Catalytic Converter Removal
Featured Build Threads
Status
Not open for further replies.
JohnnyO
Large Member
TRS Event Staff
💻 TRS Socials
Pittsburgh
PA - USA
Vehicle
Drive
2.3L EcoBoost
2.0"
"220, 221, whatever it takes."
Removing the catalytic converter(s) is illegal. Regardless of the emissions laws in your particular state, it is against Federal law. The Ranger Station does not endorse or recommend removing the catalytic converter. Threads or posts advising removal of the catalytic converter may be locked or removed.
1. It is against the law.
2. The engine computer is set up to run with the cat, so if you remove it you may get a CEL, code, whatever, and that can mess up other things that the computer controls.
3. The only way it may be even remotely legal to remove it would be on an off-road-only vehicle that is never driven on public roads.
4. If you want it loud, it is perfectly okay to remove the muffler and resonator (if so equipped) and run a straight pipe behind the catalytic converter.
5. There are legal high-flow cats available.
6. Frankly, modern catalytic converters aren't very restrictive anyway due to gas mileage concerns.
For all those living in New York
New York has adopted California emission standards. Meaning catalytic converters have to be carb certified. You will fail a visual inspection if you replace your converter with one that's not carb certified. This includes the magnaflow universal ones. They have to state carb certified on the case.
Status
Upcoming TRS Events
Featured Ranger Based Vehicle
