Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 05-11-2009, 01:15 AM   #1
wesleyn
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger
wesleyn is on a distinguished road
Default 3.0 Miss/Stumble. Out of ideas and money
I have a 2003 Ford Ranger 3.0 automatic with 70k that has a stumble/miss at all RPM's. I have replaced the IAC, fuel filter, motorcraft plugs and decent wires, TPS, and cleaned the MAF. I do not see any vacuum leaks. I am at whits end with this, and now totally broke from buying parts. I dont know what else it can be. Even tried fuel dry and seafoam. Nothing is helping. Can anyone offer suggestions or ideas? Anything prone to failure or that I should check? The 2003 3.0 does not have the DPFE from what I can tell, so that rules that part out. I would greatly appreciate any help. Thanks!
wesleyn is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 05-11-2009, 10:09 AM   #2
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
Make / Models : Model/Build Years:
FORD / RANGER 2000-2003
FORD / TAURUS 2000-2003
MERCURY / SABLE 2000-2003
Service Bulletin Number : 052212
NHTSA Item Number : 10018746
Summary Description :
BUCK/JERK AND MISS DURING DRIVE CYCLE ABOVE 3000 RPM - NO DTC - 3.0L 2V GAS AND FFV ENGINE. *TT
I suggest a trip to the dealer to see if a PCM reflash is available for your concern. The TSB search summary lacks detail, but it "appears" to be documented, so Ford will have a "fix".
Earl43P is offline   Reply With Quote
Old 05-11-2009, 10:51 AM   #3
TomB1269
TomB1269's Avatar
Vehicle Year: 2002, 2005, & 2
Vehicle Make: All Fords
Vehicle Model: Ranger Edge '02, Freestar '06 & The newest '05 F150 FX4 SCrew
I use this vehicle for: Original Daily Driver/New DD
TomB1269 is on a distinguished road
Default Mis-Fire over 3000 RPMS
If you are having this "BUCK/JERK AND MISS DURING DRIVE CYCLE ABOVE 3000 RPM - NO DTC - 3.0L 2V GAS AND FFV ENGINE. *TT" as well as what sounds like belt sqeal that clears as the engine warms, and sounds as if it coming from the firewall or under the truck by can not pin down an exact location; it is a clear sign of Syncronizer shaft failure and common for it to start showing signs around your milage. I ran thru an issue were just after doing a full tune-up (Plugs, wires, filters, ETC) the truck showed a small miss, which progressed to a miss when the engine was cold over 4000 rpm and as it warmed just over 3000 rpms. It was the syncro shaft. The TSB states that the Cam Position sensor does not monitor faults over 2500 rpm (hense no CEL, no codes). The only test is to read to signal from the EGR valve, if it is cycling or 150 times to its limti of 1050 this points to a syncro shaft problem.
The shaft can be obtained for NAPA, or like (Autozone was not able to tell me they had it) for just under $200. You will need to be sure an locate the alignment tool discussed in the chilton/haynes manual for proper re-install.
TomB1269 is offline   Reply With Quote
Old 05-11-2009, 01:14 PM   #4
Toms01PSD
Toms01PSD's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: F-250
I use this vehicle for: Everyday use
Toms01PSD is a name known to allToms01PSD is a name known to allToms01PSD is a name known to allToms01PSD is a name known to allToms01PSD is a name known to allToms01PSD is a name known to all
Default
Or you can get it from the dealership for $178.00. That's including 7% sales tax in my state, and they let you borrow the alignment tool for free, atleast mine did.
__________________
Quote:
Originally Posted by Will View Post
What is that, a 351? You don't need a chain hoist for anything that small. Just get in there and man-handle that bitch. Punch its valve covers in and then bite it on the EGR valve.
Toms01PSD is offline   Reply With Quote
Old 05-24-2009, 07:44 PM   #5
jschamberlin
Vehicle Year: 2000
Vehicle Make: Ford
jschamberlin is on a distinguished road
Default Ford 3.0L issues
For those suffering mysterious misfire issues in the 3.0L (gas or FFV), I'll pass along this bit of information - run compression checks. My 2000 Ford Ranger 3.0L FFV 5spd had a misfire in cylinder 6 - I went through all the usual suspects (a couple of times), but the code kept coming back. I finally learned from a Ford Technician that the engine was prone to carbon buildup in the cylinder head, and he recommended removing the head for a thorough cleaning. Once I got it off, I found that cylinder 6 had sucked the intake valve approx. halfway through the seat, and the head was cracked between the spark plug opening and intake valve. In addition, I also found 3 other intake valves that were fried. So in my case, it cost me for 2 new heads and an overhaul of the rest of the engine (much cheaper to do yourself if you have the time, patience and repair manual!) - all parts from Rock Auto online. Mine is now running like a champ....however, my girlfriend's dad's 2003 Ford Ranger 3.0L (standard gas engine) automatic trans. went caput. It acted like the timing chain had slipped, and he had low compression on cylinders 4 and 5 (both indicated by the PCM as having a misfire). After getting the engine stripped down, we found that intake valves on cylinders 4 and 5 were eating into the head (just like mine on cylinder 6, only without the crack), and cylinder 6 intake valve wasn't far behind. So far we've been able to establish that both my 2000 3.0L FFV and his 2003 3.0L gas engine both came from the one factory. While it could be coincidence, it seems strange that both 3.0L engines had similar (dare I say same) problems in the same cylinder head at roughly the same mileage (I compared his to when my issue first started, and it's almost exact to the mile).
jschamberlin is offline   Reply With Quote
Old 06-04-2009, 11:35 PM   #6
etemplet
Vehicle Year: 2000
Vehicle Make: Ford
etemplet is on a distinguished road
Default
Roger that. My son's...which is now "my" 2000 Ranger has 280K miles on it. We replaced the heads last year (rebuilt heads because the valves sucked into the heads)40K miles later Number 1, 4, &6 are at 25 to 50PSI compression. We are going to do a leak down to see what's going on. We've never replaced the timing chain so...maybe the timing is an issue but I'm not so sure. I know it's allot of miles but I've got experience with high mileage engines. My Ranger 2.3 has 400k miles on in and all of the cylinders have 180PSI with very little variance. I've never had the valve cover off the engine because I can't get it off. I tried once about 12 years ago but gave up because it hit the upper portion of the fire wall and wouldn't come off.
Anyway, we'll see what happens with the leak down test. I'm curious and eager to solve this problem once and for all. Perhaps I should rebuild the whole engine but this is really a spare vehicle and yard truck.
Take Care and Good Luck !
__________________
Cheers,
Gene
etemplet is offline   Reply With Quote
Old 11-01-2009, 05:34 PM   #7
lucky14
lucky14's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
I use this vehicle for: When I want a better ride than my jeep
lucky14 is on a distinguished road
Default
Does anyone have a picture of the syncro. shaft and CKP sensor?
__________________
ASE Master Automotive/Coll. Tech L1/X1
2001 Ford Ranger 3.0, 5spd, 4x4 4dr Alu DS, BFG AT's, flowmaster
1997 Jeep TJ 4 1/2 lift, 33's lots of mods
1987 Buick Grand National- 20 psi of boost!
lucky14 is offline   Reply With Quote
Old 11-02-2009, 06:15 PM   #8
jmorleybdps
jmorleybdps's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: Ranger 3.0 V6 FlexFuel
I use this vehicle for: Personal
jmorleybdps is on a distinguished road
Default Similar problem
Hey guys,
New member here just starting to really learn about my truck. I have a haynes repair manual and some basic mechanical knowledge. I can see through searching that this topic is well-documented, but I thought maybe I was missing something simple in my symptoms that a more experienced mechanic might pick up on. I don't think it's the problem quoted above because my misfire is at low revs.
My 2001 3.0 V6 FlexFuel Automatic Ranger with 140,000 miles on it sat for two weeks in heavy rain. I had never had a misfire issue before that. When I started it up it had a rough idle and continued to misfire in the low revs (up to about 2000) but seemed to smooth out as I reached higher revs. The problem is growing worse and it misses consistently at low revs and with small throttle applications, but seems to run a little smoother with a leadfoot and higher revs.
I changed the spark plugs a few months before this started happening and didn't have any problems with them, so I don't know if those would "go bad" after working fine for months.
I changed the fuel filter when the mis first appeared and that smoothed it out for a day until I drove it through a rainstorm and the misfire re-appeared, then disappearing again when it dried out.
Today I thoroughly cleaned the MAF for the first time. It was filthy and after cleaning it the truck fired up, purred beautifully and ran great for 5 minutes at all different RPM's, then the misfire came roaring back same as it was before.
I guess I'd just like to know if this sounds like something you've seen before and if I should buy a new coil, plug wires and plugs, or should I check compression.
I did get one code out of it for a misfire on cylinder 5, but that has since gone away and has not reappeared, even though the misfire is still clearly there.
Thanks for giving this a look!
Jon
jmorleybdps is offline   Reply With Quote
Old 11-02-2009, 06:27 PM   #9
graff104
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Everything
graff104 is on a distinguished road
Default
If it is on just cylinder 5 could be a sticky injector.
graff104 is offline   Reply With Quote
Old 11-02-2009, 06:30 PM   #10
jmorleybdps
Vehicle Year: 2001
Vehicle Make: Ford
Default
Is there a good way to test that?
Thanks!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
