429 or 460 big block
95Splash460
I have a 1995 Ford Ranger splash extended cab with a 3.0 v6 and a 5 speed manual tranny. How hard is it going to be to put a big block in this car I am going to strip it so all unwanted stuff is gone. So I am starting basically from scratch am I going to be able to fit the engine?
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
TRS Banner 2012-2015
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Frank The Tank
43
South
Have you ever seen a SOHC 427? Now THAT is cool.
used heads for them are 6 grand!!!
I think he should forget the big block all together (you won't be able to plant the rears without 3k lbs of molten lead poured in the bed)
and just buy a crate 427 aluminum small block with a blower, huffing nos, and a warranty......... (that would be cheaper than our last two ideas)
Frank
fx2prerunner
2
Newfoundland, Canada
ford
5.0L
ahhh I think the question was will it fit? I know there are some big block rangers going around, there is a gen2 in my town with a 460 so it can fit, I dont know how much work it will be. I think a 429 ranger would be pretty cool though.
superdave1984
24
KY
Yes there are some on this board that have done it. Do you already have the engine and tranny? If not I have a 429 (not boss) and C-6 that are in my way.
Bruce
Southwest Missouri
4.0 SOHC
429 and 460 is the same block...there is a guy over at TRS that has a 545 in his ranger.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
A 460 is a 429 with (help me with the math) 30-ish more cubes.
It's a great motor. Really, it's the same motor (in concept--valve arrangement I mean) as a 454, except a 454 has more stroke and a 460 has more bore. The 454 lasted longer in production and the 460 was replaced with the modular motor 6.8--which I also like--more actually.
But go for the cubes is my main point.
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Frank
Why is this an issue :icon_rofl: Anyone who puts a big block in a Ranger doesn't have traction at the top of their list :icon_hornsup:
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
The difference between a 429 and 460 is the crank and wrist pin location on the pistons.
The 429 is my choice simply because of the fact that it will be a better revving engine because of the shorter stroke.
redneckracerx
Solid Axle Swap
3
Dirty Jersey
first gens
Ford right?
anything but stock
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
That's not a fact, it's a theory. It's not that much more of a stroke so the difference is negligable unless you are shooting for 7,000rpm--and even then I think a balanced 460 could do it. I could also theorize that a 429 has to spin faster to get the same air into it as a 460 and the 3" main bearings are are making more friction and wasting power making the 460 better even at the same flow rate.
The only fact is that the 460 is going to make 25 more ft# with the same heads on it because it has a larger displacement, it will have it's air going fast at a lower rpm (although will it be noticable with such a small difference in stroke?) which makes a carberator work better and fills the cylinders more completely at low revs and that a basically stock 460 head with a camshaft in the 230* @ .050 range will pull to 5,500rpm while keeping enough low rpm grunt to light up the tires with a 3.0 axle in a '64 Galaxie.
BigBlockRanger
545 (8.9L)
I don't know, from a stop sign my 545 (read: long 4.5" stroke) went from idle to 7000 almost quicker than I could yank the shifter into second. Plenty damn quick for me. lol
:dntknw:
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
