Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 05-16-2010, 10:02 PM   #1
croadmar
Vehicle Year: 2003, 2001
Vehicle Make: Ford, Mazda
Vehicle Model: Ranger FX4 Level I V6 4.0 Ltr , Tribute ES V6 3.0 ltr
croadmar is on a distinguished road
Default Coolant leak in my 03' ranger v6 4.0
thought it was my water pump, replaced that and my thermostat, and still have the same leak. it's leaking alot of fluid (probably a gallon a minute) from above and behind the water pump. by reading posts i'm finding it may be an old freeze plug, lower thermostat housing, intake manifold gasket or a head gasket. will a pressure test of the coolant system tell me the problem, if so, can someone please lead me to the correct steps to do so.
Thanks
croadmar is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 05-16-2010, 10:14 PM   #2
88_Eddie
Chopper Challenge Champion
88_Eddie's Avatar
Vehicle Year: 1988, 2000
Vehicle Make: Ford
Vehicle Model: Bronco II (Eddie Bauer), Explorer
I use this vehicle for: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
you'd have water in the oil or oil in the water if it was a head gasket, did you use sealant when you put the water pump back in?
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Old 05-16-2010, 10:23 PM   #3
croadmar
Default
i sealed both sides of the water pump gasket. the water pump area and thermostat cover was bone dry when i started it up after changing it but coolant was leaking all over behind the pump somewhere. how do i get back there to see the actual leak?
Old 05-16-2010, 10:47 PM   #4
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
that is a lot of leak. Only a few things can leak that much, like a burst hose.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 05-16-2010, 10:54 PM   #5
88_Eddie
88_Eddie's Avatar
Vehicle Make: Ford
Default
Quote:
i hope that would have been one of the first things he checked
can you post pics?
__________________
Old 05-16-2010, 10:58 PM   #6
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Quote:
can you post pics?
Same here, I just can't think of anything else that could leak that much without being obvious about it. I mean 1 gal/min, its only a 3 gallon system.
__________________
Old 05-16-2010, 11:02 PM   #7
croadmar
Default
didn't see any hose leaks, but again, i can't really see the area without starting to tear off the top. i'll try and dig around the hoses
picture a v6 4.0 with coolant leaking all over the motor and tranny behind and above the water pump
Old 05-17-2010, 08:53 AM   #8
88_Eddie
88_Eddie's Avatar
Vehicle Make: Ford
Default
i've never really torn into the 4.0 in my exploder, so i'm not really sure where everything is located and what it looks like. i wonder if the block could be warped
__________________
Old 05-17-2010, 03:22 PM   #9
PARTSDEV
Vehicle Year: 1989
Vehicle Make: FORD
Vehicle Model: RANGER
PARTSDEV is on a distinguished road
Default
Check your lower t-stat housing.i work at a ford dealer-sell em all the time.sorry to say,bad design.
PARTSDEV is offline   Reply With Quote
Old 05-17-2010, 04:55 PM   #10
Clay Lorance
Clay Lorance's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: F-150 XLT SUPERCREW
I use this vehicle for: EVERYTHING
Clay Lorance has a spectacular aura aboutClay Lorance has a spectacular aura aboutClay Lorance has a spectacular aura about
Default
Quote:
What he said, had the same problem with mine about 3 months ago, thermostat housing probably has crack in th seam where the to halves meet.
__________________
2003 F-150 XLT SUPERCREW|4.6 V8|Automatic|P265/70/R17 Goodyear HPs|Towing Pkg|Harvest Gold
Texas members also join at www.rangersoftexas.com
Clay Lorance is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
