Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-09-2010, 04:51 PM   #1
atvkid4eva
atvkid4eva's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Offroad
atvkid4eva is on a distinguished road
Default Really soft pedal hardly any brakes...
hey guys my buddy has a 93 explorer 4wd and the other day the brake pedal got really soft and went to the floor..could still stop but barely..so we thought it could be the master cylinder so we put a new one it bled the whole system completely and it is back to where it was with hardly any pedal..the truck has all new brake lines and leakes no fluid..good pads and shoes as well..what else could it be?
__________________
88' Ranger:5-speed, 6" lift, Detroit locked D35, Locked 31 Spline 8.8, 35's, 5.13 Gears...
atvkid4eva is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-09-2010, 07:26 PM   #2
kaytbugsdad
kaytbugsdad's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: mainly putting around town
kaytbugsdad is on a distinguished road
Default
If my memory serves me right, the RABS (Rear Anti-lock Brake System) valve and the proportioning valve are combined, and instead of pushing brake to the rear brakes, its bypassing fluid thru the valve back to the master cylinder....... Thats usually the reason you have a low brake pedal with no apparent fluid leak.......
__________________
87 Merkur XR4Ti--- 82k miles, 5spd, mono-white, all original......
My truck's life started as an ugly little red truck...... now it's a LOWERED ugly little red truck!!!!
kaytbugsdad is offline   Reply With Quote
Old 03-09-2010, 09:38 PM   #3
chazzone
Premium Member
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Broncco II
I use this vehicle for: Everything
chazzone will become famous soon enough
Default
Quote:
That doesn't sound right at all. The ABS control actually closes off each line if the sensor sends a signal that one wheel is locking up.
I don't see how this could cause a soft pedal.
There can really be only one reason, and that is a leak in the system, which could include a bad master cylinder.
Re-check and rebleed. If you're absolutely sure that the system is intact, it'd have to be the master cylinder.
There's got to be a leak in there somewhere.
chazzone is offline   Reply With Quote
Old 03-10-2010, 03:02 PM   #4
atvkid4eva
atvkid4eva's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
there are absolutely no leaks...ive traced every brake line and they are all new lines...a new master cylinder was installed the other day and completely bled..there isnt any air in the system to the best of my abaility. what about the brake booster?
__________________
Old 03-10-2010, 03:58 PM   #5
Guilius
Guilius's Avatar
Vehicle Year: 1995
Vehicle Make: Ranger
Vehicle Model: XLT
I use this vehicle for: doing things my friends tell me i shouldn't try and enjoying it.
Guilius is on a distinguished road
Default
I am dealing with a slightly similar problem with my Ranger after doing a rear Axle Swap to the explorer 8.8 (post is a few down from here).
i have gotten some information that if you have 4wheel ABS, it may have a Hydraulic Control Unit. If air gets into this, as it may have done with the master cylinder swap, your in some pretty hard luck. it can only be bled with a special tool from ford, and i have called around and the closest i found is 525 bucks. Dont as me what this tool looks like or how to use it, but they said they could do it in an hour and i refuse to bring it to a dealer.
im trying to get info on removing the HCU alltogether, and tying the three lines out from the HCU directly to the master cylinder.
this can explain the soft brakes even though it was fully bled. the unit has air in it.
mine are the same way and we adjusted the Pushrod from the master Cylinder, thinking that might be needed for the addition of the rear discs instead of the drums i usedto have, and they started locking up. readusted it back to normal and almost no brakes at all again.
Guilius is offline   Reply With Quote
Old 03-13-2010, 06:04 AM   #6
chazzone
Premium Member
Vehicle Year: 1989
Vehicle Make: Ford
Default
Here is what I found on bleeding the HCU. I've never had to do this before, but I found a lot of references to the issue.
http://www.justanswer.com/questions/...93-ford-taurus
__________________
'89 EB BroncoII, 2" body/3" suspension lift by Duff. D35 front/8.8 rear swap, Camcraft cam, Pacesetter headers, 4.0 radiator,P235 75 15 Michellin LTX
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
