Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-12-2009, 02:15 PM   #1
JTH1972
Vehicle Year: 1986
Vehicle Make: Ford Ranger
I use this vehicle for: Work and Play
JTH1972 is on a distinguished road
Default No fuel filter???
Okay, I'm lost... I tried changing the fuel filter on my '86 a little while ago but I can't find it! I know it should be on the inside frame rail on the drivers side, but I've looked through there with a flashlight and I've found nothing. Only filter I can see is the canister one between the fuel tank and the fuel pump on the frame rail.
Am I just blind or could have someone done a modification in the vehicles life and removed the filter?
__________________
1986 Ford Ranger 2.9L / 4X4 / A4LD
"...In a world where most men seem to spend their lives doing things they hate, my fishing is at once an endless source of delight and act of small rebellion." - Robert Traver - Testament of a Fisherman
Tattooed people are art collectors that bring their gallery with them.
JTH1972 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 07-12-2009, 02:25 PM   #2
lost86broncoii
lost86broncoii's Avatar
Vehicle Year: 1986 1986 199
Vehicle Make: Ford
Vehicle Model: Bronco ii Ranger Explorer
lost86broncoii is on a distinguished road
Default
i got an 86 bronco ii 2.9 auto 4x4 and i just replaced mine, the filter is in the black canister, use an oil filter wrench to unscrew if on tight, mine was just hand tight. on my truck it was located about 6 inches behind the transfer case skid plate. Be careful not too over tighten it or you'll bust that cheap little o-ring that seals it up.
lost86broncoii is offline   Reply With Quote
Old 07-12-2009, 02:27 PM   #3
JTH1972
Vehicle Year: 1986
Default
Quote:
Where mine is sitting I have to remove the skid plate to get at it, but I know what you're talking about. So possibly no inline filter on this truck then?
__________________
Old 07-12-2009, 02:46 PM   #4
lost86broncoii
Vehicle Make: Ford
Default
well some one could have put one on it but i think you would have seen it on the line some where? i had an 1990 f150 that the guy who had it before me put after market inline filters on and some weird valves to shut off gas from under the drivers seat it gave me all kinds of problems...
But yeah on your truck i am pretty sure it has the same drop in fuel filter, just unscrew the bottom of that black canister and your filter will be right inside that and it has two little rubber O-rings one for the canister and one for the filter.
just changed mine last week and had the big O-ring bust cause i tightened it down too much, got burns all up and down my arm from some fuel system cleaner i had in it... learned my lesson real quick.
Old 07-12-2009, 02:51 PM   #5
lost86broncoii
Vehicle Make: Ford
Default
just checked my haynes manual some "later models" didn't say years do have an inline filter, but which models and when are beyond my knowledge. i have had two 86's and both had the canister filters. hope it helps.
Old 07-12-2009, 06:06 PM   #6
RustedRanger
RustedRanger's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Everyday driver
RustedRanger will become famous soon enough
Default
My 87 has the cannister and when I took it apart it didnt have a filter in it. I had to take the skid plate off as well as the fuel lines and remove the whole thing to get it apart. The O ring that came with the new filter(which didn't fit) was all screwed up and wouldn't lay flat to get it back together so I took some advice from a guy at my uncles shop and soaked the O ring in really hot water then put a thin layer of grease in the grove it goes in and that held it in place to get it back together. The real filter for mine was in the frame rail to the drivers side of the engine.
RustedRanger is offline   Reply With Quote
Old 07-12-2009, 07:20 PM   #7
IMenriched
IMenriched's Avatar
Vehicle Year: 1986 02'
Vehicle Make: ford
Vehicle Model: ranger f150 fx4
I use this vehicle for: exercise and DD & hauling college kids stuff
IMenriched is on a distinguished road
Default
Yeap, My 86' does not have the "in-line" filter,near the engine...just the cansiter, back by the t-case.
and double plus, with being gentle with it.
It was explained to myself that late 86's and early 87's hold the possibility if having both canister and in-line fuel filters.
__________________
IMenRiched
By the power of Lord Jesus
2 are willing to die for you.
one is a soldier, but the 1st was Jesus Christ
~few appreciate either~
IMenriched is offline   Reply With Quote
Old 07-13-2009, 04:49 PM   #8
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
On an '86 and ONLY an '86 EFI (well.. '85 2.3EFI's have it too)
the filter is inside the black cannister.
'87-88 have the cannister but it's got nothing in it.
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 07-13-2009, 09:36 PM   #9
fsmall23
Vehicle Year: 1988
Vehicle Make: Ford
fsmall23 is on a distinguished road
Default
I have an 87, and there is a inline fuel filter up around the front wheel on the driver side---in the frame. I also have one of those bowls, but when i took it apart there wasn't any filter nor would any filter specified fit.
fsmall23 is offline   Reply With Quote
Old 07-14-2009, 07:19 AM   #10
IMenriched
IMenriched's Avatar
Vehicle Make: ford
Default
Thanks Allan for clearing up the vintage deal, apparently I was misinformed.
Yes, Like Allan stated...straight from the guru himself (that is a compliment Allan) , 87's will not have a filter in the cansiter near the t-case. Now the canister will still be there, just no filter in it. Ford now calls it a reservoir to draw fuel from on when heavy throttle situations and in those special cases where one has dual tanks to aid in when switching over from 1 tank to another if so equipt. If dual tanks are invovled then there will be a swtiching soleniod there as well.
Ususally, if there is a filter in this canister, the bottom side that screws in place, is shorter, and the 87's and newer, used a taller version and filter would not fit into it.
__________________
IMenRiched
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My temporary fuel filter housing fix Chic N Stew General Discussions 16 03-26-2013 08:30 AM
How to Change Your Fuel Filter zedmaster 4-Cylinder (2000 & Older) 27 06-26-2012 10:15 AM
from old 4.0 swap MrE_Powers 'Other' Engine Conversions 5 04-26-2011 09:59 PM
'86 BII 2.9 Canister fuel filter... mjonesjr 2.9 Liter Forum 3 03-24-2008 01:59 PM
HOW TO: Setup Nitrous Oxide on a daily driver. rocket5979 Forced Induction 3 03-16-2008 02:31 PM
1999-2018 / 959 Media LLC / All Rights Reserved
