Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 11-10-2009, 06:54 AM   #1
WJC97
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger Supercab 2.3
WJC97 is on a distinguished road
Default Fuel filler hose repair
Just bought my friend's 97 Ranger, and took it out for a fillup last night. Dumped fuel all over the ground at fill-up, and I see there is a longstanding problem with crap fuel hose on Rangers (I know from experience Ford will let problems fester for 10+ years before fixing them ).
My question is: Is there any creative solution to this besides buying the new neck assembly? For example, does anyone make a fuel-resistant flex hose that I could clamp to the necks?
Also, if I do have to buy the new neck assembly, are the generic ebay models too much of a risk? They're awfully tempting for $40 delivered, but I have no idea of the quality. Advance wants $300 for the Dorman part, which is probably junk itself. (Dorman quality is inconsistent).
WJC97 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-10-2009, 07:33 AM   #2
Doom's Day Custom
Doom's Day Custom's Avatar
Vehicle Year: 1996
Vehicle Make: ford
Vehicle Model: ranger xlt 4.0l v6
Doom's Day Custom will become famous soon enough
Default
lol i had the same problem so all i did was put gasoline safe glue in the cracks and wrap it really good in electrical tape!!!! But there is a problem i don't think you know about which the end of the hose are to different diameters.. I call a tractor trailer place that repair them and the will sell me the hose to fix so you might want to check out a tractor trailer place and i have tried every place around me i could think of to find that hose but with no success and the tractor place was the only on that had it !!! I hope it help!!!
__________________
CHARGE $5 FOR WHINING IN THE FORUMS
Laws are only used to stop the honest person!!! If woman don't find you hansom ,then they should atleast find you handy!!!!
Doom's Day Custom is offline   Reply With Quote
Old 11-10-2009, 08:00 AM   #3
mentalbreakdown00
Vehicle Year: 1995
Vehicle Make: Jeep
Vehicle Model: XJ
I use this vehicle for: hauling, dirty work/ daily ride
mentalbreakdown00 will become famous soon enough
Default
From experience, I have not found a suitable hose yet that lasts as long as the Ford one. I have discovered that each end is slightly different diameter, and also another problem you will have is the air tube that runs through the hose is built into it, I have destroyed everyone of them I have tried to remove, unless you don't mind the constant clicking at the gas pump when it shuts the valve off like it's full.
__________________
It only hurts 'till it quits....my dad
Insanity; repeatedly doing the same thing expecting different results.... Albert Einstien
mentalbreakdown00 is offline   Reply With Quote
Old 11-10-2009, 10:04 AM   #4
LittleBigFoot
LittleBigFoot's Avatar
Vehicle Year: 79-00
Vehicle Make: Mostly Ford.
Vehicle Model: Rangerish-Broncoish-Truggyish Thing.
I use this vehicle for: The 13th step of the 12 step program.
LittleBigFoot is on a distinguished road
Send a message via AIM to LittleBigFoot Send a message via MSN to LittleBigFoot
Default
I just swapped a 33 gallon Bronco tank into my 00. Had the same problem with the fuel filler neck.
The two different IDs of the hose make it a pain in the ass to piece somethin together.
Most auto parts stores dont carry fuel filler neck hose.
Your best bet would be snagging a few from the junk yard. With C4C I bet you could find a later model ranger neck with the seperate vent line and make that work.
Good luck
__________________
Wheeler: Ranger With Some Stuff Done
DD/Tow Pig: 1972 F250 With Some Stuff Getting Done
LittleBigFoot is offline   Reply With Quote
Old 11-10-2009, 10:59 AM   #5
WJC97
Vehicle Year: 1997
Vehicle Make: Ford
Default
Quote:
Good luck
I thought of that, but was afraid of spending time and money on another hose that may rot in a year or two. Is there a particular year where Ford "fixed" the problem, with a more durable hose? And are all later model years compatible with the 97? Thanks for the responses.
Old 11-10-2009, 11:06 AM   #6
mentalbreakdown00
Vehicle Year: 1995
Vehicle Make: Jeep
Vehicle Model: XJ
Default
12-13 yrs isn't durable enough?
__________________
Old 11-10-2009, 12:43 PM   #7
erocka1982
erocka1982's Avatar
Vehicle Year: 2004
Vehicle Make: ford
Vehicle Model: ranger edge
I use this vehicle for: gettin tickets
erocka1982 is on a distinguished road
Default
your getting ripped off at advance. the dorman filler neck does not cost that much. i work at a parts store i can get you a dorman filler neck for half that! and prolly 6 bucks to ups to you.
__________________
04 ranger edge+ext cab+4x4+dual exhaust(magnaflow)+upgraded all the lights+tinted windows+custom xm radio install+billet grille+3"body lift+cranked t-bars+285/75/16's
erocka1982 is offline   Reply With Quote
Old 06-13-2010, 10:32 PM   #8
Nelson674
Vehicle Year: 1990
Vehicle Make: Ford
I use this vehicle for: DD
Nelson674 is on a distinguished road
Default
Sorry I know this is an old thread but I just ran into this same problem and figured I would bring it back up to the top to see if anyone has figured out a fix yet.
So.... Has anybody found a better/less expensive solution to the cracking fuel filler hose problem?
Thanks for any input.
P.S I'm new around here, for those that don't frequent the intro. section here is my truck.
http://www.therangerstation.com/foru...ad.php?t=81909
Nelson674 is offline   Reply With Quote
Old 06-14-2010, 07:46 AM   #9
scottg
Junior Member
Vehicle Year: 04
Vehicle Make: Ford
Vehicle Model: SportTrac
I use this vehicle for: Daily Driver
scottg is on a distinguished road
Send a message via AIM to scottg
Default
im running the ebay special on my 95, and it works fine. I've only had it for 4 months though. It did fix right the first time
__________________
2004 Explorer Sport Trac XLT premium 4.0L auto 4wd
1995 Ranger XLT ext cab 3.0L auto 2wd
2005 Jeep Liberty Limited 3.7L auto 4wd
scottg is offline   Reply With Quote
Old 06-14-2010, 07:12 PM   #10
Nelson674
Vehicle Year: 1990
Vehicle Make: Ford
Default
Quote:
Did you drop the tank for installation or remove the bed?
This is my first vehicle (besides my parents Camery I've been driving the last few years) so I'm somewhat new to fixing cars and mechanic work. Could someone enlighten me as to what makes this filler neck so expensive at LMC and where ever the OP said he looked. ($300 ) It's just a rubber hose that is resistant to gas, no?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help my truck failed the new Fuel Evap Smog Test overseaz 4-Cylinder (2000 & Older) 21 09-27-2015 07:22 AM
from old 4.0 swap MrE_Powers 'Other' Engine Conversions 5 04-26-2011 08:59 PM
Fuel Filler Problem RW985 General Discussions 15 06-30-2009 07:10 AM
Fuel Filler and Pump Kona 1983-2011 Off-Road & 4x4 Ford Ranger's 0 11-19-2008 12:07 AM
1994 Fuel Filler Neck........HELP!! BMT_Ranger General Discussions 2 05-02-2008 04:28 AM
1999-2018 / 959 Media LLC / All Rights Reserved
