Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 06-05-2009, 04:08 PM   #1
MUDDING B-3000
MUDDING B-3000's Avatar
Vehicle Year: 1997 , 1992
Vehicle Make: Ford , Ford
Vehicle Model: F-350 , Ranger
I use this vehicle for: daily driver and weekend warrior!
MUDDING B-3000 is on a distinguished road
Default clutch interlock bypass?
alright well ive search the whole site an read all the bypass threads an still cant figure out how to bypass the clutch switch on my truck. it says theres 2 wires at the switch but my 1992 ford ranger 4 L manual, has 6 wires (red/lt Blue, pink, green, lite blue, white/ red, blue/yellow) what wires do i cross to bypass this?
the small wire on the top of the starter relay i was checking continuity to find where that wire goes an i found that it goes to a connector in the cab but its a red/white wire not the red/lt blue thats on the relay an then there is not wiring coming out of that connecter where the red/white wire goes in? so am i missing something that wont let my truck start?. or to make things easier how do i wire up a 2 way toggle switch to that post on the relay so i can manual start the starter?
__________________
1997 Ford F 350 xlt 7.3L Powerstroke
1992 Ford Ranger 4x4 Full Width D44 an 9", 5.5 EB coils, custom extended RA's, custom leaf spring pack soon will be swaping in 5L .
MUDDING B-3000 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 06-05-2009, 04:30 PM   #2
martin
Vehicle Year: 1984 1991
Vehicle Make: ford
Vehicle Model: b2 explorer
martin is just really nicemartin is just really nicemartin is just really nicemartin is just really nice
Default
pink, red/light blue.
martin is offline   Reply With Quote
Old 06-05-2009, 04:47 PM   #3
MUDDING B-3000
Default
see i just used a little piece of wire an pushed it into the slot for the pink an reb/lite blue an tried an it did not work?
like when i turn the key over nothing happens but if i jump the starter relay out the motor kicks over so what would be wrong?
__________________
Old 06-05-2009, 05:42 PM   #4
snake
snake's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: The mighty Ranger
I use this vehicle for: cruising for chicks
snake is on a distinguished road
Default
Does your truck have a PATS system (theft light)? If so, the light should be on steady when the key is on before it can crank. Blinking fast would indicate a malfunction and no starter... Still could be the clutch switch, or even the key switch.
__________________
2002 XLT in wedgewood blue, 4.0 auto, 4 doors (no waiting) MP3, 3:55 limited slip rear, payload package, factory installed trailer hitch, side step bars. Built 7/31/2002, shipped 8/19/2002, purchased 9/25/2002 sold 8/2011.
2011 F-150 crewcab ecoboost twin turbo. Purchased 7/13/2011
snake is offline   Reply With Quote
Old 06-05-2009, 05:50 PM   #5
swamprat
swamprat's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: dripping oil in driveway
swamprat is on a distinguished road
Default
I belive I crossed different wires. I will check for you. after dinner
I guess on an 89 BII the wires are different colors. I crossed the pink wires on both sides.
__________________
Only a Southerner still calls that domestic conflagration of the 1860s, "The War of Northern Aggression"
swamprat is offline   Reply With Quote
Old 06-05-2009, 06:07 PM   #6
MUDDING B-3000
Default
snake where is the theft device located? i highly doubt the truck has it cuz it was pretty much gutted when i bought it so. an swamprat thanks for looking
__________________
Old 06-05-2009, 11:17 PM   #7
warrior24
warrior24's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger SuperCab
warrior24 is on a distinguished road
Default
cant you just zip tie the switch down?
__________________
I'm not asking you to fix it, just please let me get it back to the way it was before I touched it.
The Technician Prayer
warrior24 is offline   Reply With Quote
Old 06-06-2009, 12:10 AM   #8
Combs Customs
Combs Customs's Avatar
Vehicle Year: 1993 / 1993 /19
Vehicle Make: Ford / Ford / F
Vehicle Model: Explorer / Explorer / Ranger
I use this vehicle for: Trails / Rock Crawling / DD
Combs Customs is on a distinguished road
Send a message via AIM to Combs Customs
Default
Or, grab a module out of an automatic truck. Plugs right in.
__________________
Suggy Build
'93 Ex Title, 302 / NP435 / NP203-205 Doubler / HP KP D60 - 10.25 / 39.5 Iroks
Combs Customs is offline   Reply With Quote
Old 06-06-2009, 09:37 AM   #9
MUDDING B-3000
Default
ya i just grab one of those caps from an automatic an put it in but my truck still wont turn over? so i think im just goin to rig up a toggle switch to start it.
__________________
Old 06-06-2009, 10:21 AM   #10
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
IF that is the case the circuit is interrupted elsewhere.
This truck isn't an "in progress" conversion from an automatic is it?
The starter circuit is what an electrical technician would call
"daisy chain" wiring.
the clutch interlock is one of THREE switches that
turn on the starter relay
there's the obvious ignition switch, there's the clutch interlock switch
and there's the neutral safety switch.
And even though a manual trans truck doesn't HAVE a Neutral Safety Switch
it DOES have part of the wiring for it and a Jumper, a little loop of wire, where the transmission harness connects to the engine bay harness.
Look on the plastic inner fender back below the master cylinder.
There are two connectors there, one is to the "Frame harness"
on a 1993-94 there are two smaller ones that goes to the
engine guage sensors AND to the transmission there should
be a little loop of red wire with a blue stripe off the back of
one of those smaller connectors.
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
