contribute! You Know You Drive A Lifted Truck When...
ozziemo27
June 2010 OTOTM Winner
OTOTM Winner
Michigan
I'm Making an ultimate list of "You Know You Drive A Lifted Truck When..." I came up with a couple but i was wondering if you guys would contribute so the ultimate list can be made. This should be fun! :icon_twisted:
You Know You Drive A Lifted Bronco II When...
~ You consider making a custom spare tire carrier because you can no longer reach the lever to release it without a ladder.
You Know You Drive A Lifted Ranger When...
~ You can look straight across to Super Duty drivers at intersections.
~ You get offended when people call you Ranger a 'compact'.
~ You get the 'I wanna f*** you' look from the hot ass blonde/brunette driving the lifted powerstroke that's TALLER than you.
~ Someone passes you in the opposite direction and they thought you were in a lifted F150.
~ You have to convince your boss it isn't a '98 F-150.
~ The guys in the rigs pigs don't cut you off as often.
~ You drive your girlfriend's Focus, and wreck the front bumper because you're so used to just driving over the curbstops.
~ You score a free set of tires off a Cherokee that filled the wheelwells nicely on it and look ridiculously tiny on your truck.
~ Your truck makes people reconsider IFS.
~ You can drop the tranny for the dreaded ticking time bomb slave cylinder replacement while just sitting on your butt with the truck on it's tires.
~ You park it in a parking lot and come out of the store to find "hardcore" jeep guys looking your truck over.
~ You can disassemble and remove the entire front axle in under 1 hour with basic tools.
~ You have multiple sets of spare axleshafts lying around, just in case.
~ You're at a stop light you can see your FORD logo reflected on the car infront 's rear window.
~ You just got a new girlfriend and you have been single your whole life.
~ Girls see rangers and get an devious grin on their face cuz they had a good time in yours...
~ You need to lift up the 5 gallon pail you are using to change your oil with to keep the wind from blowing it all over the tire/ground....
~ You can't rotate your tires because your buddy(who has an f150) jack isnt tall enough.
~ You can no longer reach the ATM.
~ You need a ladder to fuel up or the nozzle doesn't reach.
~ You drive forward out of your parking spot over the parking block and forget it was even there.
~ Neons disappear within 10' of your front end.
~ Fat chicks can't jump in.
~ You walk up to your truck with someone they always ask if you have a grab handle.
~ Yao Ming needs a step ladder.
~ Your girlfriend/wife/lover/significant other has the lower body strength of a sumo wrestler.
~ You find your parking tickets stuck inside your rocker panel.
~ You're always in your truck because you're scared to jump out and break your ankle.
~ You borrow a friends car because your lifted truck broke again, and go to the drive-through, have have to look and reach up...you don't know what the hell to do!
~ You get your front and rear bumper hung up on each side of an 8 foot ditch.
~ Your arms aren't the only things that see flex.
~ You have to stand on the tires to wash the windshield at a gas station.
~ You back into the car behind you because you could not even see the roof.
~ You no longer need a creeper to get under the vehicle because you can casually sit under it.
~ You need alot of concrete blocks under the jack stands to get them to reach the vehicle.
~ You dont need a ladder to clean your gutters because you can just stand on the bed of the truck. ( also works with trimming trees)
~ You can see your truck 4 feet above everyone else in a parking lot.
~ You have to start dating women at least 6ft so they can enter your vehicle
~ The pimple-faced ricer driver has to open his sunroof to flip you off. Your wife says "NO" before you ask, and you do it anyway.
~ You can sit under it comfortably to replace the starter.
~ Your floor jack no longer is tall enough to lift the axle.
~ 6-ton jackstands don't reach the frame when the truck is on the ground.
~ Your significant other has insisted you put some sort of step on the truck so it's easier for them to get in.
~ Your friend looked at you when you got done lifting it the last time and said "I'm not riding with you in that!"
~ You have to stand on a bumper or tire to check your oil.
~ You plan your custom front bumper with that in mind... ^^
~ You can't use the drive through because your truck cant clear the height clearance bar.
~ A hi-lift jack is to short to jack it up.
~ You cant reach the door handles to open the doors.
~ Your tires are taller than your 4 year old!
~ You're looking at new houses and your decision is based off whether the garage door is big enough for your truck to fit through.
~ You walk around the back of the truck at night and instead of hitting your shins on the hitch receiver you hit your stomach.
~ You can stick your whole head in your wheelwell to look at the axle and have room to use a torque wrench on your u-bolts at the same time.
~ You go pick up your drunk buddy from the bar after he calls you for a ride and then falls out of the truck and breaks his arm.
~ You cruise around looking to pick up a girl and you actually have to pick her up to put her in your truck.
~ You can easily view down the cleavage from your drivers side window.
~ You have to turn around because of bridge clearance restrictions.
~ Valet parking is the only option cause parking garages just wont work
~ You're driving and the compacts get out of your way with scared faces on the rearview mirror from the drivers/passengers.
~ You can talk face to face with a semi truck driver at a red light.
~ You need to let the air out of the tires just to reach the spare tire when a step ladder is not available.
~ You pull into the automatic carwash, and the swing arm just sits there and bangs against your truck side because it can't swing over the top of it...
~ A cop pulls you over for speeding and you don't mind getting the ticket because you had to open the door, reach down to get it.
~ You have to use the semi-trucker lane at McDonalds because you can't see the speaker to tell your order.
~ You are pulled up behind a car and there are 4 headlight reflections on the bumper and only 2 are yours.
~ Your tires are custom made in the same shop as the ones for a Caterpillar 797 dump truck.
~ Someone with baggy pants trys to jump in and they tear the seat out of them.
~ You can sit indian-style under your truck to change the oil, without jacking it up.
~ You wear out the edge of your seat cover and bust a spring in the seat from doing the "jump in".
___________________________________
when u drive forward out of ur parking spot over the parking block and forget it was even there
You know you drive a lifted Ranger when...
-You can look straight across to Super Duty drivers at intersections
-You get offended when people call you Ranger a 'compact'
-When you walk up to your truck with someone they always ask if you have a grab handle
updated! awesome, guys, lol, i made a ranger specific one for those ones, Mike
when yao ming needs a step ladder..
when your girlfriend/wife/lover/significant other has the lower body strength of a sumo wrestler..
or you find your parking tickets stuck inside your rocker panel:/
When you get the 'I wanna fuk you' look from the hot ass blonde/brunette driving the solid axle lifted toyota.
-You have to convince your boss it isn't a '98 F-150 (it happened, he asked if I was sure it was a Ranger:icon_rofl:)
-The guys in the rigs pigs don't cut you off as often
You know you drive a lifted truck when...
Your always in your truck because you're scared to jump out and break your ankle
most posted are not ranger specific... lol.
It can apply to both.... here...ranger specific...or at least ford...
When you get the 'I wanna fuk you' look from the hot ass blonde/brunette driving the lifted powerstroke that's TALLER than you.
k...how's that? lol.
You know you drive a lifted ranger when someone passes you in the opposite direction and they thought you were in a lifted F150.
True story...I thought my buddy's '98 double lifted Ranger WAS a lifted Fiddy.
awesome! haha
You know you drive a lifted truck when you borrow a friends car because your lifted truck broke again, and go to the drive through, have have to look and reach up...you don't know what the hell to do!!
