Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-16-2007, 07:50 AM   #1
gatorranger
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger
gatorranger is on a distinguished road
Default Fuel Problems on Flex Fuel 99 Ranger
I have a 99 Ranger with the 3.0 Flex Fuel engine, with 51k miles. On saturday, it instantly stopped running upon startup. It cranks fine but then idles (or dies)as if there was no gas. No codes have been thrown on the panel. I changed the fuel filter with no results. If ether(starting fluid) is sprayed in the air intake the motor will run/idle fine. Also, when starting and in the run position, you can hear the fuel pump turn on. I figured that there must be a problem with the fuel pump and have one on the way. I also noticed that there is a sort of fuel regulator/sensor downstream from the fuel filter that I understand moderates the fuel on the flex fuel model. I can not find any information on this unit and whether it may be at fault. I would appreciate the forum's advice on what I should investigate or repair. Thank you.
gatorranger is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-17-2007, 07:16 AM   #2
BDAB
BDAB's Avatar
Vehicle Year: 2006, 1993,1990
Vehicle Make: Kia, Harley-Dav
Vehicle Model: Sedona, 1200 Sportster, F15
I use this vehicle for: Family truckster, dailyx2
My credo: If you can't go through it or around it, then go over it.
BDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud of
Default
you know my jetta is doing the same damn thing and I am convinced its the fuel pressure regulator........... going to confirm it with a fuel pressure gauge as soon as I get 1.
__________________
The day I am forced to stand for the national anthem is the day I sit
BDAB is offline   Reply With Quote
Old 08-26-2007, 12:01 AM   #3
Wicked_Sludge
Wicked_Sludge's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger, Flareside
I use this vehicle for: Attracting the ladies
Wicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the rough
Send a message via MSN to Wicked_Sludge
Default
i believe the module after the fuel filter is for sensing the ethanol content of the fuel so the computer can adjust timing/injector pulse accordingly. i have heard of it failing a few times.
i also thought the newer rangers use a returnless fuel system (eg. the pump is sped up or slowed down to regulate fuel pressure)
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 08-27-2007, 07:55 PM   #4
JohnnyO
Moderator Emeritus
JohnnyO's Avatar
Vehicle Year: 2008
Vehicle Make: Ford
Vehicle Model: Sport Trac
I use this vehicle for: Daily Driver
JohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to behold
Cool
My wife's 3.0 Taurus was acting up a while ago, turned out to be the camshaft postion sensor trigger bearing thingy (I think that's what it was called ). Apparently the bearing can sieze up. My man at the garage sprayed some WD-40 on it and it was good. About a $125 job to replace it if needed he said. Didn't cost me anything.
He was a little baffled because everything checked out okay, then called a Ford tech he knew who diagnosed the problem in about three seconds since he'd run into it before.
__________________
'08 Sport Trac, custom 2.5" single exhaust with Flowmaster DBX muffler, K&N, Firestone Destination A/T's, Truxxx 2.5"/1.5" strut lift.
JohnnyO is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
