Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-02-2009, 12:52 AM   #1
traviss76
traviss76 is on a distinguished road
Default Ranger A/C Orifice tube.
This filter known as the orifice tube gets clogged more often then I thought. This is the second truck in which this tube was clogged with black goo and some cat hair??? Not really cat hair but dude that would be weird. The tube filter is usually inside the bottom line of the evaporator. Just inside the coupling. Make sure it goes in by the arrow indicator. The smaller filter pointed at the evaporator. I blow the old oil out with compressed air and add new oil around 8 ounces. About two cans of r134 cools good. Make sure if replacing the hose assembly to save the old one. Oil usually forms around leaks.
traviss76 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 08-02-2009, 08:39 PM   #2
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
You likely have compressor issues if there's black goo in there (known as "Black Death"). The orifice tube is not designed as a filter for the whole system.
You'll need to flush the entire system out (except the condenser, that should be replaced, as you can't effectively flush it out due to it's serpentine-flow design), replace your compressor, orifice tube and accumulator, and then recharge the system with the proper amounts of oil and R134a.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 08-07-2009, 10:59 PM   #3
warrior24
warrior24's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
Vehicle Model: Ranger SuperCab
warrior24 is on a distinguished road
Default
Yup 4x4 is right it is black death "cancer'. I saw the same problem on my moms 93 Taurus.
__________________
I'm not asking you to fix it, just please let me get it back to the way it was before I touched it.
The Technician Prayer
warrior24 is offline   Reply With Quote
Old 02-11-2010, 09:28 PM   #4
laclabb
laclabb is on a distinguished road
Default
Quote:
Originally Posted by traviss76 View Post
This filter known as the 4-seasons a/c orifice tube gets clogged more often then I thought. This is the second truck in which this tube was clogged with black goo and some cat hair??? Not really cat hair but dude that would be weird. The tube filter is usually inside the bottom line of the evaporator. Just inside the coupling. Make sure it goes in by the arrow indicator. The smaller filter pointed at the evaporator. I blow the old oil out with compressed air and add new oil around 8 ounces. About two cans of r134 cools good. Make sure if replacing the hose assembly to save the old one. Oil usually forms around leaks.
I agree. From the way your story goes, I guess the main root for those symptoms is your compressor.
laclabb is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Replace original orifice tube w/ "red"? CraigK Heating & Air Conditioning 6 08-18-2008 10:39 PM
No A/C Function on a 1993 Ranger Splash Tom1993 Heating & Air Conditioning 12 06-09-2008 01:03 PM
Sad to say, The Ranger is now for sale Shoeboy General Discussions 17 06-06-2008 09:04 PM
RumbleGoat Racing Ford Ranger #7314 Dzrtcj7 General Discussions 32 04-04-2008 06:53 PM
Roll Cage info/pics CheapThrillB2 General Discussions 7 12-08-2007 02:27 AM
1999-2018 / 959 Media LLC / All Rights Reserved
