| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#121 |
July 2011 OTOTM Winner
Year: 1989, 1991
Make: Ford
Model: Bronco II XLT, Ranger XLT
Engine: 4.0, 2.3
Class: 4x4, 2WD
Used For: the rippin and the tearin
Rep Power: 23 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (5)
When to Liberty today because i am idiot. Guess I just wanted to walk around with my tools for a half hour and not get anything accomplished. Ended up at Glisson's. Only thing I found today was another D35 man hub. You can never have too many. Also stole a switch off a D28 man hub to fix the one thats on my truck.
Also got my cb installed.
__________________
89 Bronco II XLT: 4.0, A4LD/5R55E, 1354 Doubler, 35" Baja Claws, XJ coils, FW HP44, Tru-Trac, Spooled FW 8.8 Disc Brake, 4.56s, OBA 91 Ranger XLT: 2.3, M5OD, Dream Beams, 31 spline 8.8, Rear Discs, Limited Slip, 3.73s 04 Focus ZX3: 5.0, T5, 4 lug 7.5, Rear Discs, 3.73s 12 Focus SE: Sport & Winter Package, ST Front End |
Tweet
#122 |
Year: 1989, 1991
Make: Ford
Engine: 4.0, 2.3
Class: 4x4, 2WD
Picked up a set of 32s today for $100. After making it to have them mounted, the tire shop told me on of the side walls are ripped. Now I am out $100 unless I can find a couple more for cheap.
Also found an oil leak on the front of the motor. I am hoping its the oil pan gasket and not the main seal. Not a very good day.
__________________
Tweet
#123 |
Year: 1989, 1991
Make: Ford
Engine: 4.0, 2.3
Class: 4x4, 2WD
Guy that does my job on 3rd shift quit. Now I get to come in at 3am till someone else is trained in.
When I said I needed money, I didn't mean I wanted to work for it.
__________________
Tweet
#124 |
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (0)
Look on the plus side if it is the front seal you dont have to pull the tranny to fix it. Hope it is just loose bolts tho if you can get to them.
__________________
it takes a nickle to go first class when it stops hurting it will feel alot better
Tweet
#125 | ||
gravel in my travel
Year: 1990,92
Make: Ford,Ford
Model: B2,F150
Engine: 4.0,5.0
Class: 4x4, 4x4
Used For: tearin up the gravel roads
Rep Power: 14 ![]() ![]() iTrader: (7)
Quote:
__________________
Quote:
Tweet
#126 |
Year: 1989, 1991
Make: Ford
Engine: 4.0, 2.3
Class: 4x4, 2WD
Had a guy respond to my CL ad for tires. He gave me 3 Lemans A/T 32s for free. Not what I was looking for, but the price was right lol. Had them mounted on the way home so now she sits even.
New tires and a comparison pic of my 32s vs. my 30s. ![]()
__________________
Tweet
#127 |
August 2011 OTOTM
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0 OHV
Class: 4X4
Rep Power: 8 ![]() iTrader: (1)
Looks good but where is the side pic ? Text me a offer on those coils if you want them .
__________________
1997 FW44 37's. |
Tweet
#128 |
Year: 1989, 1991
Make: Ford
Engine: 4.0, 2.3
Class: 4x4, 2WD
I'll get one
__________________
Tweet
#129 |
Year: 1989, 1991
Make: Ford
Engine: 4.0, 2.3
Class: 4x4, 2WD
__________________
Tweet
#131 |
Year: 1989, 1991
Make: Ford
Engine: 4.0, 2.3
Class: 4x4, 2WD
Just had someone else call with 2 32's and 90% tread. Will be looking at those.
__________________
Tweet
#132 |
Year: 1989, 1991
Make: Ford
Engine: 4.0, 2.3
Class: 4x4, 2WD
Installed Skyjacker coils today that I got from 97TrailRigDD.
While taking the tire off I came across this. Damn Pep Boys when overboard with the impact. ![]() ![]() Skyjacker coil and my F150 coil and the washers. ![]() And some half ass flex shots. Damn radius arms won't let me stuff the front. ![]() ![]() My front end sits about 1 1/2" taller than the back now. Now how can I fix that? And Greg, on level ground the coil sits 16 1/2" high. Your motor must weigh yours down quite a bit.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
