Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-03-2010, 02:28 PM   #1
SixFoFalcon
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger XLT SuperCab
I use this vehicle for: Comic Relief
SixFoFalcon is on a distinguished road
Default How to remove driver side O2 sensor?
At nearly 110k miles, I have a code for an upstream O2 sensor out of range. Normally I'm hesitant to swap O2 sensors before ruling everything else out, but in this case the sensors aren't too pricey and at their high mileage it's quite possible they are due for replacement, so I'd like to swap in the new sensors and see how that goes.
The passenger side was a piece of cake--the swap took all of 5 minutes using a 7/8" O2 sensor socket. The driver side is more challenging. The O2 sensor is practically resting against the engine block, which is making it impossible to slide the O2 sensor socket over it. I have to come in at an angle with the socket, and without clearance to straighten it out (it hits the engine block), I can only slide the socket down about 1/2 way toward the hex portion of the sensor. My 7/8" combination box & open-end wrench is mysteriously MIA from the tool chest, not that I'm sure I could even get that in there anyway.
Has anyone had success with an obstruction wrench or flexible/pivoting box wrench or flare nut wrench? I'm willing to buy such a specialty tool, but I don't want to spend all day running around picking up different tools on a trial and error basis.
And before anyone suggests removing the Y-pipe from the manifolds, understand that the flange bolts on the driver side are both rounded off. I'd probably have to do some surgery w/ a cutoff wheel to go that route.
__________________
My Family of Fine Fords
1999 Ranger XLT SuperCab - UDPs, HWBP, K&N, Dynomax cat-back, Xcal2, Bilsteins
2005 Focus ZX3 - the daily driver
1964 Falcon 2-dr Sedan - restoration in progress
SixFoFalcon is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 07-03-2010, 02:52 PM   #2
disciplerocks
July 2011 OTOTM Winner
disciplerocks's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II XLT
I use this vehicle for: the rippin and the tearin
disciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to behold
Default
When I replaced mine on my Focus, I bought the regular socket and got the front then had no room to get the back one out. I had to go and buy the L shaped "crows foot" socket. Here is a pic.
__________________
89 Bronco II XLT: 4.0, A4LD/5R55E, 1354 Doubler, 35" Baja Claws, XJ coils, FW HP44, Tru-Trac, Spooled FW 8.8 Disc Brake, 4.56s, OBA
94 F150 XLT: 5.0 HO, OBDII, E4OD
04 Focus ZX3: Built 5.0, T5, 4 lug 7.5, Rear Discs, 3.73s
12 Focus SE: Sport & Winter Package, ST Front End
Quote:
Originally Posted by AllanD View Post
Ford says (about towing not masterbation) "Don't do that!"
disciplerocks is offline   Reply With Quote
Old 07-03-2010, 03:02 PM   #3
t0x1k
t0x1k's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Keeping the wallet on a diet
t0x1k will become famous soon enought0x1k will become famous soon enough
Default
It's a very hard and long process but a smallish breaker bar that ratchets(or you'll be flipping the wrench around a lot) and the regular oxy wrench will do the job.
__________________
1994 XLT | 4.56 Dana 35/8.8 31 | 35x12.5x15 BFG KM2 | 5.5" suspension + 1.5" spacers + 3" body
1985 | 302 v8 | Tremec tko600 | Torq thrust 2s
t0x1k is offline   Reply With Quote
Old 07-03-2010, 04:36 PM   #4
SixFoFalcon
Vehicle Year: 1999
Vehicle Make: Ford
Default
Thanks guys. I ended up going to AutoZone and the woman at the parts counter searched through the tool rental boxes until she found one of the O2 sensor tool kits that had the 7/8" crow foot socket included. I had about 15 of room to turn my socket wrench from underneath the truck. The tricky part was removing the crow foot socket every 1/6 of a turn, since the protruding portion of the socket would eventually run into the engine block (or maybe it was the trans bellhousing... either way it was an immovable object).
So all in all it took about an hour and a bit of knuckle skin to swap that driver side O2 sensor. It never did get loose enough that I could turn it by hand, so I had to re-orient the crow foot socket and wrench about a dozen times.
Upon removal, I saw that two of the sensor's wire leads were damaged. It looked like they had been smashed during some previous repair job. After installing the new sensor, I made sure to route the wires out of harm's way before reconnecting the plug to the harness.
Hooked everything back up, started the engine, did the PCM "re-learn idle" procedure, and all seems to be well now. We'll see if the MIL stays dark and the MPGs improve in the near future.
__________________
Old 07-03-2010, 04:52 PM   #5
disciplerocks
Vehicle Year: 1989
Vehicle Make: Ford
Default
Good to hear. Glad it worked for ya!
__________________
Old 07-03-2010, 06:23 PM   #6
Spowerback
Banned
Spowerback's Avatar
Vehicle Year: 2010
Vehicle Make: FORD
Vehicle Model: RANGER
I use this vehicle for: DD
Spowerback is an unknown quantity at this point
Default
22mm-7/8"
not forget to put this at new part
Spowerback is offline   Reply With Quote
Old 07-03-2010, 06:34 PM   #7
disciplerocks
Vehicle Year: 1989
Vehicle Make: Ford
Default
Quote:
Originally Posted by Spowerback View Post
7/8"
He's got it finished. Read the thread before posting.
__________________
Old 07-03-2010, 06:42 PM   #8
Spowerback
Banned
Spowerback's Avatar
Vehicle Year: 2010
Vehicle Make: FORD
Default
ok good
Old 07-03-2010, 06:50 PM   #9
t0x1k
t0x1k's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Default
Did you have fun with hooking it back up to the harness? I was on the side of the road with my hand between the fire wall and engine using my middle and index finger to coax the two connectors back together.
__________________
Old 07-04-2010, 11:33 AM   #10
SixFoFalcon
Vehicle Year: 1999
Vehicle Make: Ford
Default
Considering all the crap I went through yesterday, plugging it into the harness was nothing!
In addition to the O2 sensor swap, I spent a good 3 hours with the dash apart, fixing stuff.
The horn switch contacts were dirty (had to punch the airbag whenever I wanted to honk the horn) so I pulled the airbag, cleaned the horn contacts w/ 800 grit sandpaper and protected them with dielectric lube.
Then I pulled apart the multi-function switch because I was having occasional problems with the left turn signal not flashing. Took me a good 30 minutes trying to fit that puzzle back together after I cleaned and lubed all the internals.
Finally I performed a long-overdo gauge cluster swap (I wanted to upgrade to a tachometer) which meant ticking the "new" odometer forward to match the truck's mileage. Then I had to drive around comparing the MPH on my GPS to the MPH on the new speedometer, pulling over every few minutes to reposition the speedo needle until I finally got it just right.
Also installed a new battery, changed the oil, and some other easy stuff.
So yeah, plugging into the harness wasn't so bad... from the sounds of it, the location is a little more accessible on my '99.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
