Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-06-2009, 10:53 AM   #1
bIIcool
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Bronco II
bIIcool is on a distinguished road
Default Temp gauge not working
I have a 1990 bronco II 2.9 4x4. Recently I just replaced all my fuel injectors to increase my fuel performance. After i put everything back together I noticed that my temperature gauge no longer works it stays pegged at below zero. Before the injector change it worked fine. I have since replaced the temperature sensor and confirmed that the wires connected to the jack were still ok. I tested the old temp sensor and it appears to work ok. testing resistance I see a resistance change the hotter it gets. After all this my gauge still does not work. Does anyone have any idea as to why this would suddenly just stop? Any suggestions?
bIIcool is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-08-2009, 01:25 PM   #2
nightshift
nightshift's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Bronco II 200k on 06-23-09 @ 1413H. WOO-HOO!!
I use this vehicle for: Commute & gettin' around
nightshift is on a distinguished road
Default Wiring
Seeing as how you've replaced the injectors, check the wiring on the top of the engine for damage, check to make sure all your connectors are together, OK, and not corroded. A good thing to do is to put some dielectric grease in the connectors whenever you pull them apart. This helps to keep out the moisture (not so much of a problem with modern weatherpack connectors).
__________________
Those who are willing to give up freedom for security deserve neither.
nightshift is offline   Reply With Quote
Old 11-12-2009, 09:19 PM   #3
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
Check the engine grounds.
IF you were working on the injectors you had the ground lugs that
connect to the upper intake loose
Also check the ground wire that runs between the back of the drivers side cylinder head and the Wiper motor.
Oddly messing with that one also causes weirdness in the temp guage operation.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
temp gauge not working bIIcool Misc Electrical & Gauges 0 11-06-2009 10:52 AM
Twitchey Temp Gauge Needle LearjetMinako General Discussions 0 10-29-2009 08:52 AM
fuel gauge and temp gauge Bruce Misc Electrical & Gauges 1 07-01-2009 05:58 AM
aftermarket temp gauge problem fatt_owl2.9 Misc Electrical & Gauges 6 05-11-2009 08:19 PM
engine temp gauge not working fishon91 Misc Electrical & Gauges 5 02-21-2009 11:12 AM
1999-2018 / 959 Media LLC / All Rights Reserved
