Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 07-09-2009, 07:51 AM   #1
wayneg
Vehicle Year: 2005
Vehicle Make: Ford
Vehicle Model: Ranger
wayneg is on a distinguished road
Default How to Flush Radiator
I just joined this forum so please let me know if this question should be posted elsewhere.
Anyway, I have a 2005 Ranger with a 2.3 engine and auto trans. Just turned 30,000 miles. I decided to flush and refill the radiator, and have these questions. One: there appears to be no radiator cap. I'm used to sticking a hose in the cap hole and running fresh water thru for a bit after draining, but I obviously can't do that here. Do I instead pull off the top hose and flush thru there? Second question: do I pull off the bottom hose to drain or is there a drain plug accessible once I remove the plastic cover/protector that's held in place by four plastic plugs?
Any and all advice/guidance will be greatly appreciated!
wayneg is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-09-2009, 08:24 AM   #2
baxtej44
baxtej44's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: General driving
baxtej44 is on a distinguished road
Default
i don't know about your specific vehicle, but alot of them have some drain plug like a wing nut orsomething of the sort at the bottom of the radiator... you have to have a radiator cap don't you?!
__________________
Photobucket:
http://s629.photobucket.com/albums/uu14/baxtej44/
baxtej44 is offline   Reply With Quote
Old 07-09-2009, 08:35 AM   #3
ForOffRoadDriving
ForOffRoadDriving's Avatar
Vehicle Year: 1994
Vehicle Make: FORD
Vehicle Model: RANGER
I use this vehicle for: EVERYTHING A RANGER CAN DO, AND LOTS OF THINGS IT SHOULDN'T
ForOffRoadDriving has a spectacular aura aboutForOffRoadDriving has a spectacular aura about
Default
your radiator cap is probably on the over flow bottle. you can either flush from the upper hose or pull a heater hose and flush that way (this way you can make sure you get all the old coolant out of the heater core. there also should be a drain on the passenger side of the radiator. what are you planning to put back in it for coolant, good ole green stuff or the extended life stuff?
__________________
1994 Ranger 4X2 Off Road, Built Not Bought!
http://www.therangerstation.com/foru...ad.php?t=37621
ForOffRoadDriving is offline   Reply With Quote
Old 07-09-2009, 09:08 AM   #4
wayneg
Vehicle Year: 2005
Vehicle Make: Ford
Default
I was going to put in the yellow/golden extended life stuff, since that's what it was delivered with. Would the old-time green antifreeze be a better choice?
Old 07-09-2009, 09:11 AM   #5
shadetree
shadetree's Avatar
Vehicle Year: 1994
Vehicle Make: Explorer Sport
I use this vehicle for: Work
shadetree is on a distinguished road
Default
Pull the top and bottom hose to flush the radiator. Remove the thermostat and flush the block. Some heaters have a control valve. Remove the hoses at the heater connections if your's has the valve.shady
__________________
Bawney Fwank/Bobby Rush 2012.
shadetree is offline   Reply With Quote
Old 07-09-2009, 09:13 AM   #6
wayneg
Vehicle Year: 2005
Vehicle Make: Ford
Default
Also, I guess my "radiator cap" is on the coolant overflow bottle. I just took a look at that cap and it's marked 16psi, so I guess that's it. I'm just used to the cap being on the physical radiator itself, which is not the case here.
Old 07-09-2009, 10:31 AM   #7
exbass94
exbass94's Avatar
Vehicle Year: 2006, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Default
Quote:
Use Zerex G-05. It's the same gold extended life stuff that's in it. Regular green would not be better.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 63k miles
1994 Ford Explorer Sport 2-dr 4x4, 203k miles
1992 Honda Accord EX, 182k miles
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek, 33k miles (wife's)
exbass94 is offline   Reply With Quote
Old 07-09-2009, 01:19 PM   #8
JohnnyO
Moderator Emeritus
JohnnyO's Avatar
Vehicle Year: 2008
Vehicle Make: Ford
Vehicle Model: Sport Trac
I use this vehicle for: Daily Driver
JohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to behold
Default
I would put the extended life stuff back in. Unless you get the antifreeze that's compatible with everything, plain ol' green stuff should not be mixed with the gold/yellow extended life stuff unless you flush the system REALLY REALLY well. IMO not worth the effort so I get the mix-with-anything stuff.
On most cars and trucks, as long as I can reach it easily, I just pull off the lower rad hose to drain it, much faster that way. Stick it back on, don't bother with the clamp, fill with water, run, drain, and repeat. Ditto the upper hose to fill the system. I don't bother removing the thermostat.
__________________
'08 Sport Trac, custom 2.5" single exhaust with Flowmaster DBX muffler, K&N, Firestone Destination A/T's, Truxxx 2.5"/1.5" strut lift.
JohnnyO is offline   Reply With Quote
Old 08-10-2009, 08:23 PM   #9
dmt
Junior Member
Vehicle Year: 2004
Vehicle Make: Ford
dmt is on a distinguished road
Default
I was just getting ready to post this same question. WayneG let me know how this worked out for you.
Thanks.
dmt is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Radiator Flushing 94RangerMike General Discussions 5 11-12-2010 04:19 PM
Radiator Flush lskrogers Heating & Air Conditioning 3 10-08-2009 12:37 PM
collapsed radiator hose and rusty radiator??? jodom15sc General Discussions 12 04-02-2009 11:02 AM
Radiator - Flush or replace? JTH1972 General Discussions 4 01-18-2009 02:47 AM
Radiator for an 83 2.3 Loanranger 4-Cylinder (2000 & Older) 1 10-22-2007 12:02 AM
1999-2018 / 959 Media LLC / All Rights Reserved
