Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Off-Road Rangers Under Construction
Notices
Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress.
Post New Thread Reply
Thread Tools Display Modes
Old 11-25-2009, 05:13 PM   #1
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Class: mall-crawlin'
Used For: Dump runzzzz
Andres629 has a spectacular aura aboutAndres629 has a spectacular aura about
Default Andres629's 92 build
Figured I might as well start a build thread on my truck, no matter how slow it may be updated. Mostly just for my records. Bought truck in December, 2008. Here's the truck it replaced...
Pretty clean '94 F-150 5.0 auto, s/b, Aussie locked 8.8, L/S D44 up front, stock gears... manual t-case from a 95, Pro-Comp 4", BFG 33x12.5 M/T, and some dual exhaust... oooooooooh.
Here's the '92 as I bought it in December.
Truck had 344,xxx km on it. 2.9 rebuilt w/ receipt at 243,xxx km, A4LD rebuilt at 300,xxx km w/ receipt, 4.10 gears. Superlift 4" lift installed, 3" PA body lift. Did ball joints when I bought it, and wheel bearings and threw on a K&N filter, as the stock airbox was cracked ABOVE the filter. Genius... About a month later, broke the coil bucket, replaced with a solid one from local Pick 'N' Pull. Threw on some BDS shocks at the same time. No pictures, as I wasn't thinking of that at the time. Drove/wheeled it as it was for months, got some new tires, and did body mounts. Replaced the 4x4 control module, plugs and wires, and other misc. things.
__________________
1987 BII - Rest in peace. I'm sorry I had to give up on you.
Project Back in The Game: 94 Ranger Supercab- 4.0, M5OD to C4 swap, coil sprung Dana 60, 914 disc brake rear, 5.13's, beadlocked 40" LTB's, Bed bob
The Daily: 95 RCLB F-250 - Powerstroke Diesel, ZF-5, 3" downpipe, 4" straightpipe, 315/75r16's at stock height.
Quote:
Originally Posted by MountainMike View Post
BFH FTW!
Quote:
Originally Posted by wahlstrom1
Measuring the trailer all the way to the hitch instead of just the deck is like measuring your dick from behind your balls... Just sayin!
Andres629 is offline   Reply With Quote
Old 11-25-2009, 05:28 PM   #2
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Default
Recently, broke a leaf spring so I figured it was time to do the 64" swap. Got them re-arched and got rid of the stock block. Here's a few pictures.
That's a large amount of camber on them there springs!
Upside down/Belltech 6400 shackles. Don't worry, I won't be driving it like this! I don't have a welder yet, so it was just put together so I could move it in and out of the garage if I needed to use the space.
Driveable.
__________________
BFH FTW!
Old 11-25-2009, 05:43 PM   #3
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Default
And what the heck, might as well post a couple pics of my DD. Paid $400 CDN for it... needed ring gear and a head gasket to get 'er running again. In pretty good shape if you ask me! In terrible need of a regear though, after I threw the 235/75R15's on it. Threw the 4x4 coils on the front to level it out a bit and stop the rubbing on the fender at full lock. Swapped in the seats from my parts truck, dash pad as well. Going to throw the stock blocks from my '92 under the leaves, and grab a couple 2WD F-150 coil spacers for the front. Here she is, not bad for $400 CDN, huh?
Missing a LOT of interior pieces... luckily my parts truck has a blue interior!
SEATS!
Not too shabby, I'd say. Very little rust too, excellent.
__________________
BFH FTW!
Old 11-25-2009, 05:48 PM   #4
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Default
Now, here's where I need some input from you guys! The parts truck I have has a flat deck on it... I'm torn as to whether I should throw the flat deck on my 92, or leave it... I mean, I've got a perfectly good, rust-free box!
Here's a picture of the parts truck when I first bought it, and the flat deck on it. 87 4x4 2.9, $200, rings gone.
Flat deck. Yay or nay?
__________________
BFH FTW!
Old 11-25-2009, 05:52 PM   #5
mc_muench
mc_muench's Avatar
Make: Ford
Model: not a ranger :(
Used For: late night cruisin'
mc_muench is on a distinguished road
Send a message via Skype™ to mc_muench
Default
NAY!!!!!!!! I love the chrome stripe down the side and diamond plate under the tailgate, but you should get the grill chrome then too...just a thought
__________________
The Dude abides...
2007 Explo Sport Trac Limited 4.6 V8 4x4: Dad's new ride
BB "The RedBull Ranger": SOLD...not a day goes by that I don't miss her
mc_muench is offline   Reply With Quote
Old 11-25-2009, 05:56 PM   #6
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Default
Haha, thanks MC. The chrome stripe is actually just tin tape, like you'd use on ducting. The truck had a huuuuuge dent in the passenger side door, so when I repainted it, I thought it needed something to break up the red a bit... TIN TAPE! It actually turned out not too bad, considering. =P And I threw that checker plate in there 'cause of the body lift... I thought it looked silly having that huge gap in there.
Thanks for the input. And the grille and headlight bezels are black now.
__________________
BFH FTW!
Old 11-26-2009, 11:52 AM   #7
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Default
Well, threw the flat deck on there... not sitting as high as it should, nor is it bolted down. I have some 5" channel that would go under the mounting points. What do y'all think? I'm torn...
__________________
BFH FTW!
Old 11-26-2009, 12:29 PM   #8
ranger92
Junior Member
Year: 1992
Make: ford
Model: ranger custom
Engine: 3.0l
Class: 2WD Street
ranger92 is on a distinguished road
Default
boooooooooo nay to the flat bed
ranger92 is offline   Reply With Quote
Old 11-26-2009, 12:35 PM   #9
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Default
Seems to be the general consensus. I guess no flat deck. Haha.
__________________
BFH FTW!
Old 11-26-2009, 01:20 PM   #10
mc_muench
mc_muench's Avatar
Make: Ford
Default
Tin tape, huh? Never would've thought that by the pics...
It doesn't matter what it's made out of, it looks good
__________________
The Dude abides...
Old 11-26-2009, 11:12 PM   #11
85rx7_93ranger
85rx7_93ranger's Avatar
Year: 1990
Make: ford
Model: B2
Engine: 2.9
Class: 4x4
Used For: DD/project "crazy horse"
85rx7_93ranger is on a distinguished road
Default
man it looks like your bed would hold alot more than that ugly flatbed lol
__________________
93 ranger sold for 90 B2 with 2.9 and 5 speed, cant wait to lift it up!
almost done with the 85 mazda rx7 355 v8/2004r/ ford 8.8 trac-lok project...in progress
85rx7_93ranger is offline   Reply With Quote
Old 11-27-2009, 12:49 AM   #12
Andres629
Andres629's Avatar
Year: 1994
Make: Ford
Model: F-350 Ranger
Engine: 4.0
Default
Well, that's not the flat bed I was going to use, just needed a place to put it 'til my cousin comes and picks it up for his S10. Was just trying to get an idea what it would look like with a flat deck, but I think I'm partial to the Ranger body lines.
__________________
BFH FTW!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
