rear main seal
b2rich
15+ Year Member
Lake Oswego, OR
It looks like i have a rear main seal leaking. It just started and so far I have gone thru a half quart of oil in 2 weeks.:annoyed:
I dont have the $$ to get it or to have it repaired right now.
can anyone recommend an additive that i can use in the oil to tide me over that will put a band-aid on the leak for now.
and NO a 4.0 is not a viable option right now. damn it.
You can try a pcv valve out of a larger V-8 sometimes that leak is just from excessive blowby or maybe just a new pcv when was the last time you changed it. Dont try and clean it they get old and they are cheap.
i changed it about 3 years ago.
the seal is only 11 bux, i dont reccomend any additive they tend to gum up the important stuff, u can try a diesel weight oil 15w40 20w50, that might slow it down some due to the thicker oil. i had to replace mine right when i got it, thats how i got it so cheap, not hard to do just a big pita
ummm ahhhh wellllll,
have you ever looked at something and just started obsessing about it till you come to the conclusion that the issue is worse than it really is ?
not me. noo!!
I got to thinking last night. :icon_idea:
If it was the rear main seal wouldnt i hear some sort of odd noise or a vibration or would it just be leaking out the bottom of the bell housing?
so i got up this morning and took a closer look from the top. I have oil on the top of the bell housing as well as the back left side of the block. Hmmm
so i follow the path of the up the block and to the lower bolt of the valve cover. i get my socket and extension out and what do you know. Its loose.:shok:
so i give it about 3 turns and or so its snugg. i also tightened the others about 1 turn each. DHOOO.
well that is all i got to say about that.
thats what i get when i assume. but generally i make the greater ass out of me.
anyway thanks for the responses. It never would of gotten me to looking outside of the box. or in the box or whatever.
:icon_cheers:
No, you would not hear any noises or anything. It would leak out of the bottom of the bellhousing or rear of the oil pan. It is like an $11 seal but you have to pull the tranny so after fluids, other seals, and stuff you'll be in deeper than that.
Good to hear that it is the valve cover seal... you should just replace that.. it will keep leaking. They're easy to change.
i wonder if it would be a bad thing to use some medium strength locktite on the fasteners.
I had the same problem on my 88.I was using 10/30 full syn.oil, then on my next oil change I used 10/30 High mileage Mobil 1 syn. an it stop leaking.3 oil changes later and still no leaks.
