Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-20-2009, 06:29 PM   #1
93Ranger4x4
93Ranger4x4's Avatar
Vehicle Year: 93, 96
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Just about everything
93Ranger4x4 is on a distinguished road
Send a message via AIM to 93Ranger4x4
Default Slave cylinder line removal
Welp, i've ran into a small snag. I'm gettin my 4.0 and tranny ready to swap into my 93, i'm replacing the clutch,pressure plate, and the slave cylinder, problem is, i can't disconnect the line on the slave cylinder. Says use the tool or screwdrivers and press the white plastic clip in and pull the line. Well, thereis NO white plastic piece in between the line and the slave cylinder. Short of just cutting the line off, anyone have some thoughts on how to remove it?
__________________
93 Ford Ranger Splash 4x4 (blown up,again)3.0 5spd, Too much to list
96 Ranger 4.0 5spd 4wd stock for now...(Project: Purple Haze)
01 Ford F-350 4x4 7.3l powerstroke
93Ranger4x4 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-20-2009, 06:55 PM   #2
atvkid4eva
atvkid4eva's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
I use this vehicle for: Offroad
atvkid4eva is on a distinguished road
Default
on my 88' i had the same problem...i ended up just removing the small pin from the master cylinder side..if you are replacing the slave you could just cut the line i suppose and get a new one with a new clip for your new slave... there are posts upon posts where people just "pop" the line free..i tried the tool and everything nothing worked. good luck.
atvkid4eva is offline   Reply With Quote
Old 08-20-2009, 07:19 PM   #3
4byRANGER
4byRANGER's Avatar
Vehicle Year: 1995
Vehicle Make: FORD
Vehicle Model: RANGER
I use this vehicle for: eveyrhting !!
4byRANGER is on a distinguished road
Default
if there is no plastic peice you should be able to fit a quick disconnect tool in there, kinda like the fuel line disconnect tool..
it has 2 c shaped collars that will fit in there
__________________
1995 ford ranger ext cab, swapped 4x4 and auto for 2wd and 5 speed!!
4byRANGER is offline   Reply With Quote
Old 08-21-2009, 11:36 AM   #4
93Ranger4x4
Vehicle Make: Ford
Default
Already tried with a fuel line tool, just isn't enough room. Guess I could unbolt the slave and pull the line through the bell housing and try the fuel line tool again. If that doesn't work then I guess I'll just have to cut the line and hope I can save the one that is already in my ranger.
__________________
Old 08-21-2009, 11:47 AM   #5
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: Wasting time
BlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant future
Default
I would go to a junkyard and grab one off another truck.
Or look for an RBV around town that you can crawl under.......
Most of the fuel line disconnects' plastic is too thick, you may have to trim it down.
__________________
I hate all RBV's. I hate my Ranger most of all.
1989 Ranger build - 4.0 swap, 7.5, Dana 35, 4.56 gearing, Lockers, 6" lift, Electric power steering
1976 Fiat 131 build
1990 BII-R.I.P.
BlackBII is offline   Reply With Quote
Old 08-21-2009, 11:55 AM   #6
cargs
cargs's Avatar
Vehicle Year: 1993
Vehicle Make: FORD
I use this vehicle for: Daily Driver
cargs is on a distinguished road
Default
we changed the slave cylinder on my dads f150 (same slave). we couldn't get the disconnect removed so we cut the line on the slave side of the connection, and removed it that way. you need to use a hacksaw blade and a lot of patience! its a bit awkward, but saves you from buying a new slave line. once you have the transmission removed you have a bit more room to get the connector off the line.
good luck.
__________________
93 Ranger, 3.0L, 5spd, manual t-case swap, MSD ignition, 31x10.5 BFG AT's, 2006 ranger bucket seats, rancho RS500 shocks, Warn 37780 "Jeep" hubs, 2007 Glasstite Raven Canopy.
http://www.cardomain.com/ride/2327329/1
cargs is offline   Reply With Quote
Old 08-21-2009, 04:41 PM   #7
93Ranger4x4
Vehicle Make: Ford
Default
Well, the 4.0 and tranny are out of the truck and in the bed of my diesel so hacking the line wouldnt be too hard. But BlackBII, what do u mean take the plastic piece from another ranger? do they just sort of slip over the line? if thats the case i can take the one off my 3.0's tranny and try it.
__________________
Old 08-21-2009, 04:55 PM   #8
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Default
Yeah, the plastic piece can be removed. It's not a solid circle, it has a slit in it so you can remove it.
__________________
1976 Fiat 131 build
1990 BII-R.I.P.
Old 08-21-2009, 05:18 PM   #9
93Ranger4x4
Vehicle Make: Ford
Default
Wow, something i did not know, hell i even looked in my Haynes manual and it didnt even say anything about being able to slide it off, then again, it never said do such and such if the clip is gone lol. Thanks! i'll probably give that a try this weekend and see if that works, i just dont wanna ruin a good line if i dont have to.
__________________
Old 08-22-2009, 10:39 AM   #10
piotrsko
piotrsko's Avatar
Vehicle Year: 83-85/86/87/88
Vehicle Make: ford
Vehicle Model: FRANKENranger homebuilt ALL ELECTRIC 220VDC up to 400 hp
I use this vehicle for: Son's anti college education
piotrsko is on a distinguished road
Default
I had a brake place make me a new one for frankenranger for about 40 dollars USD, new line, new fittings.
piotrsko is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My "new" 93 ranger sfwjesse 1983-2011 Off-Road & 4x4 Ford Ranger's 31 08-11-2009 02:47 PM
Clutch line to slave cylinder MJ'sBlkBII Transmissions 21 03-20-2009 03:48 PM
5R55E Automatic Transmission to M50D-R1 Transmission Swap mjonesjr Transmissions 15 03-10-2009 02:53 PM
slave cylinder installation ncsdaonex 4-Cylinder (2000 & Older) 3 12-27-2008 08:05 PM
broken line going into slave cylinder mccrob Transmissions 7 03-07-2008 06:56 PM
1999-2018 / 959 Media LLC / All Rights Reserved
