| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Premium Member
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0 Vulcan
Class: 2WD
Used For: Errands
Rep Power: 9 ![]() iTrader: (0)
If the 3.0, 4.0 are 60 degree and 3.8, 4.2 are 90 degree then how do we clear the a/c blower housing. I can only see two options body lift or cut the box and jeopardize loosing a/c / heating.
From the write ups in here it appears you cut the box or remove all together. I see alot of people recommend going 4.0, however only way to that if worried about h.p. is the sohc.. The direction I want to head is an old school "Grocery Getter" except in our modern world. (i.e. V-6). iam thinking 4.2or if I get lucky 3.8 s.c............. |
Tweet
#2 |
Year: 2006
Make: Ford
Model: F250 FX4
Engine: 6.0L Powerstroke
Class: 4x4
Used For: Droppin panties
Rep Power: 17 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Being those engines are a 90 degree V6, its pretty much the same deal as a V8. But, you have a 3.0L which means you can bolt up a FWD 3.8L to your trans. Basically, look at the V8 swap articles as far as firewall clearances go.
__________________
2006 F250 Super Duty Fx4. 6.0L powerstroke ARP studs, EGR delete, 4" turbo-back, bullydog intake, SCT livewire TS with looney tunes... (sold) SUPERCHARGED 2005 Ford Ranger |
Tweet
#3 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Used For: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Rep Power: 13 ![]() ![]() ![]() iTrader: (0)
1 - 2 inch body lift and your golden.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
