Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-27-2007, 02:22 AM   #1
buzz_mn_58
Junior Member
Vehicle Year: 2000
Vehicle Make: ford
Vehicle Model: ranger XLT
buzz_mn_58 is on a distinguished road
Default 2000 ranger rear brake problem
Hi, The left rear drum shoes are dragging, and heating up the drum. So I replaces the shoes, that didnt help. Then I replaced all the brake shoe springs and the self adjuster, that didnt help. So the next was a new wheel cylinder. Samething happens, drive the truck the drum gets very hot, park the truck until cold, then try to drive forward that left rear is locked up. Reverse the truck 10-20 ft. then it is loose enough to drive forward. What do I do next ? May be a colapsed rubber brake hose if there is one ? Or maybe the Master Cylinder ? How about something with the ABS system ? PLEASE help before my wife makes me bring it to the Ford Dealer ! ! Thanks, Buzz
buzz_mn_58 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-27-2007, 04:01 AM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
Also check to make sure that the ebrake cable on that side isn't seized. You've got the adjuster backed all the way off and installed the right way and its still dragging?
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 12-27-2007, 08:30 AM   #3
buzz_mn_58
Junior Member
Vehicle Year: 2000
Vehicle Make: ford
Default
I'll check the e-brake. Yes, Sasquatch The adjuster are in right and back off all the way when installed, maybe a 1 turn on them. The brakes seamed to be fine after the install of the parts. While in the driveway hit the brakes hard in forward and reverse, many time all fine. But after driving to work there hot. (country driving no stop an go) then go to leave after cool down there stuck...............
Old 12-27-2007, 03:26 PM   #4
mfp4073
Junior Member
mfp4073 is on a distinguished road
Default
my 99 was locking up the rear brakes when you first started driving it. Was like that when I bought it. took it apart. Everything looked normal. Cleaned and lubed. Worked for about 3 weeks and then it started doing it again. The tranny went out at that point and I have not had a chance to get back into it since. Dont have any aswers, just a similar story to add to the thread.
mfp4073 is offline   Reply With Quote
Old 12-27-2007, 08:26 PM   #5
metalmacguyver
Yeah, I built that.
metalmacguyver's Avatar
Vehicle Year: 1997, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, F350
I use this vehicle for: Working and Wheeling
metalmacguyver is on a distinguished road
Send a message via AIM to metalmacguyver
Default
Quote:
i have never heard of collapsed brake lines. it should not be possible because it is always under pressure. it keeps happening to that one side and not the other so that means that its not the master. it doesnt sound like an ABS issue either as far as i know.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall.
http://www.therangerstation.com/foru...ad.php?t=21890
1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now...
1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only.
metalmacguyver is offline   Reply With Quote
Old 12-27-2007, 09:43 PM   #6
buzz_mn_58
Junior Member
Vehicle Year: 2000
Vehicle Make: ford
Default
Thanks for all the help people.It was the left rear parking brake cable.
Old 12-28-2007, 07:23 PM   #7
Sasquatch_Ryda
Vehicle Make: Ford
Default
AH! Good to hear you got it sorted out
__________________
Old 12-28-2007, 08:22 PM   #8
mfp4073
Junior Member
Default
how did you determine that and what did you do to fix it?
Old 12-28-2007, 11:57 PM   #9
buzz_mn_58
Junior Member
Vehicle Year: 2000
Vehicle Make: ford
Default
mfp4073...... Determinded that because the cable,and shoes wouldnt move when stepping on the park brake pedal with the drum removed. How did if fix it ? $19.00 and a trip to the NAPA store.......... Buzz
Old 12-29-2007, 02:52 PM   #10
mfp4073
Junior Member
Default
sounds good!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
