Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 04-06-2010, 04:37 PM   #1
Junior Member
jdc215's Avatar
Vehicle Year: 1989
Vehicle Make: ford
Vehicle Model: Bronco II
I use this vehicle for: DD and weekend ORV
jdc215 is on a distinguished road
Default 2.9 timing chain replacement.
i think im going to have to replace my timing chain and gears and after thumbing through the chilton manual it says i need to remove the oil pan. is there any way to remover the oil pan without lifting the motor or can it be done with the pan on? i do have new motor mounts to put in some day but i was really hoping to avoid it.
jdc215 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
Old 04-06-2010, 10:13 PM   #2
Odd One
kunar's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger
kunar is a name known to allkunar is a name known to allkunar is a name known to allkunar is a name known to allkunar is a name known to allkunar is a name known to all
can be done with the pan on, ive done it more than once. its pretty much self explanatory, youll see when you get into it. the reason they say to pull the pan is because to get the cover off over the crank you need it to move straight toward the front of the truck. there's 2 studs that go through the pan and into the cover though, so you have to lift it up to get the studs out of the pan. you just have to kinda angle it and get it to all slide apart at the same time. the biggest thing to remember though is to use loc-tite and properly torque the bolt that holds the cam sprocket on, and do the same for the bolt that holds on the harmonic balancer. if you dont, youll be doing it again.
1987 Ranger Supercab STX, 4.0/M5OD/BW1350 4.10 8.8/D35, 3" Lift, Cut Fenders, 33's
1987 Thunderbird Turbo Coupe (Mostly stock, for now...)
1991 Escort GT (Daily Driver)
Past: 87 Supercab, 87 Longbed, 89 Shortbed, 96 Explorer Sport
kunar is offline   Reply With Quote
Old 04-07-2010, 07:07 PM   #3
Mysticcook's Avatar
Vehicle Year: 84,86,86,89,
Vehicle Make: Ford Ranger
Vehicle Model: extra cabs except 84
I use this vehicle for: Yard art
Mysticcook is on a distinguished road
Take this for what its worth. I have 86 ranger (project) ran good but but low oil pressure when warmed up. its been overhauled a while ago. but i dont think they replaced the timing chain tensioner or guide. Cause in my adventure to fix problem i found half of the chain tensioner in bottom of oil pan, with the associated plastic bits in the oil intake screen.Now i am betting this is the problem with the oil pressure (VS replacing oil pump) course now that it is warming back up i will start to put back together with fingers crossed.
I havent had it running long enough nor done compression test to know if this is all worth while. Using rockauto.com. definately saved some $$
I agree with kunar.
Mysticcook is offline   Reply With Quote
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
