Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-04-2009, 10:22 PM   #1
Larry02451
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Transportation
Larry02451 is on a distinguished road
Default Heater Problems
My heater gets hot sometimes. At other times just warm. I have changed the thermostat three times with the same results. The heater works better when the heat indicator moves farther off of cold. Anyone had this problem??
Larry02451 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-05-2009, 07:57 AM   #2
srteach
srteach's Avatar
Vehicle Year: 1999, 2001
Vehicle Make: Ranger, F350
Vehicle Model: XLT supercab, SuperDuty
I use this vehicle for: DD / light OR, DD
srteach will become famous soon enoughsrteach will become famous soon enough
Default
Check the radiator. Any gunk visible? If so, pull it and have it flushed at a radiator shop. Pull the water pump, check that the impeller spins with the shaft and is not loose.
srteach is offline   Reply With Quote
Old 10-05-2009, 09:07 AM   #3
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
finish filling out your profile so we know what engine you have etc. etc, what thermostat did you use? Does your temp gauge work and does the truck warm up in the appropriate amount of time? Does the outside weather affect the heat
modelageek is offline   Reply With Quote
Old 10-05-2009, 09:23 AM   #4
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
I had a similiar problem with the truck in my profile. the engine would take a long time to warm up and the heat would be sporadic. I replace the thermostat with a napa product and it still did not work. I then changed it with a motorcraft f8cz-8575-aa. you need to make sure it is seated properly. it has worked great since then make sure coolant is filled and you burp all the air out of the system by squeezing the upper readiator hose. if you have the 2.3l i think you would use the same t-stat. the other t-stat had a sepaerat rubber gasket that did not seat properly and coolant would blow buy it thus takaing a long time to let the engine warm up
Old 10-05-2009, 09:34 AM   #5
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
I just realized you posted in the 4 banger forum so you have the 2.3L. gives us more info about the issue such as. what t-stat did you put? if the engine is not warming up quickly it is a t-stat issue. if the engine is warming up quickly it is something else. are your heater hoses hot? etc etc
Old 10-05-2009, 01:12 PM   #6
Larry02451
Vehicle Year: 1991
Vehicle Make: Ford
Default
I do have a 2.3L. I replaced the t stat with a 195 degree t stat from auto zone. The temp. gauge barely moves off of cold. It sometimes moves a little more than others and when it does the heater gets a little warmer. Sometimes it will get pretty warm but when I turn the heater fan on high it cools back down and the temp gauge moves back toward cold again. Thanks for any Infomation.
Old 10-05-2009, 03:38 PM   #7
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
It sounds like you have the same issue I had. I might consider replacing the t stat with the motorcraft one.make sure it is seated properly in the housing If the gauge and sensor are working properly and it seems like they are the engine should heat up even if the waterpump fins were broken. I would suggest concentrating on getting the engine to properly warm up first. Then we can go from there if the heat is not working. Make sure to fill the radiator completly and burp out the air
Old 10-05-2009, 09:20 PM   #8
Larry02451
Vehicle Year: 1991
Vehicle Make: Ford
Default
That's the same conclusion I have. I will try that.
Old 10-05-2009, 09:32 PM   #9
countryboy
countryboy's Avatar
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: dd and playin
countryboy will become famous soon enoughcountryboy will become famous soon enough
Default
is your antifreeze full and did you check to see if your collant was flowing to the heater core good.
countryboy is offline   Reply With Quote
Old 10-06-2009, 07:13 AM   #10
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
I agree make sure the coolant is completly full and you burp any air out of the systems. I have noticed on my truck if my coolant is low or there is air that my temp gauge flucuates and that it might sho running cold but if I rev the engine while it is in park. That gauge moves up. I concluded that my coolant was low and reving the engine pushed coolant passed the sensor and made it jump.
But if the sensors and gauge are working but the engine is not warming up most likely u have a stuck open tstat the wrong tstat or an improperly installed tstat. Make sure the tstat is installed and seated correctly in the housing. You might even need to twist it a little to remove and or install it. Good luck
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
87 Bronco II Grounding Problems Solved hdtv27ew Misc Electrical & Gauges 6 01-02-2018 10:20 AM
Heater core leakage maybe? SixSh00ter General Discussions 6 05-01-2011 08:12 PM
Bad heater core or something else? kossdust Heating & Air Conditioning 6 02-23-2009 11:46 AM
Heater Problems (1998 3.0L) Paraaronoid Heating & Air Conditioning 0 01-08-2009 01:21 PM
How do you seal slightly loose fitting heater hoses? OilPatch197 General Discussions 7 10-12-2008 02:53 AM
1999-2018 / 959 Media LLC / All Rights Reserved
