Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 05-23-2010, 11:38 PM   #1
p38fln
Junior Member
Vehicle Year: 2011
Vehicle Make: Ford
Vehicle Model: F-150 XLT SuperCab
I use this vehicle for: Daily driver
p38fln is on a distinguished road
Default Bank 1 / Bank 2 Too lean
Had this 2003 ranger for just under a year now, and the check engine light has started coming on. A code scanner gives two codes - Bank 1 lean, bank 2 lean. I also noticed that the misfire count went up by 1 when the code went to pending, and then went to 2 when the code went active, and at the same time there was a fairly loud ticking sound coming from the engine.
The freeze frame data said that the fuel mix was at 99% when the code was triggered, this is almost always at about 5% when I just look at it with the data feed.
Tried running 91 octane no-ethanol/oxy gasoline and clearing the codes, the problem came back in two drive cycles.
Looked carefully under the hood and noticed all of the spark plug wires going to the right side of the engine were touching each other, and the insulation had mostly worn off the parts that were touching.
Unplugged all the wires and routed them so they didn't touch each other anymore - the ticking sound was gone. The check engine light came back on a week later with the same bank 1 bank 2 lean code and showing a misfire on the misfire counter.
What are the possiblities that new spark plug wires could fix this? It seems somwhat random and always related to a cylinder misfire.
p38fln is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 05-24-2010, 12:59 AM   #2
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger FX-4 level 2
I use this vehicle for: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Default
From your description I'd venture a guess that about 99-1 for new wires would be the Vegas odds.
Big Jim
Big Jim M is offline   Reply With Quote
Old 05-24-2010, 10:03 AM   #3
snoman6115
snoman6115's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
I use this vehicle for: everything and tailgating
snoman6115 is on a distinguished road
Default
i had the "both banks lean" code and turned out to be a vaccum leak. the upper intake was leaking, replaced my valve cover gaskets, they were leaking slightly, and now i dont get that code. easiest is to replace wires first and plugs. all else fails look for vaccum leaks
snoman6115 is offline   Reply With Quote
Old 05-24-2010, 05:52 PM   #4
trader007
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger 4x4 4.0L
trader007 is on a distinguished road
Default
when i got that code, first cleaned my maf sensor (carefully too!). that helped, but i soon found out 1 o2 sensor was bad, so i replaced all 3 of them. that helped tremendously, but it still wouldnt keep the light off for more then a day or so. im pretty sure it was still running in open loop the whole time
finally, replaced the pcv valve and that finally did it. i know in my case i had other problems, but no reason not to check the simple things first. like snoman says, vacuum leaks/plugs can cause this code in a heartbeat!
trader007 is offline   Reply With Quote
Old 05-24-2010, 06:37 PM   #5
01_ranger_4x4
01_ranger_4x4's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
I use this vehicle for: Offroad, just for fun
01_ranger_4x4 is on a distinguished road
Default
as stated earlier, its most likely a vacuum leak. there are two elbows near the intake plenum on these SOHC 4.0's that crack and begin to leak vacuum (see photo below) its a very common issue with these motors but its a simple fix.
__________________
2001 stepside 4x4 4.0- RCD coilover lift, 33" KM2's, 4:56 gears, auburn gear LSD, headers, SCT tuner, flowmaster duals and other misc mods.
http://www.cardomain.com/ride/2321189
01_ranger_4x4 is offline   Reply With Quote
Old 05-25-2010, 02:23 PM   #6
Yellowsplash
Yellowsplash's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger Splash
Yellowsplash is on a distinguished road
Default
Quote:
Vacuum leak, vacuum leak, and lastly vacuum leak...dont even dare touch your O2's. Above is a pefect picture of what happens. I help customers replace one about once a week due to this problem. Once you are for sure there is absolutely positively no vacuum leaks, I'd think about venturing elsewhere. Your fuel trim tells you everything...
__________________
95 Ranger Splash, 4.0, M5OD-R1, BW1354M, D35, Exploder 8.8 31spl 4.88, No-Slip, SJ Class II 8" Lift, 3" BL, F250 Shock Towers, Bilsteins, 1pc DS, 35" BFG M/T KM2s on 15x10s...
95 Explorer, 01 ST, 03 Explorer 4.6 2V V8, 08 ST Adrenalin 4.6 3V V8, 03 Focus SVT EAP, 14 F150 FX4 Ecoboost, 14 F150 Raptor 6.2L
Yellowsplash is offline   Reply With Quote
Old 05-26-2010, 01:05 PM   #7
p38fln
Junior Member
Vehicle Year: 2011
Vehicle Make: Ford
Default
I plugged in my scan tool in and got these results (I tried to only select the ones that would matter)
Coolant: 192 F
ST FTRM1: 7.0%
LT FTRM1: 24.2%
ST FTRM2: 2.3%
LT FTRM2: 24.2%
Fuel Sys 1: CLSD
Fuel Sys 2: N/A
MAF Gr/Sec: 4.26
ST FTRM11: 9.3%
ST FTRM21: 3.1%
Old 06-07-2010, 05:48 PM   #8
p38fln
Junior Member
Vehicle Year: 2011
Vehicle Make: Ford
Default
Found the leak, the #1 cylinder is leaking at the air intake gasket.
Old 06-16-2010, 09:33 PM   #9
p38fln
Junior Member
Vehicle Year: 2011
Vehicle Make: Ford
Default
All but one of the intake gaskets were leaking slightly but the main leak was the elbow on the PCV vacuum hose.
No more leak - The O2 sensors are all bouncing around 0% +/- now.
Old 06-20-2010, 09:13 AM   #10
Yellowsplash
Vehicle Year: 1995
Vehicle Make: Ford
Default
Good to hear you found it...
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
