thrashed 93 going on 3/4 tons
blue88b2
15+ Year Member
Dallas, Oregun
1987 ranger
So I bought this ranger on Jan 19, 2010. I trailered it home to start the repairs and mods!:icon_thumby:
It's a 3.0L V6 5 speed magnaflow exhaust some other goodies 6" lift and 33's on soft 8's. Warn manual hubs and James Duff bumper.
Sure the body is rough, but the motor tranny and transfer are strong. It needs ball joints badly and all the lift tightened up.
I ordered new rear leafs for it today, should see them tomorrow. they're trailmaster 3" for $219 shipped! that will eliminate some block and fix the massive spring wrap and rear steer:D
-Jason
alright, here's a small update!
Got the new leafs installed last night. Put some new unbroken tail lights from a 98 ranger in today, removed most of the stickers and finally washed it!
Found the rear pinion and brakes to be completely shot! And still cannot get the front end to track well need ball joints, bearings and breaks. SOooo... I'm going to junk them and buy axles soon!!!
Going to order another set of these leafs for the front end to go with the axles when i find them!
well I bought axles tonight!!!
Dana 44HP 4.09 gears out of a 78 F250
Dana 60 4.10 same truck.
Front
Rear disassembled
Complete front
Rear end gears need set up still.
u-bolts plates and extra new ball joints.
Complete set of bearings, seals, pistons, for the rear axle.
the rest of the Richmond install kit to finish the gear setup.
The rear axle has the yukons in it, the Richmonds are brand new 4.10's, but the wrong kind i guess?
freshly turned drums and new shoes, along with the parts.
Extra rear carrier
Shafts
Going to get started on this very soon!
-Jason
daaang..you work fast! all that in less then 10 minutes :beer: haha.
Anyways, that truck doesn't look half bad, nothing unfixable:icon_welder:
:beer: when you put your mind to something!:D
Well I first posted in the "show off" forum, when i bought the truck last week. But then kept adding too that post. So rather than keep going, Thought i'd switch all the pics and info to a build thread!
I like um beat up, then i don't feel bad smashing/ rolling them:icon_thumby:
-Jason
going to upgrade to 35spline in the rear?
No, i'm gonna run it how it is for now, I'll tweak it down the road when i get more time and money, Right now i just want to get it on the trail/road!
-Jason
here's a teaser of last night, heading back to my shop to finish it up today.
-Jason
THE Deed is done! Almost, Drive line, brake lines and steering to be finished!
4" lift leaf springs for an explorer, 6" shackle sitting on 34x9.5 tsl's
I don't think it's too high,, It sure settled down from when it was at droop! And flexes really well! better after the 63" rear spring swap in the back and the dana 60.
It was suggested to me by a guy in another forum to swap out the square u-bolts with round ones and flip them, so i'm going to do that later, after i get it on the road( which is my main goal.)
more pics of the swap to post later.
-Jason
Nice. Is it a longbed?
yep longbed, it will be bobbed in the near future.
here are more pics sorry they're not in order.
The truck settled down more than i thought it would so I had to re drill the rear perch to get the correct shackle angle i want to run.
-Jason
sweet, nice welds, im interested lets see some more!!!
Looks good, needs bigger tires though.
alright, the rear dana 61 is now in!!!! In process of breaking in the new gears. and this afternoon i bought some used aluminum rims wrapped in 35x12.5 Swamper SSR's
For all you pizza cutter haters out there... I'll have pics tomorrow!:icon_thumby:
