Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-30-2010, 04:53 PM   #1
blindman_10
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 2.3L
blindman_10 is on a distinguished road
Default 94 ranger wont start
Hey all,
I went out to run some errands today and when I tried to start my truck it sounds like it only clicks once (I'm assuming that is the starter). Truck doesn't try to turn over at all. Battery and battery terminals are clean and the voltage is fine. All the fuses appear to be functional. I have not had any problems leading up to this.
Is it my starter? I'm new to Rangers, but on all my previous vehicles the starter typically clicks repeatedly not just once. Is there a starter relay that I can check? Any help would be greatly appreciated because my only vehicle is currently dead in the parking lot!
Truck is 1994 2.3L auto with approx 115k.
blindman_10 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-30-2010, 06:05 PM   #2
muscledrifter
muscledrifter's Avatar
Vehicle Year: 1992
Vehicle Make: Ford
I use this vehicle for: Work and play.
muscledrifter is on a distinguished road
Default
did you physically look at the starter? i know on my '91 there is a ground wire that goes on a square tab on the soloniod, if thats not connected, all you will hear is one click. hope this helps
__________________
-Landon
"Trucks are just like children, they need to be raised!"
muscledrifter is offline   Reply With Quote
Old 03-30-2010, 08:46 PM   #3
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Vehicle Year: 89
Vehicle Make: Ford
Vehicle Model: Ranger S
I use this vehicle for: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
that single click is your starter relay clicking. put the truck is neutral, follow your positive battery cable to the relay and use a screwdriver to short both poles together and see if it cranks over. if it doesn't then check the cable that runs to the starter or replace the starter
BRUTUS_T_HOG is offline   Reply With Quote
Old 03-31-2010, 04:52 PM   #4
blindman_10
Vehicle Year: 1994
Vehicle Make: Ford
Default
all wires to the starter and the relay appear to be attached securely. Bridging the poles on the relay produced no results, and the cable that runs to the starter appears fine (from what I can see). I guess I will have to remove the starter to have it tested.
Old 03-31-2010, 07:59 PM   #5
97ranger xlt
97ranger xlt's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
97ranger xlt is on a distinguished road
Default
Quote:
check the small wire on the starter. mine was loose/corroded. once i re-attached it the starter worked again..
__________________
1997 Ranger xlt x-cab 2.3l 5spd 166k gone but not forgotten
2002 Ranger xlt x-cab 4x4 4.0 auto 89k
97ranger xlt is offline   Reply With Quote
Old 03-31-2010, 11:37 PM   #6
Moreflying
Moreflying is an unknown quantity at this point
Default
How about checking for corrosion on the batt. post. Or it may be time for a new batt.
Moreflying is offline   Reply With Quote
Old 04-01-2010, 12:00 AM   #7
Bryan22
Bryan22's Avatar
Vehicle Year: 94 extd
Vehicle Make: Ford
I use this vehicle for: fun, dd.
Bryan22 is on a distinguished road
Default
smack the starter with a hammer and try again, if it starts go get a new starter =]
Bryan22 is offline   Reply With Quote
Old 04-01-2010, 12:45 AM   #8
Moreflying
Default
I know you mentioned clean battery posts. I can tell you from my experience with my truck (original owner since 1995) when this has happend to me it has been loose and or dirty battery posts. Or it could be the battery has gone flat. Battery posts may look clean but are loose or just have corrosion inbetween that can't be seen. Good luck.
Old 04-01-2010, 03:44 AM   #9
blindman_10
Vehicle Year: 1994
Vehicle Make: Ford
Default
I will crawl under and check the starter wires again tomorrow a bit closer.. I tried the smacking method - negative results. Battery is only 1-2 years old and shows a strong charge. I removed the battery cables from the posts and wire brushed both the posts and inner area of the cables and firmly reattached. Friday the girlfriend returns and then I will have an opportunity to use her car to take the starter to be tested if that is where this leads me...
Old 04-01-2010, 07:06 AM   #10
Nater
Nater's Avatar
Vehicle Year: 1994
Vehicle Make: Mazda
Vehicle Model: B2300
Nater is on a distinguished road
Default
99% sure it is the smaller wire...Mine did the same thing the Saturday after finishing the lift. I knew from my stangs experience to look at the smaller wire....Low and behold the wire looked like it was seated at a glance, but upon trying to seat it further it "clicked"...Haven't had a problem since...
__________________
Current DD-2004 Dodge Ram Quad Cab, 4.7L V8, 5 SPD
1994 Mazda B2300-Kuhmo 35x12.5R15s,Moonvisor,Westin Bull Bar,3" PA Body lift,Skyjacker 6" suspension lift-SOLD!
Quote:
Originally Posted by Peregrine
Nope, pure distilled Chuck Norris. He musta just got turned around in there with his roundhouse kick.
Nater is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
