B&G_Automotive
- Sep 1, 2009
- Reaction score
- 0
- Location
- Amherst, Ohio
- Make / Model
- Pontiac
- Engine Size
- 3800 Series II Supercharged
- Automatic
Had a simple one come into the shop today, 2007 Ford Escape Hybrid 56,000 Miles. The ABS tone ring on the passenger side front Half-shaft cracked and became loose. This ring is what the ABS wheel speed sensor picks its signal up from to allow the ABS computer to determine if the wheel is having a traction issue. This is a very common problem for the Escape and causes the ABS and traction control system to go crazy. What happens is that corrosion forms underneath the ring building tension until it just cracks and pops it self free. I thought I would share this just incase there are any Escape owners on here and their dealer is telling them that the half-shaft needs to be replaced. That is not true; the part is replaceable and is a relatively simple straight forward procedure.
ABS System DTC's set from ring failure:
C1142 - Wheel Speed Sensor Right Front Tone Ring Tooth Missing Fault
C1234 - Wheel Speed Right Front Input Signal Missing
U2023 - Fault Recived From External Node
The Ford part number for this ring is 7L8Z-2C182-B cost was $35.51 plus tax. I don't know for sure if this one is specific for the 07 Hybrid so check with your local dealership parts department.
Here is the broken ring.
This is the replacement seems to be alittle heavier than the original on the car.
I will post the pictures of the repair later for anyone who might need them.
