Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 05-25-2010, 11:51 PM   #1
greaseyfingers
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger
greaseyfingers is on a distinguished road
Default Where is the PCM to ground located on a 87 Ranger 4x4
Got a Code 95 - Fuel pump secondary circuit failure - PCM to ground
Where is the PCM ground located on a 87 Ranger 4x4?
greaseyfingers is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 05-26-2010, 01:02 AM   #2
low_five
low_five's Avatar
Vehicle Year: 1988
Vehicle Make: Ranger
Vehicle Model: 4x4 2.9l 5speed
I use this vehicle for: getting stuck
low_five is on a distinguished road
Default
powertrain control module - the computer or 'brain' inside the cab on the passenger side behind the kick panel where the passengers feet are. its probably not bad though. they rarely go bad.
__________________
how to pull codes on the EEC-IV.
http://www.therangerstation.com/tech_library/OBD_I.html
do it!
Quote:
Originally Posted by MAKG
Note that exponential inflation is a DESIRED OUTCOME.
low_five is offline   Reply With Quote
Old 05-26-2010, 10:44 AM   #3
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
Low_Five: you are placing the emphasis the wrong way around "PCM to ground"
the emphasis should be: "PCM to ground"
It's the grounding screw right next to the computer.
It's a common cause of fuel pump relay (and for that matter the EEC power relay) malfunction.
One thing that is often misunderstood is that EEC-IV does most of it's switching
on the ground side of each circuit, so if the PCM grounds are questionable not
much of anything will work correctly or reliably.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 05-26-2010, 12:38 PM   #4
greaseyfingers
Vehicle Year: 1987
Vehicle Make: Ford
Default
AD
Being the inside cab's metal panel is painted that the PCM's ground wire is suppose to be grounded to.
It must only be grounded through this small type screw's threads and the underside of this screw's head that contacts the PCM's ground wire terminal end, as this metal panel is painted where the ground wire terminal end makes contact contact with this metal panel.
This doesn't seem like a very reliable way to make a good ground, if the threads on the screw, or the threads in the metal panel aren't making good contact from rust, or any moisture.
Would it be better to scrape all of the paint off this PCM's grounding mounting area, down to the bare metal, before screwing the PCM's grounding wire to this metal panel for making a more reliable ground contact surface?
Could a Code - 95 Fuel pump secondary circuit failure - PCM to ground, be caused by a malfunctiong fuel pump relay, too?
Is the Code - 95 Fuel pump secondary circuit failure - PCM to ground, affecting both the primary and secondary, in tank, fuel pump's operation and possibly the fuel injectors, too? Besides, maybe, affecting the PCM's ability to function properly for maintaining reliable engine management from it's sensors, if the PCM isn't receiving a good ground?
Is it possible to replace the low pressure secondary, in tank, fuel pump and fuel sending unit, with a high pessure fuel pump and sending unit that will fit in the fuel tank of a 87 Ranger 4x4, STX, without having to make any modifications?
Will a fuel pump and sending unit from a 89 to 92 Ranger or Bronco 2, work for doing this?
Old 05-26-2010, 02:15 PM   #5
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Try sanding the paint off around the ground screw. I've seen that work many times.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 05-26-2010, 04:59 PM   #6
greaseyfingers
Vehicle Year: 1987
Vehicle Make: Ford
Default
I read this information at, http://www.fuelpumpinfo.org/page.php...ID=11&navID=27, that says this..
Running into a circuit failure in the fuel system?
Typically, circuits fail because of excessive resistance.
Excessive resistance limits current flow. Excessive resistance
is commonly found at the ground point where the fuel pump ground attaches to the frame rail ofthe vehicle.
Another common source of excessive resistance is pitting of the
secondary contacts of the fuel pump relay.
According to their information, another cause of excessive
resistance comes from spread fuel pump power and/or ground terminals at the fuel pump connector. When meter and test light leads are forced into terminals, the female terminals may spread and create a high resistance connection. Terminal tension can be verified by performing a “drag test” on female terminals. Poor terminal retention should be addressed by replacing
any spread terminals. The bottom line is that excessive resistance causes a decrease in current flow. When there is a decrease in current, the pump will not operate as designed.
Have any of you replaced a malfunctioning fuel pump relay, before, that had excessive resistance from pitting of the secondary contacts of the fuel pump's relay, with a new fuel pump relay and discovered that it improved your Ranger's engine's running performance, even though your Ranger's engine was still running while you were using your old fuel pump relay, but not as good, until after you had replaced it with new relay.
Old 05-26-2010, 06:32 PM   #7
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Yeah, and that paint on the ground and you hypothetical "poor contact on the threads" would both constitute resistance.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
