If you weld you should read this
anyone who has been trained to weld properly should allready know this....
as for shade tree mechanics......good knowledge to learn....
l8r, John
Same goes for welding galvanized metal, It produces chlorine gas. Thanks for the link.
Really applies to any kind of chemical product, but solvents in particular are something to tread very lightly around -- especially with a lot of heat (welding, grinding, etc.), plenty of potential for some nasty concotion to brew up.
AllanD, isn't there a similar hazard with welding high-chromium steels?
holy shit that scared the hell outa me i did not know that im glad i read it
its fun jk ive frlt dizzy and couldnt see after torching and grinding shit i wore safty glasses tho
Well that's good to know, I was told by my welding instructor who is always seems to have a bs story.
Actually, galvanized stuff is coated in zinc. The resulting fumes cause zinc poisoning, I know a few welders who have this sickness for life. The zinc will stay in the body for a long time, so the next time they get even a whiff of zinc, they're sicker than before.
Lots of up-wind ventalation and proper position of yourself in relation to the fumes helps out tremendously.
Yes. OSHA recently tightened down their chromium parts per million allowances. In my shop, some radiators that serve in a corrosive environment(i.e. near or on the ocean or salt) are made out of stainless (chromium is the main ingredient) and we had to move all the stainless welding to 2 sucker tables and one down-draft table.
Long exposures to chromium fumes causes massive nerve damage among other things I can't recall now.
If the shop had central ventalation, which we don't have, we would've been a lot better off.
WOW four parts per million can be fatal thats just wow no words. ill never prep a weld surface with brake clean ever ever ever again. glad i read that
Phosgene gas...
How is that guy doing now?
If by "main ingredient" you mean 10-20% by mass, then I would agree with you. It's still mostly iron.
