- Dec 14, 2007
I just bought my 4th. Ranger, an 08 with 2.3, 5 spd manual.
I'm going to throw a hitch on it, leaning towards a class III bolt on type. I know it's only rated for 1500 lbs, which is fine...I'll never tow anything over that because I have an F250 for my heavier towing duties. I just want to throw a class III on it for peace of mind. My trailer would not be level if I were to use a ball on the bumper, it stick up to high so...it has to come down...thus, another reason for installing a hitch.
My question is, what kind of hitch did some of you throw on your trucks? I've got concerns about access to my spare tire (which is the cheesie compact). Also, the frame is (for the lack of a better term) kinda "bent" down around the spare tire area appearing to give it room to fit under there. I'm concerned that if I buy a class III hitch, the "bend" in the frame around the spare tire might interfere with a hitch bolting up correctly because it sticks down below the bottom of the frame.
Any input on this would be appreciated. I can take pics for reference is needed.
