Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-11-2007, 06:39 PM   #1
bginn
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Ranger
bginn is on a distinguished road
Default Compression, no compression
4 cyl 2.3.
Engine has continued to lose power. At least it seems that way. Engine has eventually started missing at idle speeds and while coming to stops. Engine dies on occasion while at idle. This sypmtom doesn't appear as bad when engine is warmed up to normal operating temps. Sick and tired of the missing engine and lack of power so put in the shop. Mechanics have kept for about 2 weeks now. As per mechanic, Firing is in order, good plugs, timing ok, etc. Mechanic decides the head needs to be reworked and valves inspected. After all of this, still no fix. Swapped computers, still no fix. Mechanic says he is puzzled: "cylinder #1 & #2 is losing or has no compression on occasion." He says when cylinder #1 loses compression, cyl #2 has compression and is good and vice versa.
How can this be? Mechanic seems to be concerned and I have thought was a pretty good mechanic, but this has him puzzled, as well as his collegues. He seems to have run out of options for this compression issue. Any suggestions? More info. needed?
Thanks in advance.
bginn is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-11-2007, 07:47 PM   #2
Ranger5.0
Ranger5.0's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: DD, Wheeling,
Ranger5.0 is an unknown quantity at this point
Default
maybe try replacing....the mechanic? sounds like the guys grasping at straws
__________________
" MAKG-If you're making a snorkel, you don't need anywhere near 3 inches. You're not going to be running drag races in a river"
93' EXT,on the second 302H.O 3" single exaust,Deltaflow 40/AOD/13-56/F-150 coils, Explorer/ranger leafs.
Ranger5.0 is offline   Reply With Quote
Old 12-11-2007, 10:08 PM   #3
Young_unn
Junior Member
Young_unn's Avatar
Vehicle Year: 98,2000
Vehicle Make: Rangers
Vehicle Model: reg cab stepside, ext cab
I use this vehicle for: the 5.0 for donuts, 2000 DD
Young_unn is on a distinguished road
Default
Mine is doing the same thing as i speak. its a pain when its cold and you cant get it past 15 mph
Young_unn is offline   Reply With Quote
Old 12-11-2007, 10:38 PM   #4
michowski
michowski will become famous soon enough
Default
If you dont have any compression you need new rings at the least. If he has had it 2 weeks just to tell you your plugs and wires are good and the timing is ok then I would get it out of his shop asap. What was the compression reading he got? Should be 100psi minumum. More then likely you need new rings. If thats the case I would hone out the cylinders, replace the rings, main and rod bearings. Pistons to if you got the money.
__________________
1993 3.0 4x4 ranger
michowski is offline   Reply With Quote
Old 12-11-2007, 10:39 PM   #5
Broncodude
Broncodude's Avatar
Vehicle Year: 1984
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: Pulling out Jeeps
Broncodude is on a distinguished road
Default
Ask him if he did a leak down test.
__________________
Lock it or stay home
Broncodude is offline   Reply With Quote
Old 12-11-2007, 10:49 PM   #6
Young_unn
Junior Member
Young_unn's Avatar
Default
Quote:
Now mine may be different than his, not sure, but im eating coolant, Im thinking thats a sign or a bad head gasket, My oil isnt showing any foam on the cap or stick, and i dont burn oil (to my knowledge)
Old 12-11-2007, 10:57 PM   #7
michowski
Default
He never said anything about loosing coolant or oil so im figuring its rings. He also said the guys at the shop "reworked" the heads so im assuming that means they pulled em and replaced the gaskets. Have to wait till he responds to find out for sure.
__________________
1993 3.0 4x4 ranger
Old 12-11-2007, 11:03 PM   #8
Ranger5.0
Ranger5.0's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
What made the mechanic suspect the head needed work? WHAT work was done to the head? Is there written proof of inspections done by a qualified person? It sounds like this dude doesnt know what hes loking for. It takes a few hrs TOPS to do a preliminary diagnoses. Checking the ignition system and ignition timing is easy, if it all checked out ok, then it shouldnt have taken much time at all. there is a HUGE diference between having no compression what so ever, and having low compression. So get that cleared up. Oil in the cylinders will help creat a better seal with worn rings, so one can go on and on about therorys as to why the compression is coming and going. Me, id say his compression gauge has been droped a few to many times.
__________________
Old 12-11-2007, 11:04 PM   #9
Ranger5.0
Ranger5.0's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
young_unn Define eating coolent. Is it a leak when hot? does the exaust smell sweat? and you say you dont know if its eating oil...a good way to get a good handle on that is to check it, dayly
__________________
Old 12-12-2007, 01:14 PM   #10
bginn
Vehicle Year: 2000
Vehicle Make: Ford
Default
No coolant loss. Not any excessive oil use either, that I can tell. Not sure about the exhaust. There might have been a stronger smelling exhaust here lately, but not a sweet smell. I'm really not sure exactly what was done to the head other than just being "reworked".
Sounds like I do need to ask him a few questions though. I'll see him later today and ask about the "leak down test" and get the specifics about the head job.
Thanks y'all.
I'll keep you posted.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
