alright well i've got my 302 and c6 in and driving, and its nice, but losing approximately SIXTY HORSEPOWER to a damn automatic trans is a real party pooper. and not having overdrive is simply brutal on the highway, even with 3.54's and 31's.
SO, its time for a T5 swap
keep in mind, i'm 2wd, so i shouldn't have any issues finding parts. however, im not using no mickey-mouse cable operated foxbody clutch setup. no deal.
so, in the next few weeks i'll be picking up a junkyard mustang 5.0 T5, and a 28 oz flywheel. and these guys right here:
http://www.summitracing.com/parts/TIL-61-612/
http://www.summitracing.com/parts/TIL-61-604/
the only thing im not too sure about is the master.
i wanted to be slick and use a factory master, but im not sure if its gonna push enough fluid for the big slave. plus, im not too sure about going from those cheapo plastic lines to the fancy AN lines the slave uses. anyone know the specs for the factory unit (bore, stroke, etc).?
my other option would be a nice universal wilwood master. its available in a few different bores, and offers more than enough stroke (i'm probably going to need a pedal stop). here it is:
http://www.wilwood.com/MasterCylinders/MasterCylinderList.aspx?minorname=Compact Master Cylinder
the only issue is how it mounts.
http://www.clutchcityonline.com/products/M0703.shtml
going by the pictures, it looks like the ranger master mounts on some kind of wacky angle, is that true? anyone know if they make some sort of fancy billet adapter to use a univeral master? cause i dont want to have to make complicated mounts...
lastly, how big of a job is it to get a factory ranger clutch pedal in there? can i pull the assembly at a junkyard and just bolt it in? or do i have to take apart the dash and crap?
sorry for such a long run on thread. any help would be greatly appreciated
