Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-15-2010, 11:55 AM   #1
ronin1865
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger Edge
ronin1865 is on a distinguished road
Default 2003 Ranger Edge 4.0L Idle problems
I have been having idle problems ever since I changed my sparks plugs about a month ago. Basically, the problem has been random where when I am stopping or turning the truck or as I am changing in and out of a lower gear and low speeds (its 5speed by the way) the idle drops below 500RPM and almost stalls out. I have had it stall out a few times. It normally surges back up to a normal idle position. Now since yesterday it wants to stall out completely at a stop light or as switching the gears at low speed. It drops below 500RPM and was idling all this morning at 500RPM at a stop light. In order to get to work I had to keep my foot on the pedal to keep it running. Any suggestions what it might be? As I am pretty SOL at this point.
ronin1865 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-17-2010, 10:28 PM   #2
ronin1865
Vehicle Year: 2003
Vehicle Make: Ford
Default
Ok so I replaced the IAC thinking that might be the cause of my problems. It help some but I still having engine idle problems. Truck rpm drop when stoping /shifting and rpm jumps around when stoped. Any suggestions are greatly appreciated. This is one off those problems that can get expensive quick replacing parts.
Old 09-17-2010, 10:48 PM   #3
gearheadjlm
Junior Member
gearheadjlm's Avatar
Vehicle Year: 2003
Vehicle Make: FORD
Vehicle Model: Explorer XLT
gearheadjlm is on a distinguished road
Default
Did you make sure you used the correct plug? Autozone (if you happened to get them there) list them as the wrong plug.
RPS Thread
gearheadjlm is offline   Reply With Quote
Old 09-18-2010, 05:36 PM   #4
ronin1865
Vehicle Year: 2003
Vehicle Make: Ford
Default
I did do that the first time I changed them and it ran like crap. I checked on here and someone had posted something about that. I called the dealership and got the correct part number, and was able to get the correct ones from Advance. I changed the wires too at the same time and got those from as advance as well. Maybe those are the wrong one??? I didn't change the coil pack though.
But maybe I got bad plugs or wires or the coil pack went bad?? Seems like all of this happened around the time I changed my plugs.
I'm going to clean the MAF tonight with some MAF cleaner maybe that will help.
Old 09-22-2010, 10:20 AM   #5
ronin1865
Vehicle Year: 2003
Vehicle Make: Ford
Default
so i cleaned the maf this weekend, but didn't make all that big of a difference. so, i'm thinking it might be the tps. has anyone had similar issues? can anyone tell me what their 4.0L idles at?
Old 09-24-2010, 09:33 PM   #6
dragonranger
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 4x4
I use this vehicle for: off roading
dragonranger is on a distinguished road
Default
you may have an intake manifold leak, this can cause idle problems as well.
dragonranger is offline   Reply With Quote
Old 09-27-2010, 01:08 PM   #7
91rangerxlt
91rangerxlt's Avatar
Vehicle Year: 1996 and 2002
Vehicle Make: ford
Vehicle Model: ranger xlt ranger edge
I use this vehicle for: ones a mudder ones a daily driver
91rangerxlt is on a distinguished road
Send a message via MSN to 91rangerxlt Send a message via Yahoo to 91rangerxlt
Default
i got an 02 ranger edge with the 4.0 its an automatic but i was having the same problems, low idle, wanting to die at a stop and whatnot. i heard a vacum leak and i found that my pcv hose was brittle and leaking. put a new hose on and it fixed the problem. runs like a champ now.
__________________
http://www.cardomain.com/ride/3802684
well aint you just a happy little spitf**k
91rangerxlt is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
