Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 05-05-2009, 06:47 PM   #1
fatt_owl2.9
Junior Member
fatt_owl2.9's Avatar
Location: the salton trough, lower colorado desert, CA/sometimes the Inland Empire.
Vehicle Year: 87
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: puttering around the countryside
fatt_owl2.9 is on a distinguished road
Default aftermarket temp gauge problem
the previous owner of my truck installed Sunpro coolant temp and oil pressure gauges. They're in a neat little pod under the dash right in front of the shifter boot. They've always worked great, but a couple weeks ago the temp gauge just stopped working. I thought maybe it was an issue with the thermostat. So I replaced the thermostat, and that didn't fix it. The oil pressure gauge still works fine, so the only thing I can deduct is there's an issue with the sending unit for the temp gauge. I live in Palm Springs, CA and brutal heat is upon us, I really don't want to be without my temp gauge. Do any of you guys have a lot of experience with Sunpro gauges? Or any idea what could be causing this? Thanks in advance for any suggestions.
-the fat owl
__________________
"hold my drink, bitch" - Rick James
fatt_owl2.9 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 05-05-2009, 07:59 PM   #2
fordwheelinman
fordwheelinman's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Explorer 4 door
I use this vehicle for: DD
fordwheelinman is on a distinguished road
Default
does the dash gauge not work?
__________________
*1994 Explorer 4 door- 4L ohv, FACTORY M5OD, working electric 4x4, new DD, awaiting 31x10.50's on black stock wheels
*1978 F150- 4x4, 400 V8, C6, 31x10.50x15 adventuro all terrains on stock steels-towing, 33x12.50x15 BFG All terrain on mag 15x8.5, custom in bed gooseneck, waiting on custom flatbed
*1989 Bronco II-Converted 4x2 to 4x4 with 2.9 bored .060, ported/polished heads, port matched manifolds, a4ld, man 1350, D28/7.5 4.10's in both L/S in rear: waiting on motor
fordwheelinman is offline   Reply With Quote
Old 05-05-2009, 08:07 PM   #3
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
Those little sunpro and autoguage sets of mini-guages typically have
MECHANICAL temp and pressure guages and the temp guages is driven
by a capillary tube that runs to a mechanical sensor on the engine.
If the fluid leaks out it's dead, and dead forever...
I just robbed the pressure guage out of one of those mini guage sets
some idiot CUT the sealed tube for the temp guage.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 05-05-2009, 09:24 PM   #4
fatt_owl2.9
Junior Member
Vehicle Year: 87
Vehicle Make: Ford
Default
yes the original factory temp gauge still works, which is certainly better than nothing. But I got so used to my other gauge, and felt it was a better indicator of my engine's temperature.
The sending unit for the gauge was hacked into my upper radiator hose, and I can't understand how a loss of coolant could cause the sender to take a dump. So do they offer spare parts, do you think I could get a new sender and see if that works? I suppose I could contact Sunpro and see what they think....
__________________
Old 05-09-2009, 10:57 PM   #5
93Ranger4x4
93Ranger4x4's Avatar
Vehicle Year: 93, 96
Vehicle Make: Ford
I use this vehicle for: Just about everything
93Ranger4x4 is on a distinguished road
Send a message via AIM to 93Ranger4x4
Default
wait wait wait, its "hacked" into your upper radiator hose???
If i were you, i would just goto an auto parts store and pick up a new temp gauge, and find where your factory coolant sending unit is, drain your coolant, remove the factory sending unit, and put one of the adapters in there, run your tube the same way it was ran before, and thread it into the adapter and you should be good to go. I just recently did this myself, still tryin to get the oil pressure gauge hooked up(Ford picked a wonderful spot to put that bad boy >:( ).
__________________
93 Ford Ranger Splash 4x4 (blown up,again)3.0 5spd, Too much to list
96 Ranger 4.0 5spd 4wd stock for now...(Project: Purple Haze)
01 Ford F-350 4x4 7.3l powerstroke
93Ranger4x4 is offline   Reply With Quote
Old 05-11-2009, 11:24 AM   #6
fatt_owl2.9
Junior Member
Vehicle Year: 87
Vehicle Make: Ford
Default
lol no I didn't hack it, the previous owner did. So I can get a new sunpro gauge, get an adapter, and run it out of the factory temp sending unit? I'm kinda confused...
__________________
Old 05-11-2009, 08:19 PM   #7
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Vehicle Year: 2009
Vehicle Make: Chevy
Vehicle Model: 2500HD
I use this vehicle for: Shaming Sports Cars
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
I put a T in for the oil PSI guage, but just disconnected the temp sensor. My oil guage still works in the dash, but the temp is always on cold.
Best investment yet!
Quote:
You can disconnect the sending unit for the factory sensor. The guage in the dash will read cold, but the computer uses another sensor to actually read off of. There is a dedicated sending unit for the guage only.
Unthread it from the block, thread in your new sending unit attached to the guage and voila.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop.
Jspafford is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
