Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-12-2010, 04:21 PM   #1
BronKitis
BronKitis's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Bronco II XLT
I use this vehicle for: Spending retirement money on...
BronKitis is on a distinguished road
Default 6.5 Diesel Hard Starts :(
I have a 1992 Chevy K2500 with the 6.5L Turbo Diesel. I noticed that it was starting to start harder and harder so I replaced the glow plugs. Even before replacement, they seemed to cycle normally. The truck is STILL starting very hard, and by hard I mean lots of smoke and a miss at idle. It does fire right up with very short crank times but when she fires, she fires HARD. Blueish white smoke is what she blows, and a lot of it. If I rest my foot on the gas pedal and bring the idle up about 100 more rpms, it cleans up and seems to run much better. I really could use some help as I am far from a diesel mechanic! I don't wanna blow my baby up. Thanks!
BronKitis is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-12-2010, 09:28 PM   #2
trail B2
trail B2's Avatar
Vehicle Year: 1986
Vehicle Make: ford
Vehicle Model: bronco 2
I use this vehicle for: 4x4 and DD
trail B2 will become famous soon enough
Default
I have a 93 6.5 very similar trucks.One of the issues with these is starter speed what you can check for is starting to listen to other diesels start does yours sound slower maybe a u-tube video of one starting good.A diesel makes heat when the air compresses and the injector sprays a good pattern in the cylinder below a certain rpm neither of these things happen well enough to start good.The other thing thats weird about these is the starter doesn't quit it just turns slower and slower till the truck won't start.I just had to buy a starter and both batteries recently it sounded like the motor was going to fly out of the engine compartment compared to my old starter speed.
The other two culprits for not starting is a worn out injection pump and bad oil pressure sending unit.The test for a worn out IP is to put cool water on it with a warm engine but be careful this helps slow starter speed as well I was trying to find out why my new IP was bad and I needed a starter.There is a wire going to the IP from the OPSU and it doesn't start until there's oil pressure.If your OPSU is sticking it delays your starts.
__________________
We make A living by what we get, We make A life by what we give.http://www.therangerstation.com/foru...lies/yahoo.gif
trail B2 is offline   Reply With Quote
Old 09-12-2010, 10:59 PM   #3
Will
Super Moderator
Will's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: When I can't ride a motorcycle.
Will has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud of
Default
I agree that cranking speed is crucial. These are indirect-injected motors so they don't start as readily as a direct-injected motor. My bus has a direct-injected motor about the same size and no glow plugs and it starts on half a crank even in the winter. An indirect motor has a lot higher compression ratio which makes it a lot harder to turn over, and the injection takes place in a seperate chamber--the real injection into the combustion chamber occurs via a bit of the fuel going off and blowing the rest of the charge out of a hole in the injection chamber. There's no heat in there during cranking. If you aren't getting a good 8-second burn out of the glow plugs that would be a problem.
Air in the fuel system would make it idle really choppy and keep dying. Not much smoke though. Lot's of hard cranking, then it fires is when it smokes a lot.
How about a video clip of it cold-starting?
There is one injection pump piston (it's two, actually, but they are in the same bore) and a distributor rotates to aim the discharge down each injection line. If there was a problem with the pump, I doubt it would start at all. If there is air in one or two lines, it could start readily, but hard. I'm guessing an injector or two isn't sealing. they hold fuel in the lines and the new injection event advances the fuel through the injector. If the injector leaks down into the pre-chamber while it is sitting, there will be fuel sitting in there ready to smoke when you start it. And that injector won't have fuel in it so it won't contribute when you first start the engine. I think it's time to get a set of injectors in there.
That's just an opinion, by the way--I haven't had that problem. If you have an electronic pump it could be something with that. I've gotten air in mine, but it was before the pump and the truck doesn't start at all and doesn't smoke when it does start. I also have found that Optima red-tops smoke any other brand I've tried when it comes to hard winter starts. I've had this truck 6 years with these batteries and I was lucky to get 2 out of my Walmart/Exide yellow truck batteries. Also, I installed a battery charger under the hood so when I plug the truck in in the winter it's also warming the batteries. It's very important to keep the batteries at 100% with these.
__________________
'95 Ranger SC--obliterated in head-on with tanker truck. Being stripped for whatever parts may have survived.
'07 FJ Cruiser--4.0 6-speed. For while I build another Ranger.
'09 Mazdaspeed COBB Tuning--small but angry.
'14 ZX1000M; '09 TU250X; '79 XLS1000
Will is offline   Reply With Quote
Old 09-13-2010, 02:06 AM   #4
BronKitis
BronKitis's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
I believe it is injectors, but boy are those puppies spendy! My crank speed hasn't changed since day one and she usually fires with very little cranking. I mean bump the key and she's running whether it's rough or smooth. I drive a newer duramax at work and I'd say my 6.5 starts just as fast as it. I've never actually had to "crank" the motor to fire. I'll try to post a vid tomorrow after work on youtube and insert a link to show what I'm talking about. I REALLY think it's my injectors, but perhaps a vid and your oppinions will say different.
All the things said here kinda jumped over my head so hopefully I can catch on! I know how a Diesel fires, but that's about it.... Thanks for all the help!
Old 09-13-2010, 10:17 PM   #5
BronKitis
BronKitis's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
Okay, so I looked up some videos on Youtube and heard a familar noise- a light clacking! Most on youtube were much louder than mine but almost all were connected to injectors. I believe my clacking noise to be coming from rear cyl on passenger side. Looking at injectors on ebay now. Anyone know the benefits to marine injectors? Thanks
Old 09-13-2010, 10:36 PM   #6
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
moneyslave is about the best injector guy to deal with currently on e bay ...235 to your door us address and funds. i am buying a set right now myself.
unless you had a crap load of bad fuel its hard to see injectors suddenly dying...my injectors are way over due but i use heavy oil mix often and i think it masks the hard start...with clean real fuel i have hard starts comparatively.
this is assuming your not losing coolant, as it sounds like a gasket to me.
pretty happy with my little 6.5.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 09-14-2010, 12:24 PM   #7
BronKitis
BronKitis's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
Hmmm. I am leaking coolant but I dtermined it to be the lower coolant hose... Unless I'm mistaken. If it were a head gasket though, it probably wouldn't run smooth no matter what. As far as the issue I'm having, it started towards the beginning of fhe year and has gotten progressively worse with time...
Old 09-14-2010, 07:53 PM   #8
Will
Super Moderator
Will's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Default
I still think fuel system, but maybe check out your CDR valve. I don't know what happens when they go bad but it might be adding oil to the intake air. The hose will have signs of oil in it, but if the valve is bad there would be a lot of oil present and I would think you'd be losing oil at a significant rate. Turbo seals maybe too--I don't know if that would cause a run-away/engine destruction on a 6.5 or just be troublesome.
If the head gasket was blown I would think lots of nasty smelling bubbles would be coming up in the radiator. Take the cap off and start it.
__________________
Old 09-17-2010, 02:09 AM   #9
BronKitis
BronKitis's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
What/where is the cdr valve? She does burn some oil but I've always just attributed that to the fact she's a tired diesel... No bubbles in radiator... But my waterpump now seems to be leaking issue.
I wanted to test my plugs to make sure they are recieving proper voltage and what not. Anyone tell me how to test them? I appreciate all the help!
Old 09-17-2010, 10:26 PM   #10
Will
Super Moderator
Will's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Default
The CDR valve does the same job as the PCV valve in a gas motor, but because the engines are different, it works the opposite way. It's stuck into a rocker cover, just like a PCV. They both serve to evacuate crankcase fumes. The diesel has no vacuum at idle, but does have a little at power. A gas motor has lots of vacuum at idle and little at power. The PCV is mostly closed at idle to keep from drawing to much oil vapor, and too much air. The CDR is open wide at idle and closes off under power when there is too much vacuum which would suck up too much vapor.
The CDR is a lot larger because there is a lot less pressure involved. The failed CDR could suck up a heck of a lot of oil into the engine.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
