Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-03-2009, 09:37 PM   #1
ranger dude 185
Vehicle Year: 2004
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: rockin the mud puddles in the AZ
ranger dude 185 is on a distinguished road
Default replacing the clutch master cylinder
I have an 04 ranger with the 3.0 and 5 speed manuall tranny. the clutch master cylinder is having problems and i have had it in the shop where they agree its the master cylinder but the problem was not all the time so i have been driving it and its starting to have a problem more often so i need to get it replaced. the shop told me they could replace it for about 250-300$ with everything, parts/labor/bleeding the system. I found a master cylinder at the auto parts store for about 50 bucks. I went to school to work on diesel trucks so im pretty good with mechanical work but i have never changed a master cylinder on a ranger and was wondering if anyone has or if there is a lot of work or special tools required. just debating weather or not i want to attempt it or let the shop do it.
ranger dude 185 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-03-2009, 10:56 PM   #2
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Vehicle Year: 89
Vehicle Make: Ford
Vehicle Model: Ranger S
I use this vehicle for: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
its easy, the hardest part is bleeding it. just unhook the clutch pedal pushrod. remove the fluid line and unbolt from the firewall
BRUTUS_T_HOG is offline   Reply With Quote
Old 12-04-2009, 08:15 AM   #3
piotrsko
piotrsko's Avatar
Vehicle Year: 83-85/86/87/88
Vehicle Make: ford
Vehicle Model: FRANKENranger homebuilt ALL ELECTRIC 220VDC up to 400 hp
I use this vehicle for: Son's anti college education
piotrsko is on a distinguished road
Default
up in the TECH section there is a whole series of how-to's on R&R the clutch system, or a search on clutch master cyls will give you about a hundred differeent ways to bleed.
piotrsko is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Clutch master cylinder help fishbone1 Transmissions 1 11-07-2009 01:08 AM
Clutch Master Cylinder Stuck in the Out Position KJT123 Transmissions 4 10-08-2009 10:43 PM
Question about replacing clutch master cylinder! atvkid4eva Transmissions 6 08-23-2009 11:32 PM
My "new" 93 ranger sfwjesse 1983-2011 Off-Road & 4x4 Ford Ranger's 31 08-11-2009 02:47 PM
Bench Bleeding a Master Clutch Cylinder bernerboy Transmissions 5 12-06-2008 02:50 PM
1999-2018 / 959 Media LLC / All Rights Reserved
