Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-06-2009, 05:35 PM   #1
rangerstranger
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger 4cyl 2WD 2.3L
rangerstranger is on a distinguished road
Cool 97 2.3L 4cyl, need tune up suggestions!
Im a 97 ford ranger manual 2.3L or 2.5L (have to make sure) 4cyl pickup, 2WD. Not much power to this baby, so I was wondering what the easiest way to supe/tune it up!
rangerstranger is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-06-2009, 07:06 PM   #2
bodkin1
bodkin1's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
I use this vehicle for: Daily Driver
bodkin1 is on a distinguished road
Send a message via Yahoo to bodkin1
Default
I would probably start with new plugs and plug wires. And maybe a new fuel filter.
__________________
DD-2002 Ranger 4x4 XLT, 4.0, X-Cab
Work-1998 Ranger 2WD XLT, 4.0, X-Cab
Dad's-1997 Ranger 2WD XLT, 3.0, X-Cab
bodkin1 is offline   Reply With Quote
Old 10-06-2009, 10:07 PM   #3
rangerstranger
Vehicle Year: 1997
Vehicle Make: Ford
Question Ranger tune up
thanks a lot, any suggestions on tune ups for gaining hp and/or torque?
Old 10-07-2009, 01:54 AM   #4
TheStig88
Junior Member
TheStig88's Avatar
Vehicle Year: 96,06,84
Vehicle Make: Ford
I use this vehicle for: Kickin ass
TheStig88 is on a distinguished road
Default
Quote:
engine swap with something bigger
__________________
1987 2.3 5spd (gone but not forgotten)
1996 2.3 5spd 5/5 drop, built 2.3 Turbo
1985 2.8 twin stick, durasparked (sold)
2006 FX4 (screaming yellow/workhorse)
1984 2.3 4spd (lowered dd/gas saver)
TheStig88 is offline   Reply With Quote
Old 10-07-2009, 06:51 AM   #5
rangerstranger
Vehicle Year: 1997
Vehicle Make: Ford
Question tune ups
I was thinking about doing that but i would like to see if i could just find parts for a tune up first.
i found some at this site:
http://www.engineperformancechip.com...-2008-c-10_280
give them a look if you will and let me know what you think.
i was focusing on air intake, performance chip, and the electric supercharger?
Old 10-07-2009, 04:49 PM   #6
bodkin1
bodkin1's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
maybe a K&N air filter. Or in your year range, maybe a K&N cold air intake. But a K&N filter in the stock filter box (like I have on mine, since there aren't any cold air intakes for 93-94's) will do, if you don't want to shell out more money.
__________________
Old 10-07-2009, 05:43 PM   #7
blackwidow67
The Vengeful One
blackwidow67's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: RANGER
I use this vehicle for: pissing my neighbors off
blackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to all
Default
intake will give you a 2-3 hp boost at max. electric super chargers are a totall waste. dont bother with them. they wont give you any power. and a chip wont do a whole lot. its more for tuning, and upgrades later. all it really does is "trick" the ecm.
i would do intake, exhaust, ngk spark plugs. ignition box. header, and some wires.
thatll gain you about 15 horse. these 4 bangers arent for horsepower. there just reliable tough engines.
__________________
1988 RANGER. Built 355 SBC. TH700R4. 3:73 Gears. BlackWidow Clone
1990 RANGER. Mild 5.0. T5 trans. 4.10 gears. Daily driver!
2002 Dakota 5.9 R/T QUAD CAB. for work and play....... well mostly play
1962 CHEVY IMPALA SS CONVERTIBLE
1999 DODGE RAM 1500. Lifted. 33s. 5.9. Magnaflow exhaust. Tow rig!
blackwidow67 is offline   Reply With Quote
Old 10-07-2009, 05:45 PM   #8
blackwidow67
The Vengeful One
Vehicle Year: 1990
Vehicle Make: Ford
Default
Quote:
could always do what i do. make a cold air intake outta 3'' pvc pipe with a cone filter on the end.
gotta love the $10.00 home depot intake.
__________________
Old 10-07-2009, 07:54 PM   #9
scotts90ranger
scotts90ranger's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
I use this vehicle for: holding down the driveway
scotts90ranger is a jewel in the roughscotts90ranger is a jewel in the roughscotts90ranger is a jewel in the rough
Default
going to accel coil packs isn't going to increase the power, the stock ignition system is plenty.
header won't gain you much either, the stock manifold is a decent setup.
getting rid of the air muffler in the intake should get you a little more grunt on the top end though, it will make it a little louder but you probably don't care... the stock air filter is the same as on a 4.0L, so it's not as restrictive as you would think if it can flow nearly twice the air a 2.3L needs...
if you think you need a less restrictive intake, get a vacuum gage and plumb it up to the engine, drive down the highway and floor it, the gage should point directly at 0, if you are still at a couple inches of vacuum then you are being restricted.
I'm running a turbo 2.3 through the stock intake plumbing and exhaust system (including cat), sure it's not the optimum setup, but it runs fine most of the time...
scotts90ranger is offline   Reply With Quote
Old 10-08-2009, 07:23 AM   #10
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
As the Great coach Bill Belichick says "it is what it is" put some good plugs and wires on it ie. Motorcraft change the fuel filter, clean the maf if you have one, new airfilter, check or change your tranny and dif fluids, make sure the tstat is working properly run some techron thru it and drive it around. remember. "you ain't runnin a speedboat"
modelageek is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2.3L 4Cyl Issues DJtheGreat 4-Cylinder (2000 & Older) 1 09-14-2009 07:44 PM
97 2.3L to a 99 3.0L Help wont start reklesint 'Other' Engine Conversions 12 12-02-2008 09:40 PM
97 ranger 2.3L 5speed 2WD speedometer thateb General Discussions 1 11-06-2008 03:58 PM
97 2.3l to 99 4.0 SOHC wolfman00hd 'Other' Engine Conversions 0 09-18-2008 11:11 AM
93 2.3l head fit a 97 2.3l? Arlington 4-Cylinder (2000 & Older) 1 12-06-2007 07:27 PM
1999-2018 / 959 Media LLC / All Rights Reserved
