Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-23-2009, 05:49 PM   #1
dragonryder
Junior Member
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: DD beater
dragonryder is on a distinguished road
Default Do I need a new heater core?
Alright I have a 96 ranger 2.3l thats got almost 200k miles on her. I've only had it about 6 months and it never seemed to defrost well. I just wrote it off to the fact that it doesn't have A/C so it takes longer. I can smell antifreeze in the cab but I know I have a coolant leak on the lower rad hose so I thought that was why. Now today I started to see smoke from under the hood, so after a short investigation I find coolant dripping from a tube that comes out of the fire wall just below and to the right of the coolant lines going into the heater core. I have no leaks inside the truck but I do have alot of moisture that forms on the windows when it sits and the windows fog pretty good when I kick on the defrost. I'm thinking it's the heater core but I heard it is a real PITA to change so I thought I would ask on here first.
dragonryder is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 12-23-2009, 09:43 PM   #2
schmoo
Vehicle Year: 83 2.8 ranger
Vehicle Make: 84 2.3 4x4 rang
Vehicle Model: 98 4.0 4x4 ranger
schmoo is on a distinguished road
Default
my 83 was like that- it was easy to change, unhook
hoses, take three screws out on the cover inside,
and it falls out in your hand. don't wait- it is not
healthy to breathe antifreeze.
schmoo is offline   Reply With Quote
Old 12-23-2009, 09:48 PM   #3
dragonryder
Junior Member
Vehicle Year: 1996
Vehicle Make: Ford
Default
From what I have read on here it is not that simple on the 95+. We have to remove the whole dash to get to ours. Also antifreeze can be all that bad, it has a nice sweet smell that covers up the smell of the cigarette's.
Old 12-25-2009, 07:47 AM   #4
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
in all seriousness you don't want to be breathing in coolant fumes. +1 on 95 and after being a pita to change........is there a chance that the hose is leaking at the firewall and causing this issue. have you tried to tighten the clamp where the drip is?
__________________
2004 Ext Cab, 4WD, 4.0, Auto, 153k(engine is out of a 2009 Ranger with 95k) Mileage readings as of 5/14/2017
2004 Ford Ranger Edge, Ext Cab, 2WD, 3.0, 5 speed, 116,000, AC. (SOLD)
1999 Ford Ranger, Reg Cab, 2.5, 5 speed, 2WD, no AC, 150k (SOLD)
modelageek is offline   Reply With Quote
Old 12-25-2009, 10:09 PM   #5
fili450r
fili450r's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger Splash
I use this vehicle for: daily driver, mudding, hauler, GETAWAY vehicle. PISSING ME OFF!
fili450r is on a distinguished road
Default
Quote:
x2....check all other solutions before taking your dash out....mine is lucky enough to be the old easy way, but it is not fun, i did it on a 98 exploder.
__________________
94 Ranger Splash 3.0-stock. pioneer HU/speakers..cheapos for now.
05 Honda 450r(mine)- modded a bit.
Sand Rail(dads)- 3.0 Honda Vtec, 6 rib bus tranny. *OH SO FUN*
fili450r is offline   Reply With Quote
Old 12-26-2009, 05:11 PM   #6
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
Even inhaled Ethylene Glycol can cause liver damage.
IF you smell coolant...
As for it draining out that little pipe? that little pipe is there to prevent
it from draining inside thecab.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 12-26-2009, 09:40 PM   #7
riverviewcontracting
riverviewcontracting's Avatar
Vehicle Year: 88
Vehicle Make: ford
Vehicle Model: bronco II (that thing)
I use this vehicle for: whatever i want Built Ford Tuff with Junk yard Stuff and a lot of trash
riverviewcontracting is on a distinguished road
Default
that is the heater core drain tube to keep the cooland out of the cab check under the dash it ma be easy as 5 screws to drop the cover and udo the hoses then pull back the core and down its out put back just the oppisite i just did 1 of them this year on different year and make rbv
riverviewcontracting is offline   Reply With Quote
Old 12-26-2009, 09:47 PM   #8
Vehicle Year: 88
Vehicle Make: ford
Default
Old 12-29-2009, 11:54 AM   #9
dragonryder
Junior Member
Vehicle Year: 1996
Vehicle Make: Ford
Default
Thanks all, I thought that the tube may have been a drain but I wasn't sure. Guess thats why I haven't been getting and antifreeze in the passenger floor. Now just a question of tearing the dash out and replacing the core.
Old 12-29-2009, 12:26 PM   #10
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
95+ you have to pull the dash. I think the ford dealers alocate 5 hours plus parts
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Heater Core Swap in a '98 thegoat4 Submission Archive 13 09-05-2014 08:47 AM
Heater core R&R in a '98, FYI thegoat4 Heating & Air Conditioning 21 04-30-2014 10:20 PM
Heater core leakage maybe? SixSh00ter General Discussions 6 05-01-2011 09:12 PM
Bad heater core or something else? kossdust Heating & Air Conditioning 6 02-23-2009 12:46 PM
heater core cover/box MyFirstRanger99 Heating & Air Conditioning 1 08-03-2008 09:50 AM
1999-2018 / 959 Media LLC / All Rights Reserved
