Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-25-2010, 03:26 PM   #1
kramocramed
Vehicle Year: 2007
Vehicle Make: Ford
Vehicle Model: Ranger Sport
I use this vehicle for: Everything.
kramocramed is on a distinguished road
Default Radiator Drain Plug?
I want to flush my radiator and put some new collant in. I'm at 59,000 miles.
Anyway, is this the plug that I turn? I want to be sure before I pull out any tools. Forgive my newbishness.
kramocramed is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-25-2010, 03:33 PM   #2
exbass94
exbass94's Avatar
Vehicle Year: 2006, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Default
Yes, that's the one.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 63k miles
1994 Ford Explorer Sport 2-dr 4x4, 203k miles
1992 Honda Accord EX, 182k miles
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek, 33k miles (wife's)
exbass94 is offline   Reply With Quote
Old 08-25-2010, 03:44 PM   #3
kramocramed
Vehicle Year: 2007
Vehicle Make: Ford
Default
Are the precedures the same as an oil change basically? Minus the new filter.
Take off top cap.
Drain old collant from bottom plug
Use a hose to further flush it? (read this somewhere I think)
Put bottom plug back on
Fill with collant until it's full to the top cap.
Replace top cap.
Correct?
Old 08-25-2010, 04:19 PM   #4
stmitch
March 2011 STOTM Winner
stmitch's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: Surprising people
stmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of light
Default
You should also be careful about getting all of the air out of the system. If you have air pockets, they can cause you to overheat.
stmitch is offline   Reply With Quote
Old 08-25-2010, 04:20 PM   #5
88_Eddie
Chopper Challenge Champion
88_Eddie's Avatar
Vehicle Year: 1988, 2000
Vehicle Make: Ford
Vehicle Model: Bronco II (Eddie Bauer), Explorer
I use this vehicle for: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
yeah, there's a kit you can get from autozone for $7 or $8 that you can use to flush it as well.
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Old 08-25-2010, 07:44 PM   #6
Rearanger
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger 3.0L
Rearanger is on a distinguished road
Default
I don't know if Ford has upgraded that plug since my 2003. If not be careful because you can break the plug very easily, as I did. Advance Auto has a fix it one to replace, which seems to be a better design than the OEM.
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS,
P235/70R-16, Synthetic fluids, 91.5k miles
Rearanger is offline   Reply With Quote
Old 08-26-2010, 09:20 PM   #7
mixwell
mixwell's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: Ranger 3.slooow
I use this vehicle for: DD
mixwell is on a distinguished road
Default
I would advise getting the flush kit @ Autozone.. It's no more than $10.. I'm doing a flush this weekend also.. By backflush you get everything out not just the radiator.. To me that drain plug was crap and slow.. Also remember the cap doesn't come off all the way, it gets to an open point and then that's it.. I usually drop the lower radiator hose because I'm impatient..
mixwell is offline   Reply With Quote
Old 08-27-2010, 04:49 AM   #8
Rearanger
Vehicle Year: 2003
Vehicle Make: Ford
Default
Quote:
If you mean the Prestone Kit that uses a garden hose adapter installed inline in the heater hose then I would recommend against it. The adapter is plastic and can produce a leak point from the plastic cap - as mine did. It's also a big hassle collecting and properly disposing of all the water/anti-freeze mix.
At 59k and 3 years he doesn't have much in the way of deposits in the system if he has the original coolant, or the proper mix. Consider doing as I do and just drain the rad once per year and replace with a 5 year 50/50 mix. I buy Walmart's. I also add a proportionate amount of Prestone additive to help lub the water pump.
__________________
Old 08-27-2010, 07:55 AM   #9
McCormack
Vehicle Year: 2000
Vehicle Make: Ford
McCormack is on a distinguished road
Default
Warm up the engine and then drain as much coolant as possible via the radiator petcock, then stick a garden hose in the filler neck and start the engine and run the engine until the water overflowing out of the filler neck comes out clear. Shut off the engine and let the radiator drain, close the petcock and fill with 50/50 antifreeze mix.
It's only on vehicles who's engine's head(s) are the highest point of the cooling system that you have to worry about air pockets (and those types of vehicles will usually have some type of coolant system bleeder valve on their engines), so you don't have to worry about cooling system air pockets on Ranger trucks.
McCormack is offline   Reply With Quote
Old 08-27-2010, 09:32 AM   #10
locovaca
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
locovaca is on a distinguished road
Default
Quote:
x2. My Dad put one on my sister's Taurus and it was leaking after only a year or so.
locovaca is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
