Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 02-01-2010, 10:32 PM   #1
88rangerxltkc
88rangerxltkc's Avatar
Vehicle Year: 88 94
Vehicle Make: FORD
Vehicle Model: Ranger XLT 2.9 Auto Ranger XLT 3.0 5 Speed
I use this vehicle for: DD and mud
88rangerxltkc is on a distinguished road
Angry still having flood out prob on start up
I replaced iac valve which my uncle told me was the prolem. well no it wasn't. the truck still on start up spits and sputters wanting to flood out no matter what rpm. sometimes it will clear up quick and sometimes it will take 30 seconds. but like someone flipped a switch it clears out and runs PERFECT. Any help will be greatly appreciated.
88rangerxltkc is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 02-02-2010, 01:03 AM   #2
sjr53
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Bronco II
sjr53 is on a distinguished road
Default
I would put a timing light on the coil high tension wire & see if it is misfiring. I haven't read your previous posts that I'm aware of. It sounds like more than flooding from multiple leaking injectors or some other fuel problem (FPR) since it clears up suddenly. How about corrosion on the coils primarey wiring connection.
sjr53 is offline   Reply With Quote
Old 02-02-2010, 06:52 AM   #3
IMenriched
IMenriched's Avatar
Vehicle Year: 1986 02'
Vehicle Make: ford
Vehicle Model: ranger f150 fx4
I use this vehicle for: exercise and DD & hauling college kids stuff
IMenriched is on a distinguished road
Default
Quote:
Best to run codes....so that more parts are not replaced...on a "yeap, by jingle,that is it", fashion.
for getting the codes http://www.therangerstation.com/tech_library/OBD_I.html
that said, It could very well could have been the IAC was playing a part in your symptoms. maybe not, has there been any improvements/changes in start up since??...or is it still the same??
it could still be one or more items causing the issue....IDK?
FPR
MAP
CTS
ACTS
grounds and vacuum leaks, need to be checked too
__________________
IMenRiched
By the power of Lord Jesus
2 are willing to die for you.
one is a soldier, but the 1st was Jesus Christ
~few appreciate either~
IMenriched is offline   Reply With Quote
Old 02-02-2010, 08:19 AM   #4
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger FX-4 level 2
I use this vehicle for: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Default
The word "FLOOD" refers to too much fuel.. Missing at startup most times ISN'T too much fuel. So if it IS flooding there should be black smoke from the tail pipe.
My first guess is the mixture is too lean, causing the missing at startup.. Or some other problem, rather than "flooding".
Big JIm
Big Jim M is offline   Reply With Quote
Old 02-02-2010, 01:27 PM   #5
robertc1024
robertc1024's Avatar
Vehicle Year: nada
Vehicle Make: Ford
Vehicle Model: 2008 F150
I use this vehicle for: teach my boys to not get rid of a Ranger.
robertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond reputerobertc1024 has a reputation beyond repute
Default
I had similar problems with my coolant temperature sensor. Sometimes the truck ran great, sometimes was super rich, hard to start etc.
robertc1024 is offline   Reply With Quote
Old 02-02-2010, 05:32 PM   #6
88rangerxltkc
Vehicle Year: 88 94
Vehicle Make: FORD
Default
well thanks everyone for the advise i think im gonna start with pulling the codes seeing that i haven't done it since ive owned the truck.
Old 02-03-2010, 05:01 AM   #7
jaymegriffiths
jaymegriffiths's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
I use this vehicle for: screaming at
jaymegriffiths is on a distinguished road
Default
im willing to bet its either fpr, injectors, or temp sensor for computer
__________________
Quote:
Originally Posted by Frank The Tank View Post
if you guys really hate buying it so much, get a bigger tank and stop resetting the trip mileage and just drive.
Quote:
Originally Posted by baddad457 View Post
And that's a 600 cfm Holley and you've got it mounted backwards
88 2wd 2.9
jaymegriffiths is offline   Reply With Quote
Old 02-03-2010, 10:33 AM   #8
heptofite
heptofite's Avatar
Vehicle Year: 1986
Vehicle Make: Ford
Vehicle Model: Bronco II XLT
I use this vehicle for: Being Totally Awesome
heptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to beholdheptofite is a splendid one to behold
Default
my 2.9 would flood out when i had a bad coil.
heptofite is offline   Reply With Quote
Old 02-04-2010, 08:53 PM   #9
88rangerxltkc
Vehicle Year: 88 94
Vehicle Make: FORD
Default
Quote:
yeah i replaced the coil already i barely got it home when i bought it. The guy i bought it from did not know any thing about trucks and he had one of the plug cut off and spit into the three diff. wires and left one off. So i fixed that and havent had a single problem since. Now my 4.0 is a diffrent story, it has all sorts of problems.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
