone. You think that would hold up pretty well?
__________________
2000 Mazda B3000
2wd
5spd
K&N filter
Old 04-21-2009, 11:20 PM   #5
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD has a spectacular aura aboutAllanD has a spectacular aura aboutAllanD has a spectacular aura about
Default
The mounts on it look suprisingly like the FRONT bumper mounts on a Gen2 or Gen3 Ranger.
But the rear bumper on an Explorer mounts the same way.
AD
__________________
Political Correctness: A doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
AllanD is offline   Reply With Quote
Old 04-22-2009, 02:11 AM   #6
Captain Ledd
Captain Ledd's Avatar
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Used For: Literally everything.
Captain Ledd is on a distinguished road
Default
From the safety chain plates, welds and style, it looks like a Reese Hitch, very similar style of construction to the Reese I recently installed. It also does appear to be class III.
As to what it goes to I can't help. I don't think it goes to the rear of a GenIII Ranger though.
__________________
"The difference between genius and stupidity is that genius has its limits" - Albert Einstein
1984 Ranger - std cab, long bed: The Deathtrap
302; T18; D20 Tcase; 6' lift; 4.56 gears; 33' pro comp MT's; Aussie locked rear
1997 Ranger - std cab, short bed: Red Ranger
2.3L; M50D R1; 1 wheel drive ; bone stock
(soon to undergo 4x4 conversion )
Captain Ledd is offline   Reply With Quote
Old 04-22-2009, 08:31 AM   #7
Chris.S.
Chris.S.'s Avatar
Year: 2010
Make: Ford
Model: Ranger FX4
Engine: 4.0
Class: 4x4
Default
I believe the factory receiver hitches are made by either Valley hitch or Hidden hitch, the valley hitches have a rating of 1000/100 lower then the number I listed previously.
Is there any sort of part number or anything on it anywhere?
__________________
Old 04-22-2009, 03:39 PM   #8
MrShanks2U
Junior Member
MrShanks2U's Avatar
Year: 2000
Make: Mazda
Model: B3000
Default
Quote:
No.
__________________
2000 Mazda B3000
2wd
5spd
K&N filter
Old 04-22-2009, 06:21 PM   #9
strvger
strvger's Avatar
Location: the land of 2 seasons-Winter and getting ready for Winter!
Year: 1983
Make: Ford
Model: Ranger reg cab, short bed
Engine: 2.8
Class: 4x4
Used For: dd and light trail riding
strvger is on a distinguished road
Default
after sanding the hitch, i'd recommend using POR-15 or something similar to protect it from future rust issues. you will need to topcoat/paint over the POR-15 so it won't degrade from UV light.
__________________
1983 Ranger, 2.8 V6, 5 spd, 4x4, duraspark'd, 2in bl, 31" TreadWright AT's, 4.56 gears, rear Detroit, 42 gl. gas.
"Life is tough. It's tougher if you're stupid"
The Duke
strvger is offline   Reply With Quote
Old 04-22-2009, 06:54 PM   #10
MrShanks2U
Junior Member
MrShanks2U's Avatar
Year: 2000
Make: Mazda
Model: B3000
Default
Quote:
Are there any retail chains that sell POR-15? The only place I've ever seen it is in my Essentials catalogs.
__________________
2000 Mazda B3000
2wd
5spd
K&N filter
Old 04-22-2009, 07:53 PM   #11
suzuki14258
Junior Member
Year: 2004
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Used For: Daily Driver
suzuki14258 is on a distinguished road
Default
That looks alot like my hitch i got from ford.
suzuki14258 is offline   Reply With Quote
Old 04-28-2009, 06:58 PM   #12
MrShanks2U
Junior Member
MrShanks2U's Avatar
Year: 2000
Make: Mazda
Model: B3000
Default
What do the mounting bolts need to be torqued to?
__________________
2000 Mazda B3000
2wd
5spd
K&N filter
Old 04-28-2009, 08:38 PM   #13
strvger
strvger's Avatar
Year: 1983
Make: Ford
Engine: 2.8
Class: 4x4
Default
Quote:
got mine at a local auto parts store. most of them should carry it really. it is very popular in most areas of the country, even if it is rather spendy.
__________________
The Duke
Old 04-28-2009, 09:19 PM   #14
Jspafford
Awww Crap!
Jspafford's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Tickets
Jspafford will become famous soon enough
Default
That does NOT look like a Ranger hitch. I work at a dealership (RV) and I sell them all day long. That looks like a newer explorer hitch. It has too much drop to be a Ranger. I can tell you it is not a Reese, Draw-Tite, or Hidden Hitch if it fits a Ranger. I have a hitch for a 1983-2008 Ranger held for a customer behind the counter and it has a flat mounting flange about 6 inches across with two bolts per side, and a round hole cut out of each side to fit over a rivit in the frame rail.
Should be good for at least 5K, no matter the brand.
Just looked again, and those are definitely factory bolts being welded to the holder like that. No aftermarket manufacturers use those. They all just use grade 5 bolts.
Jspafford is offline   Reply With Quote
Old 05-16-2009, 12:30 AM   #15
JoesEdge
JoesEdge's Avatar
Year: 2003
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD Off-Road
Used For: Daily Driving and Off-Roading
JoesEdge is on a distinguished road
Default
The side mounts look like a Hidden Hitch, but the rest doesn't. I like it though. I wish I knew what brand it was so I can buy one just like it.
__________________
2003 Std Cab Ranger Edge-3.0L-5 Spd
Mods: K&N FIPK, U/D Pulley, Spintech 2.5" I/O Exhaust, Detroit Locker, 4.56 R/P, Camburg 6.0 Edge Kit, Deavers, Bilstiens, AR Baja 15" x 8", BFG 33" x 12.5" A/T
JoesEdge is offline   Reply With Quote
Reply
Bookmarks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1999 - 2010 The Ranger Station - James Oaks Enterprises LLC - All Rights Reserved
'The Ranger Station' and it's logo are Service Marks of The Ranger Station owned by James Oaks Enterprises LLC.
The Ranger Station is in no way affiliated with the Ford Motor Company
Legal Notice
