Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-01-2010, 04:28 PM   #1
JesseCard
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger
JesseCard is on a distinguished road
Default 95 ranger 2.3L loss of power up hills
Hey everyone, I have a quick question about my 95 ranger. Lately I have noticed i have lost a significant amount of power while going up steep uphill freeways. I used to be able to cruise in 4th gear up the hill but now I have to down shift to 3rd to make it up the hill. Once i get off the freeway I give the truck gas and it will barley go, then seconds later the truck will backfire and will gain some of the power back. I was thinking it was the catalyic converter but i want to know your guys opinions.
Also, I started noticed the power loss after I put a lift kit on my truck and put all terrain tires and heavier rims. Does that have anything to do with it?
Thanks.
JesseCard is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 07-01-2010, 05:02 PM   #2
Duane867
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Duane867 is a jewel in the roughDuane867 is a jewel in the roughDuane867 is a jewel in the rough
Default
Check your plugs, wires, air filter..... basic tune up stuff 1st.
Then check your cat out. Is the floorboard getting hot during this time ?
Rotten egg smell, gas smell or anything like that ?
Duane867 is offline   Reply With Quote
Old 07-03-2010, 04:42 AM   #3
JesseCard
Vehicle Year: 1995
Vehicle Make: Ford
Default
I just changed the plug and plug wires. It has a k & n air intake. I don't smell anything when its loosing power up hills. It only smells riich when the truck is idiling. Could it be the cat? I've never checked it since I bought the truck 3 years ago...
Old 07-04-2010, 02:45 AM   #4
Duane867
Vehicle Year: 1993
Vehicle Make: Ford
Default
Did you gap your plugs or use them straight out of the box ?
Have you had a scanner hooked up to it yet ?
Old 07-04-2010, 04:24 AM   #5
JesseCard
Vehicle Year: 1995
Vehicle Make: Ford
Default
No I bought the wires and new plugs from auto zone. I took the manifold off and replaced all 8 of the plugs and wires. I didn't notice a difference in power. I started to notice the power loss when my big tires and rims were installed. The check engine light isn't on so what kind of scanner are you talking about?
Old 07-04-2010, 09:19 AM   #6
red85
red85's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: making noise and burning gas
red85 is on a distinguished road
Send a message via MSN to red85
Default
The big tires and wheels add a ton of rotational weight and a 4 popper will work proportionately harder on the hills because of that little upgrade. The best thing you can do now is to regear to lower ratios in order to regain the torque you lost at the wheels.
__________________
Professional Auto Service Tech
1996 Ranger XLT - 3.0 A4LD
1985 Ranger S - 306 ci/C4 (12.96 1/4)gone but not forgotten
1994 Ranger XL - 2.3T/M50D R1 (sadly retired now - Salt cancer got her)
2008 Ranger Sport - 3.0/M5OD R1
Don't ask a question if you don't want to hear the answer!
Putting brains before dollars since 1970
red85 is offline   Reply With Quote
Old 07-04-2010, 01:54 PM   #7
Duane867
Vehicle Year: 1993
Vehicle Make: Ford
Default
So you did or did not gap the plugs before installing them ?
I was talking about an ODBII scan tool to see if any codes were present.
Some will not produce a check engine light and in some cases the check engine light could be burnt out etc etc etc...
red85 is correct to btw... larger tire = more torque required to move them.
There is your significant loss of power I would assume.
Old 07-04-2010, 06:45 PM   #8
red85
red85's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
Default
Quote:
Originally Posted by Duane867 View Post
So
red85 is correct too .
Thank you! Now repeat this mantra to my wife!
__________________
Old 07-05-2010, 02:35 AM   #9
1985dangeranger
1985dangeranger is on a distinguished road
Default
you need a timing belt urs has to much slack mine was doing the same thing when i got it if u dont belive me move ur timing forward and it will have power
1985dangeranger is offline   Reply With Quote
Old 07-05-2010, 03:04 AM   #10
Duane867
Vehicle Year: 1993
Vehicle Make: Ford
Default
Unlike your 85'...A 95' is distributorless. Uses dual coil packs and 8 plugs. 4 on the intake side and 4 on the exhaust side. As well the Timing belt has an automatic tensioner. As it stretches is self adjusts to remove slack. If the tensioner fails or loosens and lets the belt slack then you have problems that are resolved by a new tensioner and belt or simply by re adjusting the tensioner.
There is no physical way to advance or retard the timing on a 95 2.3L
So in short .. no I don't believe you :-P
Original poster.....
If you did not gap your plugs before installing them then this is may be PART of your problem. You cant just stick them in their out of the box. You have to set the gap before installing. The gap sets optimal spark intensity. If you leave them as is out of the box then you are installing plugs that are with out doubt .025 - .035 ( thousandths of an inch ) to large in the gap and making it run rich as heck and creating a major power loss.
The other half of your problem is the larger tire and rim set up as Phil stated.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
