how do i know if i have 4 wheel abs or rear only
jandm
ford
i need new front rotors asap, is there an easy way to tell if i have 4 wheel abs or rear only, any help would be appreciated. 96, 4x4, 4.0
jandm
ford
Quick assistance would be very helpful i have to go soon for a mmeting and i need the answers ASAP It would be GREATLY appreciated...
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
Engine Type
V8
6.6L
2WD / 4WD
5"
35"
1996 was the first year they offered 4WABS, so depending on when your truck was manufactured, it may or may not have it.
If you give a dealer your VIN# they can check for you.
If you have a 2.3 or 3.0, it is RABS only, if you have the 4.0L it has 4WABS.
jandm
ford
thanks i will call the dealer today.
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
IT's easy enough to look underneath and see if there is a cable in clips that runs along wiht the caliper brake hose.
Failing that the ABS pump is kinda obvious uder the hood of a '95-up Ranger.
And for the record I've seen 1994 rangers with factory 4WABS.
On the 4.0 supercabs I believe it was standard starting in 1995.
BTW, Ihave 1995-97 beams on ym truck to get the two piston calipers
and I had an absolute devil of a time getting a NON-ABS Left front brake
hose when I was putting my Ranger together.
there simply was NO LISTING for a non-ABS '95 or '96 Ranger.
I finally found a listing at NAPA for a 1997 without ABS.
AD
AD
Staff online
Members online
Shran
April Truck of The Month
