got a 85 ranger, and a 96 explorer with a 4.0. do i need the wiring harness under the dash too, or just the one under the hood? also will the sending unit and pump in the 96 xplorer gas tank fit in the the reanger, i have a tank from a 83 in the ranger. im planning to use aftermarket gauges,no factory.
also the cab that i got from a 85, did not have a wiring harness under the hood. just some wires and plugs hanging out the the fire wall on the driver side. i had a 2.8 in the ranger, so if i use the bell housing from the 4.0, will i be able to use the clutch off the 2.8? i also have a clutch for the 96 4.0.
any help would be appreciated
