v8 swap to 95 ranger
MaGiKaLsHoTs
Solid Axle Swap
Wilmington, VT
(01) / [94] / {
[3.0L] | (4.0L) | {5.0L, sas 35 boggers}
i dont see anywhere if i need to cut this to clear the valve covers? anyone know if it will fit with that box thing on the newer rangers?
MaGiKaLsHoTs
Solid Axle Swap
Wilmington, VT
(01) / [94] / {
heres a better pic its 4 the blower housing
ok guess the picture isnt working anymore
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
It will fit the valve covers fine with no mods. The issue comes with the routing of the intake tube.
I'm running a Mustang intake manifold ('87-'93), it clears the blower box, but a 90* tube off the throttle body hit the edge of the box. Other setups (aftermarket, '94/'95, Explorer, etc., may not have this issue)
I removed the AC from my truck. replaced the heater box with a non AC version, which is the same moulding. So this whole section is now empty with no (evaporator?) inside. So I cut it off and fibreglassed it.
FWIW, a pre-'95 box will not fit, (the kind you pics of being modded for valve cover clearance) as the firewall is different. I bought one to try, that's how this was figured out.
You can see clearly here, no mods:
A friend's truck: (GT40 on RPS) Not modded, but AC not currently hooked up. (it's a short FEAD setup, (off '93 Cougar, similar to '94/'95 'Stang, Explorer) and uses the rad in stock position, leaving rome for the condensor in front of the rad)
Guess I don't have a clear shot of the modded box in photobucket, but you get the idea.
MaGiKaLsHoTs
Solid Axle Swap
Wilmington, VT
(01) / [94] / {
yep ya im not gonna have to worry about the intake unless i hook up a snorkle mine is carbed 71 302
thanks for the info
Similar threads
Members online
Today's birthdays
Truck of The Year
Kirby N.
2024 Truck of The Year!
