| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#13 |
So looking at the specs I see I do NOT have the forged pistons in my block, but is there another way to be sure they didn't use a turbo small block on my non-turbo 2.3 efi ohc?
I mean is there a VIN number verification for this like Digit 8? Since the rods are the same, could I use a LOW Pressure Blower, if so what would be the boast limit I could use? The other question I have if I want to find a small block with forged pistons in it, how do i identify, and verify it once it has arrived? Thanks you gear heads, you make my search so much eaiser... |
Tweet
#14 |
Year: 1987/1990
Make: fords and only
Model: ranger
Rep Power: 16 ![]() ![]() iTrader: (0)
oh cool...that is good info
__________________
1987 ranger super beast__1990 ranger
duff lift_________________2.9 to 4.0 swap dana 35 and sploder 8.8___duff 3 inch lift 302 swap_______________locked front and back cab off frame ![]() 97 ranger DD ![]() 3.0 manual every thing after market headlights 4.0 S.O.H.C swap in the works |
Tweet
#16 |
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Used For: Literally everything.
Rep Power: 18 ![]() ![]() ![]() ![]() iTrader: (1)
Ended up finding out some things that I was looking for.
Ala a Ford factory 1997 Ranger service manual: Rocker Arm (Cam follower) ratio - 1.86:1 Lobe Lift: 0.2163 (intake and exhaust) I got enough stock specs on things that can make people cry, If anyone would like more post up, but a moderate chunk of it is already here, at least the main stuff.
__________________
"The difference between genius and stupidity is that genius has its limits" - Albert Einstein Never give up: http://www.youtube.com/watch?v=Y6hz_s2XIAU 1984 Ranger - std cab, long bed: The Deathtrap 302; T18; D20 Tcase; 6' lift; 4.56 gears; 33' pro comp MT's; Aussie locked rear 1997 Ranger - std cab, short bed: Red Ranger 2.3L; M50D R1; 2wd; 4.56 gears; Explorer 8.8; ARB locker; 235/75R15 AT's (soon to undergo 4x4 conversion |
Tweet
#17 |
Year: 1983
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2WD
Used For: loving Beater
Rep Power: 0 ![]() iTrader: (0)
Great info, a great resource for us gen 1, 2.3L maintainers!
__________________
Chris 83 Ranger Owned since 85 |
Tweet
#18 |
Year: 1992/87
Make: Ford
Model: Ranger
Engine: 3.0/2.3
Class: 2WD/4WD
Used For: Street/Trail bitch
Rep Power: 11 ![]() iTrader: (0)
Might want to add to this: 2.3 carb'd head is missing a bolt hole that a 2.3 EFI head has. Simple fix is to drill and tap it(that's all they did at the factory). It's just one hole, and it's the one that the very front of the lower intake manifold uses to bolt onto the head. This is from my experience putting an 85 carb'd head onto an 87 EFI block.
Tweet
#19 |
you can make a butt load of horse power with the 2.3 i know of some one making like 450 hp to the tire my 2.3 make about 200hp it is bored has a ported turbo head with winsor vavles and sping a turbo cam with a 121 lobe seperation a match ported intake and a one barrel carb and 10.5.1 cr and get 30 mpg. it was built to pull a 20ft boat up north in michigan at 70. i looking to make it better i think iam going turbo or i just might put a big f ing stroke in it and my 450 or 500
Tweet
#20 | |
Year: 1984
Make: Ford
Model: RANGER
Engine: 5.7
Class: 2WD STREET
Used For: BUILDER
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
__________________
********THE BUILD THREAD********* http://www.therangerstation.com/foru...ad.php?t=96344 1984 FORD RANGER. 350 CHEVY SWAP. GONE BUT NEVER FORGOTTEN 1990 RANGER. 302 swap in the works ![]() 2001 VeeDub jetta. 2.0 5-speed. The daily driver (for now) |
Tweet
#21 |
I got a question really dont know if someone has posted about this cuz im new to the site.... I have a 2001 Ford Ranger 2.5. I was reading this first post about all the motors compared. I really want to do a turbo but dont feel like swapping motors. I know u can stroke the 2.3 to a 2.5. They dont really make aftermarket parts for the 2.5 but could i turbo my 2.5? are the exhaust manifold bolt patterns the same? also could i use 2.3 stroker parts for my 2.5 since the bore is the same?? I want to run 8:1 compression. Any help would be great guys. thanks
Tweet
#22 |
i have an 85 ford ranger with the 2.3, with manual trans. im trying to fix it up. i dont know a hole lot about it and i would just like to know what i got to do to give it a lil more. any input would be help full thanx alot.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
